Old 12-29-2009, 05:36 PM   #1
Feedback Score: 2 reviews
skip nay's Avatar
View skip nay's Photo Gallery(0)
Default Spark Plug Replacement
I have a 2008 Brute Force and was wondering what is the easiest way to replace spark plugs? The front cylinder is easy and I just turned the wheel. The back cylinder before I would fight and fight it. Well after being a couple tools shy that I needed I took off the upper part of the fender and then the clutch cover off. If I had a swivel it would be alot easier or if I had a deepwell flex socket.
So how do you replace yours?
2008 Brute Force 800: AMR 12.5:1 pistons, AMR XX cams, AMR Rings, Millennium Nikasil Cylinders, EHS Air Box Lid, Muzzy Pro Exhaust, Power Commander III, Moose Module, VFORCEJOHN SpiderMod Clutch (Maroon Spring), 24 LB Injectors, and a Bunch of Custom work to make it Reliable, Fast, and Tuned just right by VFORCEJOHN
skip nay is offline   Reply With Quote
Old 12-29-2009, 05:44 PM   #2
Shumate650's Avatar
View Shumate650's Photo Gallery(0)
Default
i have an 08 650 sra and on it i remove the rubber boot on the top of the clutch cover to get to the rear sparkplug. just loosen the two band clamps and pull it off. you will then have a clear shot of the rear plug. on mine i just use a straight extension and a spark plug socket. taking that boot off makes all the diference in the world. its still down in behind the shift linkage a little bit but very accessible. good luck
Shumate650 is offline   Reply With Quote
Old 12-29-2009, 09:35 PM   #3
AK650i's Avatar
View AK650i's Photo Gallery(0)
Default
Snorkle the Brute!!! Once done the stock CVT exhaust duct is gone and you can get right to the rear plug just by popping of the seat. I tried to pull my buddies plugs after he took it for a swim on a stock Brute and I feel your pain. With mine snorkled, a ratchet, swivle and two short extentions, I can have my rear plug swapped just as quick as the front. Plus the snorkles give you a little more piece of mind if you spend any time near water...and the cool factor goes way up!
2007 Brute Force 650i
26 Kenda Executioners/ITP SS108s
MIMB Snork/EPI Maroon Pri& Almond Sec
Moose Mod/ Custom Graphics/ Custom Front Rack
2000lb winch to snatch out Yammies...
AK650i is offline   Reply With Quote
2006 kawasaki prairie 360 spark plug
2008 brute force spark plugs
brute force spark plug socket size
change spark plugs kawasaki prairie 360
how many spark plugs does a kawasaki 650 prarie have
how many spark plugs does the prarie 360 have
how many spark plugs on kawasaki 360
how to change a spark plug on a kawasaki prairie 360
how to change plug 2008 kawasaki 650
how to replace spark plugs 2002 kawasaki prairie 650 4x4 atv
how to take plugs out of 08 brute 650
kawasaki prairie 300 4x4 spark plug wrench size
kawasaki prairie 360 remove spark plug
You may not post new threads
You may not post replies
NGK has a non resistor screw on replacement spark boot fast507 Kawasaki KFX700 V-Force 15 12-08-2008 08:22 PM
Spark plug wire boot replacement aztheride Kawasaki KFX700 V-Force 31 06-19-2008 12:05 PM
spark plug boot mod.......plug gap? STOGI Kawasaki KFX700 V-Force 1 05-24-2007 07:40 PM
best spark plug to run? vbob Kawasaki KFX700 V-Force 14 10-14-2006 05:04 PM
spark plug cap appfjord Kawasaki Tecate 4 07-28-2004 03:28 PM
