Mud Issues?
This is a discussion on Mud Issues? within the Kawasaki Brute Force/Prairie/Bayou forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; I am a new 09 750i owner and wanted to see if there are any areas on my atv that are likely to let in ...
Old 03-23-2010, 02:10 AM   #1
Poolege's Avatar
View Poolege's Photo Gallery(4)
Smile Mud Issues?
I am a new 09 750i owner and wanted to see if there are any areas on my atv that are likely to let in mud or muddy water when playing in the mud. I was stuck in a 2ft hole two days after I purchased the atv for 20 minutes or so. I ended up pinning gravel between both the rear wheels and hubs which punctured both rear rims and bent the rotors on the front. I just wanted to see if there are any other problems I may not be able to see before I take it out again. Also, if there are any sites I could find rotors for less than $80 a rotor?
I found this site a few days ago and just joined. It seems to be a great place with allot of helpful members.
Thanks for any info,
George
Poolege is offline   Reply With Quote
Old 03-23-2010, 02:21 AM   #2
Feedback Score: 2 reviews
RANDALLPINK7's Avatar
View RANDALLPINK7's Photo Gallery(0)
Default
i feel for you, i recently punctured one of my rims on my brute as well. good thing ITP has a life time warrentee. other than that, i dont know dude, mines an 05 so i dont know how your EFI works. i will say they have weak ass tie rods and ends. ive bent several till i upgraded to Venforcers rods and ends (look him up, he sales them on here.
plus if you like playing in the mud, get rid of them junk ass stock tires
2005 KFX 700
AMR 840, PORT AND POLISH, +4 VALVES, XXX cams BOONDOCKER NOS, 38mm Carbs with Custom Intakes, VENFORCER +4 EXTENSION, drag pipe, VFJ STAGE 3 WITH SECONDARY, K&N, MARVIN SHAW HILL SHOOTER'S FRONT AND REAR, FRONT LOWERING, O/B SPRING WITH WEIGHTS, DYNATECH CDI, 25 x 11 x 10 SKAT TRACK RIPPERS
04 KFX 400
440 BIG BORE KIT,13.5-1 wiseco, DYNATECH CDI, K&N, LRD EXHAUST, K&N AIR BOX LID, Fasst Flexx bars, ODI grips, 450R front shocks
06 BRUTE FORCE 750i
2 INCH LIFT snorkeled, 28 in. Mudzilla TIRES
ITP SS112 12X7 rims, dynatek cdi, K&N AIR FILTER
KFX 80
WHO KNOWS
2008 TERYX
27 in. Mud Lites, 2 inch lift, Team Green plastics, ITP SS212's
RANDALLPINK7 is offline   Reply With Quote
Old 03-23-2010, 03:05 AM   #3
redlined's Avatar
View redlined's Photo Gallery(0)
Default
George
Welcome!
If you hadn't done so already, you might want to think about an EHS mudder lid, with the stock intake plugged up. Never had it happen to me, but if you do a little research, you'll find all kinds of issues about water in the airbox......
redlined is offline   Reply With Quote
Old 03-24-2010, 11:08 AM   #4
bfb650b2's Avatar
View bfb650b2's Photo Gallery(0)
Default
Here in NM, deep mud or even water is not a issue but we do have Mountain streams to cross and at different times of the year they can be deep. In the past I always slowed down for the crossings but not since I have installed the EHS Mudder lid. With the stock air-intake blocked off I can now charge through the crossings w/o any more water-intake problems.
Air intake noise isn't too loud either with this EHS Mudder Lid, a little bit more than stock but I find it to be a sweet sounding Brute.
'09 Team Green BF750FI
Eagle Eye HID's
Direction2 Overfenders
ELKA R/S Stage 3 Shocks w/piggyback res'es
Precision Racing Steering Stabilizer
Ramsey wireless 2500# Winch
Ricochets Belly Plates
Aluminum Products A/Arm guards
Highlifter Front Bumper
CHUCK750 HDPE Footwell SKIDs
H
ydraulic-Line/Oil Cooler
HunterWorks Radiator Cooling Fan Upgrade
MSA M9 whls/26" ITP Terra-Cross XD Radials
Prothane Line sway-bar Bushing upgrade
Powermadd Handguards
EHS Mudder Lid
AMStar Pro tie rods/ends
PBR Dif-loc Button
Trailtech Voyager GPS
Contour 1080P Helmet Cam
bfb650b2 is offline   Reply With Quote
Old 03-24-2010, 09:39 PM   #5
Poolege's Avatar
Default
I like the lid but the price seems a little high. I might just go with a snorkle setup. Seems that will only cost a little more. What about the differentials and oil? Any places I should look out for?
Thanks,
George
Old 03-25-2010, 09:28 AM   #6
redlined's Avatar
Default
Thanks,
George
Front diff takes same oil as the engine, whatever you've chosen. The rear diff takes a tractor fluid...mobil 424 or something similar. I use Amsoil everywhere.....just my preference......be careful when filling, they will seemingly "top-off" and then recede, quite a few times before actually being full......
Old 03-25-2010, 10:31 AM   #7
View brute650i's Photo Gallery(0)
Default
If your looking for more of a midding site mudinmyblood has a lot of good info but this place is for sure the best for performance upgrades
2006 FCP Brute Force 801
dynatek cdi
full big gun
nitrous wet kit
stock clutching for now but working on it
brute650i is offline   Reply With Quote
Old 03-25-2010, 06:57 PM   #8
bfb650b2's Avatar
Default
True, the EHS Mudder lid is not cheap in cost but again it is not a cheapy built air-intake Lid. Allot of work went into the design, the welding and stainless steel bolts and a new air-cleaner lid or you can use your own Lid and install the parts yourself.
Eagle Eye HID's
H
EHS Mudder Lid
PBR Dif-loc Button
Old 03-25-2010, 09:29 PM   #9
Poolege's Avatar
Default
It looks very well made/designed and I could see paying up to $100 but for what they go for a snorkel seems to be a better deal with a little more security. Some say the snorkel breaths better also. I'll most likely go with a good snorkel sometime soon. Right now I'm looking at radios to mount to the front rack. lol I'm leaning toward the tube type so I will be able to fit the snorkel but I'm not sure if it'll be loud enough.
Thanks,
George
Old 03-26-2010, 12:29 PM   #10
View BudManJr89's Photo Gallery(0) Send a message via Skype™ to BudManJr89
Default
Something else you may want to think about is relocating the Radiator to your top rack. This is something alot of people do with the big CC engines. I have a 06 650 & have several overheating issues due to the radiator clogged up with mudd after taking if deep.
BudManJr89 is offline   Reply With Quote
atv playing in mud
atv steering problems after deep mud
steering issues with brute force
You may not post new threads
You may not post replies
Snorkle issues! Big BP Kawasaki Brute Force/Prairie/Bayou 1 07-15-2009 05:12 AM
08 750 EFI issues - HELP! Kevin Kawasaki Brute Force/Prairie/Bayou 1 06-22-2009 02:53 PM
Issues flipper News/Support/Feedback 13 05-29-2009 03:03 PM
efi issues redheadedstranger Kawasaki Brute Force/Prairie/Bayou 7 04-06-2009 05:08 PM
GAS ISSUES BILLY HOSCH Kawasaki KFX700 V-Force 12 09-07-2007 02:15 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
