smoking - Kawasaki ATV Forum
post #1 of 8 Old 04-29-2010, 11:59 AM Thread Starter
smoking
My 650 recently started smoking when i start and it continues to smoke until it is warm.I am going on a limb and say it's valve seals.Oh yeah and the smoke is oil.
leearchibald is offline
post #2 of 8 Old 04-29-2010, 04:01 PM
blue brute's Avatar
does it smoke if it sits at an idle for a while or just when you start it
08 brute 650i HMF slip/jet kit,Moose mod,K&N,Outerwears pre filter,EPI marron primary and almond second,27" ITP mud light XTR, temp gauge, 4000lb Viper Max winch, Loud Vision head light eye brows, Highlifter pen lock,1.5" wheel spacers, Kujo control arm bushings
blue brute is offline
post #3 of 8 Old 04-29-2010, 04:11 PM Thread Starter
just when you start and until it gets to running temp.
post #4 of 8 Old 04-29-2010, 04:48 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Quote:
Sounds like the oil rings are getting weak.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is online now
post #5 of 8 Old 04-29-2010, 05:20 PM
rednutbow's Avatar
If it goes away when it warms up you are right in thinking valve stem seals. When the seals warm up they swell, not allowing oil to pass as freely as when cold.
2008 Poot force with some AMR lovin...
Put together by ME, With of help from:
STEVES ATV of Katy, Texas. (Houston Area)
http://www.stevesatv.net
rednutbow is offline
post #6 of 8 Old 04-29-2010, 06:01 PM Thread Starter
i thought it was oil seals but just checking,i doubt it is oil rings for i just did both cylinders but i never did the valve seals.
post #7 of 8 Old 04-30-2010, 02:56 AM
NovaKaw650's Avatar
You could be right, but in my experience with bad valve seals, oil would leak into the cylinders when the engine was shut down, and burn off within the first 5-10 seconds.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #8 of 8 Old 04-30-2010, 06:09 AM
Feedback Score: 1 reviews
Leaking valve seals will also make it smoke on decel cause it is pulling oil past the seals
Hunterworks is offline
08 brute force rad smoking
2007 kawasaki brute force 650 engine smoking
2008 brute force 750 smokes a little on start up
brute force 650 smoking
brute force smokes
brute force smoking
burte force smokes till warm
can the valves being off make a brute force smoke#gsc.tab
kawasaki 650 brute force smokes
kawasaki 650 brute force smoking
kawasaki brute force smoking
my 650 brute force smokes
what would cause my 06 kawasaki 750 brute force to start smoking all the sudden
smoking 650i kdogg1804 Kawasaki Brute Force/Prairie/Bayou 3 01-10-2010 04:11 PM
Teryx Smoking Kaw Kaw 650 Kawasaki Teryx 15 08-06-2008 10:04 PM
T-4 smoking me out lonnie Kawasaki Tecate 1 01-28-2008 08:38 PM
V Force smoking? vforceracer800 Kawasaki KFX700 V-Force 3 07-03-2004 07:53 PM
