03-02-2010, 06:10 PM
#1
BF Street Tires
here in Free America (Arizona) we can ride the street properly licensed. In the summer, i don't trail ride due to the heat here in Yuma, 120+!!!! I was wondering, what kind of hard pack/street tire to use on a set of ITP delta steels that i just got just for cruising around the neighborhood???? i was looking at the Kenda street tires but am looking for recommendations. it would not be too much on the street, just cruising the parties on the block, maybe 1-10 miles at the most, also looking for cheap, don't need Pirelli's!! thanx in advance!!!!
03-02-2010, 06:21 PM
#2
Feedback Score: 18 reviews
Try the duro scorchers. I liked them during the limited time I had them on the roads
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
03-02-2010, 06:41 PM
#3
little pricey....i'm cheap!!!!!!!!!!!!!!
03-02-2010, 06:43 PM
#4
Lawn Mower tires then..
You said you were cheap and just wanted to cruise.
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
03-02-2010, 08:28 PM
#5
HA! i was thinking more along the lines of the Kenda street tire!
03-03-2010, 07:08 AM
#6
Would they have to be D.O.T approved tires? If so some small cars have the same lug patterns as our wheelers.
09 650I BruteForce TJD TRACKS, 907 riders.
03-03-2010, 08:46 AM
#7
If they have to be dot approved ,ITP sells 14" rims and then you can use car tires.
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
03-03-2010, 08:51 AM
#8
no need to be DOT approved, just around the neighbor hood, i have an extra set of 12" rims so i really wanted hard surface tires for them so i don't have to buy 14"s. Kenda makes a 26x12 front and rear hard surface tire, but they are a little pricey.
| Search tags for this page |
12 inch atv street tires, 12 inch dot tire, 14 dot atv street tires, 14 street tires for a kawasaki teryx, 2010 polaris 15 inch street tire sets, brute force street tires, dot tires for atv, kawasaki atv street tires, kawasaki prairie street tires, kawasaki teryx dot tires, kawasaki teryx street tires, street tires for polaris ranger, teryx dot tires
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
street use
slick |
Kawasaki KFX700 V-Force |
17 |
04-21-2009 07:20 AM |
More street tires
Eforce13 |
26 |
05-13-2008 10:43 PM |
street tires mounted
minimus |
Kawasaki Brute Force/Prairie/Bayou |
32 |
05-12-2008 05:23 PM |
Pro-Street Ext. Cab S-10
TeamGreen700 |
For Sale |
2 |
10-10-2007 11:16 AM |
Street Tires
ckill |
10 |
07-21-2004 02:46 PM |
» Site Navigation |
» » Other Sites
