Old 02-15-2010, 08:15 PM   #1
View poboymuddin1's Photo Gallery(0)
Thumbs down 2005 kawaski prairie 360 problem help?
i got an 05 prairie 360 i rode it for about 4 hours and shut it off. i brought it into the shop to work on it because it would lose power and backfire and a quarter throttle. i took the carp off and cleaned it while apart i went ahead and put a jet kit in it. i put it back together and it still did the same thing. so i changed the spark plug still didnt help. so i drained all the gas out of the tank and the carp and put new in. it still did the same thing. does anyone have any other ideas.
poboymuddin1 is offline   Reply With Quote
Old 02-15-2010, 08:22 PM   #2
Camo Joe's Avatar
View Camo Joe's Photo Gallery(0)
Default flash?
Is anything on the display flashing?????..........4x4, belt light????
Camo Joe is offline   Reply With Quote
Old 02-15-2010, 08:24 PM   #3
Default
yes the 4x4 light flashes every two seconds but i had it looked at and it means that the engine break accuater is going out it did that before i this all happened but thanks
Old 02-15-2010, 08:34 PM   #4
Camo Joe's Avatar
Default limp?
So you know its not in limp mode?
Old 02-15-2010, 08:44 PM   #5
Default
no idk how to check that i just no that the light ment that it was the accuater how do you check for the limp mode?
Old 02-15-2010, 09:17 PM   #6
Camo Joe's Avatar
Default .........
If its in limp mode .......it won't shift into 4x4 and the engine rpms are limited.................Is the belt light on or flashing? Check all that and let us know................
Old 02-16-2010, 01:43 PM   #7
Default
no the belt light is not flashing just the 4x4 with that accuater code
Old 02-16-2010, 04:30 PM   #8
Camo Joe's Avatar
Default ...........
Does it shift into 4x4?
Do you hear the 4x4 actuator engaging?
Does it run ok at idle or a little above? Does it have full power at low engine rpms?
Old 02-16-2010, 06:58 PM   #9
Default
yes it shifts into 4x4 and it runs good at an idle but when you give it hardly any gas it starts to backfire
Old 02-16-2010, 08:45 PM   #10
Camo Joe's Avatar
Default
Ok......
Is the battery up?
Is the charging system charging?
Does it spit and pop back through the carb when its backfiring?
Does it get better or worst by choking it?
It sounds like the pilot jet or circuit in the carb has something in it.
From 0 -1/4 throttle is the pilot jet..........make sure the jets and circuits are clean............
If its not the carb..............it could be the ignition coil being bad or not getting enough amps from the battery/charging system.
Also there could be a vacuum leak somewhere...........check all the hoses for cuts, breaks, or not being on correctly.
05 kawasaki prairie 360 4x4
2005 kawasaki 360
2005 kawasaki 360 prairie
2005 kawasaki 360 prairie 4x4 carburator
2005 kawasaki prairie 360
2005 kawasaki prairie 360 4x4
2005 kawasaki prairie 360 4x4 light flashing
2005 kawasaki prairie 360 4x4 reviews
2005 kawasaki prairie 360 review
2005 kawasaki prairie 360 specs
kawasaki 360 prairie problems
kawasaki prairie 360 4x4 problems
kawasaki prairie 360 review 2005
You may not post new threads
You may not post replies
2005 kawaski prairie 360 problem help? poboymuddin1 Everything Else 1 02-15-2010 08:18 PM
1997 kawaski lakota primary clutch set-up wanted klines corvettes Wanted 0 01-16-2010 06:45 AM
kawaski w/ problems 440kawasakikfx Kawasaki KFX450/KFX400 4 01-03-2010 10:31 PM
2005 brute force 750 4x4 Problem.. waylonnewman Kawasaki Brute Force/Prairie/Bayou 20 09-23-2009 05:01 AM
2005 Prairie 4x4 selection problem Mike SVOR Kawasaki Brute Force/Prairie/Bayou 5 11-27-2006 05:12 AM
