Belt Adjustment - Kawasaki ATV Forum
post #1 of 3 Old 03-03-2010, 02:56 PM Thread Starter
Belt Adjustment
Hey all. Time to work on my 2002 Prairie 4x4. I have a squeal which is in the clutch area... I think. Only happens for about .5 seconds when engine has almost slowed down to an idle after letting off of the gas. I've pulled the cover off and the drive belt appears to have a lot of play in it. I've read the instructions from the manual but there is one thing I'm not sure of. After rotating the left pulley to get the belt to the top and placing the straight edge on the pulleys I find that as I push down on the belt it slides under my straight edge to where I have a ton of slack. Am I suppose to hold the straight edge down hard enough so the belt doesn't move like that? Just looking at it it appears that there is about 8in. of distance between the top of the belt and the bottom of the belt. Also, I can almost clamp both sides of the belt together with my fingers with out causing the belt to move deeper into the left pulley. This was hard to explain so sorry if it's a bit confusing. Also, is the belt suppose to be notched on both sides?
Last edited by drenski; 03-03-2010 at 03:01 PM. Reason: forgot to put something in.
drenski is offline
post #2 of 3 Old 03-03-2010, 08:32 PM Thread Starter
Ok.. I took apart the driven pulley and it appears that the spring and wear shoes need to be replaced. I also found that the squeal is coming from the drive pulley as it resets itself as the rpm reduce. Can I put some WD40 in there without causing a problem?
drenski is offline
post #3 of 3 Old 03-03-2010, 08:36 PM
Feedback Score: 23 reviews
T_Dilley's Avatar
I don't think it is recommended to use any lubricant as it will attract dirt.
Get with VForceJohn. He can get you the parts you need and tell you how to clean it all up.
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
T_Dilley is offline
2000 model kawasaki 300 prairie automatic drive belt
2002 kawsaki prairir 360 belt adjustment
how do you adjust the belt on a prairie 360 atv kawasaki
how to adjust a kawasawki atv drive belt
how to adjust drive belt kawasaki prairie
kawasaki 360 belt adjustment
kawasaki 360 prairie belt adjustment
kawasaki 650 prairie belt adjustment
kawasaki atv belt adjustment
kawasaki belt adjustment
kawasaki drive belt adjustment
kawasaki prairie 360 belt adjustment
kawasaki prairie 360 clutch adjustment
first belt adjustment LG09BRUTE Kawasaki Brute Force/Prairie/Bayou 1 11-12-2008 11:00 AM
Belt adjustment Overspray Kawasaki KFX700 V-Force 3 08-16-2005 10:39 PM
Belt adjustment done! desdak4 Kawasaki KFX700 V-Force 10 05-05-2005 09:44 AM
Belt adjustment? BamaBrute Kawasaki Brute Force/Prairie/Bayou 4 02-03-2005 04:50 PM
Belt Adjustment ??? Again jcsact Kawasaki Brute Force/Prairie/Bayou 9 06-14-2004 08:20 AM
