Just bought today, big problems
This is a discussion on Just bought today, big problems within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Quote: Originally Posted by Smokey What plastics do i have to pull to access the t-stat? And a few Newb questions, if there is a ...
Old 01-18-2010, 03:19 AM   #11
J2!
J2!'s Avatar
View J2!'s Photo Gallery(0)
Default
And a few Newb questions, if there is a thread already dedicated to this just point me in that direction
-Is it normal for it to sputter if i give it a lot of gas in reverse, as in some kind of speed cut or something? It seems to run perfect in all forward gears
-There is a weird mecanical clicking/whining on the left hand side(when looking from the front) after i shut this off, i assume this is normal?
-What should i be running for oil in a cold climate, and warm? Obviously there will be brand preferences, but i'm just looking for general opinions on viscocity etc.
Is there a place where i can find factory recommended service intervals, as well as an online owners manual?
Sorry for all the dumb questions, as i said if there is a place they've been covered before i apologize.
It has a limiter on the reverse.. There is a grey button on the handlebars that says override. Push it and go.. As for the whining noise when you turn it off, that is the engine break actuator, it is perfectly normal, they all do that..A dynatek cdi will bypass that reverse override too..
06' Arctic Cat Tony Stewart Edition - AMR 840 -And A Beer Cooler!!
www.bamaboggers.com
Powered By Argo Powersports
Sponsors:
Argo Power
Rubberdown Customs
Atv Direct
Mad Motorsports
Yasky Atv
J2! is offline   Reply With Quote
Old 01-18-2010, 06:34 AM   #12
View Smokey's Photo Gallery(0)
Default
This is a fantastic forum, thanks everyone for the quick, informative responses. I've determined that the fan is not coming on, i'll test the fan switch first and then have a look at the Buss connectors.
Also picked up a PDF service manual last night for $5, hopefully that should help me find my way around this thing
Smokey is offline   Reply With Quote
Old 01-18-2010, 06:52 AM   #13
greasemonkey's Avatar
View greasemonkey's Photo Gallery(0) Send a message via ICQ to greasemonkey
Default
If the thermostat is stuck closed, then the engine wil get hot but the radiator wont because the coolant isn't getting thru it .I would check that first.
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline   Reply With Quote
Old 01-18-2010, 07:37 AM   #14
Default
Ya, thats where i'm heading, just tested the fan and unless it's a bad switch, the fan and wiring are all fine. Gonna check the tstat right away
Old 01-18-2010, 08:46 AM   #15
Default
Well, i let it run without the cap to let any air out, put the cap on and took it for a 3 min ride. about 2 min in the light started flashing again, coolant is circulating so it's not t-stat, fan is coming on as well. Any ideas, now i'm stumped?
Old 01-18-2010, 09:50 AM   #16
Default
I should also note, the overflow tank is bubling, so it's not a fualty temp sensor or anything like that
Old 01-18-2010, 10:06 AM   #17
Feedback Score: 1 reviews
ncrider's Avatar
View ncrider's Photo Gallery(0)
Default
Make sure the radiator is not stopped up. Hard to tell sometimes. Put a light behind it and make sure it's clear.
05 Prairie, AMR 730, XX Cams, BKP Porting, BKP Intakes, 36's, Muzzy, 6 Degree key, Elka Suspension front and rear, VFJ Clutch.
04 KFX, AMR 800, 4X's, Kibblewhite Valves, BKP Porting, BKP Intakes, 36's, BKP Custom catch can, Cold Fusion Nitrous, Muzzy, VFJ Clutch, FST Clutch cover, Vens Swinger Ext. Elkas front and rear, ASR A arms, Flex Bars, And the list goes on and on....
05 Brute, FST Std Bore, Stage 2's, Big Kevs Porting, Muzzy, VFJ stage 3, 27's
ncrider is offline   Reply With Quote
Old 01-18-2010, 10:12 AM   #18
Default
It's clear and clean, there isn't a spec of mud on this thing.
Old 01-18-2010, 11:46 AM   #19
rwright's Avatar
View rwright's Photo Gallery(1)
Default
sounds like you got a LEMON! was this a personal buy or a dealer?
2005 Kawasaki Brute Force 750
Loud & Proud!
  1. 27" ITP 589
  2. K&N Air
  3. HMF Slip-On/Jetted
  4. CDI Dynatek
  5. Custom Temp Gauge
  6. Red LED 1 Watt Parking Lights
  7. Elka Suspension
  8. Full Pro-Armour Skid Plates
"The Difference Between Men & Boys is the Price of Their Toys!"
rwright is offline   Reply With Quote
Old 01-18-2010, 11:59 AM   #20
Default
Its a personal sale run thru his buddies dealership. He's willing to work with me, i'm taking it back and we'll see whats wrong with it. He's not being a dick about it, so that's a start.
Am i wrong at thinking this could be a blown HG? It runs fine otherwise, no coolant in the oil or vice versa, If it is the HG, whats that gonna cost to repair? Is it something i can tackle at home?
You may not post new threads
You may not post replies
Bought a V today fastfatboy Kawasaki KFX700 V-Force 9 03-14-2008 08:32 AM
Bought me one today BigDogkfx450 Kawasaki KFX450/KFX400 3 08-17-2007 04:43 AM
Bought me one today Enigma Kawasaki KFX450/KFX400 2 08-17-2007 02:25 AM
I bought a used 03 650 today. 650T Kawasaki Brute Force/Prairie/Bayou 5 04-05-2004 05:01 AM
Bought me one today PIPO Kawasaki KFX450/KFX400 0 12-31-1969 06:00 PM
