Just bought today, big problems
This is a discussion on Just bought today, big problems within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; now all that is over my head, you can prolly call mechanics in your area for a rough est....
Old 01-18-2010, 12:07 PM   #21
rwright's Avatar
View rwright's Photo Gallery(1)
Default
2005 Kawasaki Brute Force 750
Loud & Proud!
  1. 27" ITP 589
  2. K&N Air
  3. HMF Slip-On/Jetted
  4. CDI Dynatek
  5. Custom Temp Gauge
  6. Red LED 1 Watt Parking Lights
  7. Elka Suspension
  8. Full Pro-Armor Skid Plates
"The Difference Between Men & Boys is The Price Of Their Toys!"
rwright is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 01-18-2010, 06:04 PM   #22
View Smokey's Photo Gallery(0)
Default
Just went to fire it up to load it into my truck, and it won't start. Turns over just fine, and almost starts but it won't quite go, wonderful.
My first quad experience isn't going so well.
Smokey is offline   Reply With Quote
Old 01-18-2010, 06:23 PM   #23
Supporting Vendor
View Hunterworks's Photo Gallery(0)
Default
Quote: Originally Posted by Smokey View Post
I should also note, the overflow tank is bubling, so it's not a fualty temp sensor or anything like that
If over flow is bubbling then you have a blown head gasket, happened to me today. Replaced head gasket and bubbles are gone.
Hunterworks is offline   Reply With Quote
Old 01-18-2010, 07:47 PM   #24
Default
How much should i expect to pay? Or is it straight forward to do at home, any specialty tools req'd?
Old 01-19-2010, 04:55 AM   #25
Supporting Vendor
Default
No special tools and if you have not done it before now is a good time to learn since you have a manual.
Expect to pay at least a couple hundred bucks though probably more
Mine was already mostly apart so it only took me about a hour and half.
Old 01-19-2010, 01:52 PM   #26
Default
Well, it's out of my hands now. Dropped it back off at the shop, will update when i find out what the problem is.
Old 01-19-2010, 07:44 PM   #27
Default
So they are saying it just needs a valve adjustment as there is low compression in 1 cyl, does this make sense? How would that cause overheating? Just by overworking the other cylinder?
Old 01-19-2010, 08:01 PM   #28
Feedback Score: 2 reviews
w_pinkerton's Avatar
View w_pinkerton's Photo Gallery(0)
Default
valves out of spec can cause hard starts, and a bad head gasket can cause low compression and the coolant in your overflow tank to boil.
2002 P650 - Dynatek CDI, 25" Kenda Executioners, Pink Primary, BF750 Secondary, KEBC Removed, Plug boot mod, ODI grips, Aluminum Products Skids, Maier Handguards, Elka Spring Kit, Dalton OD Cover
w_pinkerton is online now   Reply With Quote
Old 02-07-2010, 10:32 PM   #29
Default
Turns out the front head gasket was toast. I brought it back to the shop and they tried to charge me 15 hours labour at $100/hr + parts, i laughed in their faces and picked it up, found a guy to do it for $200. He did the rear as well just in case, but told me the rear cam is showing a fair amount of wear, so i'll replace it(hopefully i can find one here). He said likely cause is lack of oil/not changing often enough.. Should i just get rid of this thing, or should it be ok with a new cam and proper maintenance? If it's a timebomb i rather just get rid of it, and pick up a new one
Old 02-08-2010, 04:17 AM   #30
Supporting Vendor
Default
Hard to say, kind of hard to believe the cam is toast and the head is not.
Bookmarks
You may not post new threads
You may not post replies
Bought a V today fastfatboy Kawasaki KFX700 V-Force 9 03-14-2008 08:32 AM
Bought me one today BigDogkfx450 Kawasaki KFX450/KFX400 3 08-17-2007 04:43 AM
Bought me one today Enigma Kawasaki KFX450/KFX400 2 08-17-2007 02:25 AM
I bought a used 03 650 today. 650T Kawasaki Brute Force/Prairie/Bayou 5 04-05-2004 05:01 AM
Bought me one today PIPO Kawasaki KFX450/KFX400 0 12-31-1969 06:00 PM
