Corvette fuel pump
This is a discussion on Corvette fuel pump within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Well after having a few problems with my fuel pump, and refusing to spend the $600 on a new OEM kawie one, which is a ...
Old 03-11-2010, 04:56 PM   #1
chucked's Avatar
View chucked's Photo Gallery(0) Send a message via AIM to chucked
Default Corvette fuel pump
Well after having a few problems with my fuel pump, and refusing to spend the $600 on a new OEM kawie one, which is a bunch of bs because its a piece of plastic with a small pump in it.... I decided to make my own. I started on it yesterday. Got pretty far on it today. The fuel pressure regulator will be in tomorrow. So hopefully this time tomorrow I will have it running.
2008 brute force 750 4x4i EFI, warn 2500 winch, cheapo ebay pos skid plates, power commander, EPI maroon primary, 26" Kenda executioners
chucked is offline   Reply With Quote
Old 03-11-2010, 04:58 PM   #2
chucked's Avatar
Default
Keep in mind this is sort of a prototype... Everything is pretty solid though, except for the fuel level sender. Which isn't that important. I couldn't really come up with a way to attach is very solidly. Its got a heavy duty zip tie holding it now.
I will have under $225 in this... $70 for the pump, $100 for the regulator. Plus some hoses, fittings, aluminum for the bracket, and the filter. Funny thing... The ford car filters clip right into the OEM fuel line going to the carb.
Old 03-11-2010, 05:00 PM   #3
Feedback Score: 2 reviews
MetalAlien's Avatar
View MetalAlien's Photo Gallery(0)
Default
if it works, it's perfect!
The Secret to speed
http://www.youtube.com/watch?v=3qATbWyxYZI
Demon carb test (full run)
http://www.youtube.com/watch?v=O8Ozpu_t8lQ
MetalAlien is offline   Reply With Quote
Old 03-11-2010, 05:03 PM   #4
chucked's Avatar
Default
I had it hooked up with the fuel line going into a can, it shoots out of there!!! Probably 10 oz or so every 3 seconds.
Old 03-11-2010, 06:28 PM   #5
Feedback Score: 19 reviews
05-BF-750's Avatar
View 05-BF-750's Photo Gallery(4) Send a message via AIM to 05-BF-750
Default
Very interesting So was the Vett pump not $600 or more like the OEM? I would have thought it would of been more??
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
05-BF-750 is offline   Reply With Quote
Old 03-11-2010, 07:04 PM   #6
chucked's Avatar
Default
It was $70. And actually most chevys used this pump during the 90s. I just say corvette because it makes it sound like its a badass pump
Old 03-11-2010, 07:33 PM   #7
05-BF-750's Avatar
Default
Yea will it worked.
Old 03-12-2010, 02:56 AM   #8
redlined's Avatar
View redlined's Photo Gallery(0)
Default
Hey...I noticed on one of your pics on the brass nipple threads you used teflon tape.....that's a no-no in a fuel system. Might want to remove it before you get it all together. You'll eventually find it in the filter...or in the form of a leak. Other than that can't wait to hear the results...looks good!!!!
redlined is offline   Reply With Quote
Old 03-12-2010, 05:38 AM   #9
chucked's Avatar
Default
Hmmm good point. Ill redo it today with dope
Old 03-12-2010, 05:52 AM   #10
redlined's Avatar
Default
Cool. That's the point of these forums, eveyone helping everyone....
04 corvette fuel pump removal
07 vette fuel pump replacement
2005 corvette fuel fuel removal
2005 corvette fuel pump location
2005 corvette gas removal
2008 corvette fuel pump replacement procedure
2009 brute force burns up fuel pumps
brute force corvette fuel pump
brute force750 fuel pump swap
changing fuel pump on 2008 corvette
fuel pump swap 2008 corvette
how to replace fuel pump 82 corvette
will a raptor 700 fuel pump work in a 08 brute force 750
You may not post new threads
You may not post replies
Fuel Pump wehde Kawasaki Brute Force/Prairie/Bayou 8 06-11-2009 07:01 PM
Electric fuel pump mod for Brute 650's with vacuum fuel pump VFORCEJOHN Interstate Motorsports 0 04-14-2009 01:21 PM
Anyone need a fuel pump mudman0000 For Sale 2 01-23-2008 03:46 PM
fuel tank and fuel pump gomerkfx700 Kawasaki KFX700 V-Force 4 03-04-2007 08:22 PM
Fuel Pump shotgun Kawasaki KFX700 V-Force 15 07-19-2005 05:06 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
