Old 05-02-2010, 11:25 AM   #1
Linski's Avatar
View Linski's Photo Gallery(0)
Default Changing Rear Oil Seal
Gentlemen, I need to change the rear oil seal in my 2009 Brute 750, question is, how hard is it to do myself? And how do I go about doing it in steps? Thank you for your help.
Linsk
2009 Brute Force 750 4x4i CAMO
14" M7's with 27" SWAMPlites
K&N Air
ALL BALLS TIErods
Powermadd Handguards
Warn R/T30
Full Synthetic
H&T warmers
Saw Clamp
Linski is offline   Reply With Quote
Old 05-02-2010, 01:24 PM   #2
Feedback Score: 1 reviews
View Hunterworks's Photo Gallery(0)
Default
Unless it is pouring leave it, they all seep
Hunterworks is offline   Reply With Quote
Old 05-02-2010, 01:43 PM   #3
View yugoboss's Photo Gallery(0)
Default
Drain the oil, pull the driveshaft out with your hands, it compresses in the middle. I
found the easiest way to remove the seal is drill a small pilot hole in it, find a self tapping wafer scew, im sure others will work. Scew it in the hole you drilled, then us a
prybar and pop it out. Install just lightly tap the new seal in til its flush.
yugoboss is offline   Reply With Quote
Old 05-02-2010, 01:48 PM   #4
Default
What he said but expect the new one to seep too. Also put some grease on the lips of the seal, the sealing part not around outside
Old 05-02-2010, 02:25 PM   #5
Linski's Avatar
Default
Well thats usefull information boys thanks....I just didnt know if you had to take apart the u joint or not. I might leave it for now I have a mud run coming up this weekend. Mine hasnt leaked up until now and sitting in the garage there are oil spots. I will change it eventually, nobody likes a bike leaking oil. I can see the new one seeping hopefully not leaking.
K&N Air
ALL BALLS TIErods
Warn R/T30
Full Synthetic
H&T warmers
Saw Clamp
how to change a rear engine seal in a 2010 kawasaki teryx
how to change front and rear seals on atv
how to change rear engine seal on 2008 750
how to change rear main seal on 2008 kawasaki teryx 750
how to fix rear seal on teryx
how to install oil seal teryx
how to remove oil seal on kawasaki engine
how to replace teryx rear main seal
instructions to change rear seal kawasaki
kawasaki teryx oil seal
kawasaki teryx rear oil seal
o8 teryx rear oil seal part number
teryx transmission seal
You may not post new threads
You may not post replies
Changing rear fluid in BF 750 pfbtyson Kawasaki Brute Force/Prairie/Bayou 3 01-06-2010 04:30 PM
rear seal fix badbrute750i Kawasaki Brute Force/Prairie/Bayou 4 06-15-2009 03:28 PM
Changing rear diff fluid rotty Kawasaki KFX700 V-Force 21 02-18-2009 08:55 PM
Changing Rear Hubs SilverBulletKY Kawasaki KFX700 V-Force 7 04-13-2008 08:40 PM
Changing the rear sproket vt700guy Kawasaki Tecate 8 03-05-2007 05:55 PM
