Changing belt, do I need to adjust? - Kawasaki ATV Forum
post #1 of 5 Old 02-11-2010, 07:40 AM Thread Starter
Desertfox's Avatar
Have an OEM belt on the way, figure I should change it @1700 miles but through someones experience is it really neccesary for a $31 clutch puller? I am use to changing belts on snowmobiles so is it that bad to do it by hand on the brute? My biggest concern is if I will need to make any adjustments as far as the new belt being to loose. I know how the sensors can be. I got the big book but how hard is it too correct the proper tension?
Desertfox is offline
post #2 of 5 Old 02-11-2010, 08:08 AM
Camo Joe's Avatar
Take a look
Take a look at this..........it might help................
MudInMyBlood Forums How To: Tighten the Belt
Camo Joe is offline
post #3 of 5 Old 02-11-2010, 08:17 AM Thread Starter
Desertfox's Avatar
Nice
Wow that about covers it, thanks. One more thing, considering I am going to have this apart could anyone recommend a spring. I run 27" tires and quite a few mods but for trail, some mud, and all around riding would a maroon spring be the way to go?
post #4 of 5 Old 02-11-2010, 11:53 AM
Camo Joe's Avatar
I would say you are ok ............both of my machines are stock but with 28" tires ..........and no problem............
Camo Joe is offline
post #5 of 5 Old 02-11-2010, 01:03 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
The "proper" way is to use a primary clutch puller, but you can use a soft tool and pry the secondary sheaves apart far enough to roll the old belt off and roll the new one on. If the tension has never been adjusted, you MAY be able to simply install the new belt without adjusting the tension.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
Question about changing belt B.Anderson Kawasaki KFX700 V-Force 16 12-22-2009 08:05 AM
how to adjust the valves? sdteb Kawasaki Brute Force/Prairie/Bayou 2 01-06-2007 05:57 AM
Belt Adjust Overspray Kawasaki KFX700 V-Force 1 08-16-2005 09:17 PM
Belt adjust 4wheelfurry Kawasaki Brute Force/Prairie/Bayou 9 01-04-2005 02:06 PM
changing the belt! kalel123 Kawasaki KFX700 V-Force 5 12-09-2004 09:20 AM
