87 KLF300 Timing issue - Kawasaki ATV Forum
post #1 of 4 Old 03-23-2010, 12:58 PM Thread Starter
I just bored out my 87 Bayou 300 .020 over and installed a new oversized piston and had the valves vacuum checked. With everything back together and after setting timing and cleaning carb I am having a problem with it trying to start. When the engine turns over it will pop as if it is trying to fire off but will not run. I have about 125lb compression I have fire and I sprayed fuel in carb with these it should at least try to run. The only thing I can think of is a timing issue. I have lined the cam sprocket up with klf300 and set accordingly to the to the T mark on the alternator rotor. I have taken it off and double checked it twice I have even set it one camchain link forward and then aft of the correct Top setting at the camsprocket. I have set the valves to spec. When I turn the engine over by hand the valves open and close like they should at the right interval and the piston is at top dead center when aligned with the T mark and cam sprocket are in there right positions. Can I use a timing light when I try to start the engine and check for correct timing? I read something about a timing advance not sure how that works. Is there a sure way to check exactly when the engine fires?
bdl1801 is offline
post #2 of 4 Old 03-23-2010, 04:56 PM
What condition were the guides in. If worn they can throw the timing, should have no ridges or grooves. How about the tensioner? Did you set that up right? Harbour Freight sells a spark checker for cheap that takes the place of the plug, has a light that flashes with ignition. Be careful with cranking it with the wire off you can toast the igniter that way. Wish I was more help. You might want to post here to. Kawasaki Motorcycle Forums
Jim
foot0069 is offline
post #3 of 4 Old 03-24-2010, 05:15 PM
Just read a similar question posted today. Reminded the poster that the motor had to be on the compresion stroke. Was yours?
Jim
foot0069 is offline
post #4 of 4 Old 03-25-2010, 10:26 AM Thread Starter
I just ohm tested the ignition unit and found it did not meet spec. I figured with a bad ignition unit I would not have spark at all but I have spark. What exactly does this Ignition unit do?
bdl1801 is offline
Is there an issue????? flipper News/Support/Feedback 5 03-17-2010 08:15 PM
09 750 Oil Issue mwmorris88 Kawasaki Brute Force/Prairie/Bayou 1 01-01-2010 09:24 PM
4wd issue with dg6 vtprairie03 Kawasaki Brute Force/Prairie/Bayou 3 07-26-2009 06:30 PM
itunes issue. asnowmobiler Club Kawie 15 04-04-2009 09:38 AM
08 issue Twisted10 Kawasaki Brute Force/Prairie/Bayou 11 01-12-2009 05:16 AM
