This is a discussion on Just bought today, big problems within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Just picked up an 06 Brute force 650, 1800kms, bone stock. Took it for a quick spin before i bought it and all seemed fine. ...
| Kawasaki Brute Force/Prairie/Bayou Kawasaki's strong and reliable utility ATVs |
LinkBack | Thread Tools | Display Modes |
#1 |
Took it for a quick spin before i bought it and all seemed fine. Once i got it home after riding for 20 mins or so, the coolant temp light started flashing, checked coolant level and it was fine, felt the rad, wasn't even warm. Shut it down, pulled the oil filler and there was steam/smoke coming out. Fired it up and pulled the cap again and the crankcase is def pressurized, am I looking at a head gasket? Piston rings? I don't know a thing about small engines, but i know on my cars pressure on the bottom end is BAD news. If it is a head gasket, whats it gonna cost me for parts and labour? |
| Sponsored Links | ||
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free! |
#3 |
what do you mean the crank case is preasurerized? need more info on that? and when you say cap,do you mean the radiator cap? if so its soposed to have preasure on it! is the fan coming on? take the cap off and start the bike! by doing that it will let all the air outa the system. the coolant level should drop when u start it! top it off and then see if it still over heats! ive seen brutes over heat because of air in the system. b4 i would look @ the top end i would change the thermastat and install a temp gage and see if it indeed is overheating! also wash the red out really good!! it dont take much to make a brute over heat!! you my also want to look into racking the raditior!!
#4 |
These things have mega crankcase pressure. Its normal for it to shoot oil out of the filler hole if you take it out. I would take a temp reading of the engine, around the head or t-stat housing while running it to see how hot its getting. Could be a bad sensor, or wire shorting out.
1987 Tecate 4, Stock, being restored. 2008 brute force 750 4x4i EFI, warn 2500 winch, cheapo ebay pos skid plates, power commander, EPI maroon primary, 26" Kenda executioners |
#5 |
Yes, i was talking about crankcase pressure, not coolant pressure. I will fire it up tomorrow and see if it's just air in the system, it would seem that would probably make sense because the rad doesn't appear to be getting hot at all.
And no, private sale but the guy seems willing to work with me. |
#7 |
Yes, lots of crankcase pressure is normal.
#8 |
What plastics do i have to pull to access the t-stat?
And a few Newb questions, if there is a thread already dedicated to this just point me in that direction -Is it normal for it to sputter if i give it a lot of gas in reverse, as in some kind of speed cut or something? It seems to run perfect in all forward gears -There is a weird mecanical clicking/whining on the left hand side(when looking from the front) after i shut this off, i assume this is normal? -What should i be running for oil in a cold climate, and warm? Obviously there will be brand preferences, but i'm just looking for general opinions on viscocity etc. Is there a place where i can find factory recommended service intervals, as well as an online owners manual? Sorry for all the dumb questions, as i said if there is a place they've been covered before i apologize. |
#9 |
Supporting Vendor
And a few Newb questions, if there is a thread already dedicated to this just point me in that direction -Is it normal for it to sputter if i give it a lot of gas in reverse, as in some kind of speed cut or something? It seems to run perfect in all forward gears -There is a weird mecanical clicking/whining on the left hand side(when looking from the front) after i shut this off, i assume this is normal? -What should i be running for oil in a cold climate, and warm? Obviously there will be brand preferences, but i'm just looking for general opinions on viscocity etc. Is there a place where i can find factory recommended service intervals, as well as an online owners manual? Sorry for all the dumb questions, as i said if there is a place they've been covered before i apologize. Plastic on right side as you sit on it where the thermostat is Remember anytime someone mentions sides it is as you sit on it. |
#10 |
oil- 0 degrees and below -- 5w 30
-10 up to 30 degrees --10w 30 -10 up to 40 degrees --10w 40 0 to 40+ degrees -- 10w 50 0 to 40 degrees --20w 40 0 and up --20w 50 The kawi place put 10w 40 in it when I bought it . I used 20w 50 when i changed. temp in summer are way hot here in texas . thats why I gave u a list to refer to that came out of manual. It depends on what your temps average around where u live. the service book wants u to change oil every 100 hrs (I think) I change mine every 50.I'd rather change early, 100 hrs seems too long . remember the only dumb question is the one never asked..
Back to Top
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bought a V today | fastfatboy | Kawasaki KFX700 V-Force | 9 | 03-14-2008 08:32 AM |
| Bought me one today | BigDogkfx450 | Kawasaki KFX450/KFX400 | 3 | 08-17-2007 04:43 AM |
| Bought me one today | Enigma | Kawasaki KFX450/KFX400 | 2 | 08-17-2007 02:25 AM |
| I bought a used 03 650 today. | 650T | Kawasaki Brute Force/Prairie/Bayou | 5 | 04-05-2004 05:01 AM |
| Bought me one today | PIPO | Kawasaki KFX450/KFX400 | 0 | 12-31-1969 06:00 PM |
Looking for information on other ATV Manufacturers? Head on over to visit our friends on these other forums specializing in the following: Kawasaki ATV - Can-Am ATV - Polaris ATV - Suzuki ATV - Yamaha ATV - Honda ATV - KTM ATV - Yamaha Raptor - Can-am DS450 - Kawasaki KFX 450 - Suzuki LTR 450 |
