Old 01-29-2010, 08:49 PM   #1
View JohnZX2's Photo Gallery(0)
Default ’08 Kawasaki 750 Brute Force starting problems
My dad bought a 2008 Kawasaki 750 V-twin fuel injected Brute Force. The previous owner replaced the piston rings, and could not get it start after reassembly. My dad has checked the compression and timing, it was good. It has spark and HAD fuel, now the injector light is on and the injectors are not working. Even with no fuel, he could not get it to hit even by spraying carburetor cleaner in the throttle body’s. It really does seem like the spark is not firing on time.
I work on tuner cars and know very little about ATV’s. Any help would be greatly appreciated.
JohnZX2 is offline   Reply With Quote
Old 01-30-2010, 04:44 AM   #2
Feedback Score: 1 reviews
View Hunterworks's Photo Gallery(0)
Default
A easy check would be make sure the rollover sensor is sitting in its' place and in correct position.
It will turn the injectors off.
Bet the cam timing is off too if it has never started since.
Here is the procedure for cam timing.
From the flywheel (left as you sit on it) side of the engine using the bolt under the cover rotate the engine clockwise until the TR aligns with the mark on the inspection hole on the flywheel cover. Remove the rear valve cover with the rocker arms in it and then place cam with lobs pointed down and align the marks on the cam gear at 9 and 3 o'clock with pointer pointing up. Once you have this cam sitting in this position with all the marks lined up put the cover back on. Then rotate the crank clockwise 270 degrees until the TF lines up then just repeat the procedure. You will also need to remove the cam chain tensioner to do this.
To reinstall the tensioner, remove the 12mm bolt from center before you remove the tensioner from engine then when you get ready to put it back, trip the little catch and slide the tensioner pin back into the housings. Once you get the two mounting screws back in put the spring and rod back in and then install the 12mm bolt all at the same time.
Also, where are you?
Hunterworks is offline   Reply With Quote
Old 04-18-2010, 01:08 PM   #3
View Big BP's Photo Gallery(0)
Default
brute force starter problems?
2009 BF 650I
Black w/black racks
2" HL LIft
TwinAir Air Filter
27" Mudlites on
Black ITP SS 108
Full Bayou Snorkle
Stage 1 DynaJet Kit
Big BP is offline   Reply With Quote
Old 12-28-2011, 05:46 PM   #4
View ACE6842's Photo Gallery(0)
Default
I'm having same problem on a 07 750 that's carbed.. Any idea what would make it fire? it's never been tore into but I would like to know what would fix it b/c I'm out of ideas.
07 Brute 750 NRA Edition
29.5" Outlaws/Highlifter XL2
Highlifter extreme clutch kit
Dynojet Jet kit
Fully Snorkeled
HMF Exhaust
Warn Winch
ACE6842 is offline   Reply With Quote
08 brute force problems
2008 brute force 750 down sensor
2008 brute force problems
2008 kawasaki brute force 750 problems
2008 kawasaki brute force problems
brute force 750 starter problems
brute force starting problems
how to test injectors on a 08 kawasaki bruteforce 750
kawasaki brute force 750 starter problems
kawasaki brute force 750 starting problems
spray carb cleaner into throttle body on kawasaki prairie
You may not post new threads
You may not post replies
starting problems 04kfx7 Kawasaki KFX700 V-Force 1 11-18-2009 04:57 AM
Brute Force problems HELP PLEASE jmeier1981 Kawasaki Brute Force/Prairie/Bayou 5 07-18-2009 07:46 PM
Starting Problems gitrdone Kawasaki KFX700 V-Force 4 05-04-2009 03:05 PM
starting problems MUddogg Kawasaki KFX700 V-Force 3 12-12-2008 05:20 PM
starting problems vtprairie03 Kawasaki Brute Force/Prairie/Bayou 9 06-06-2005 05:16 PM
