water in motor - Kawasaki ATV Forum
post #1 of 5 Old 05-23-2010, 05:47 PM Thread Starter
water in motor
i just bought an 06 650 brute force this week and had it on the may mud run and it worked great. after playing in the mud all day the rad was packed full and i never noticed the heat light on the dash flashing untill i was almost home. so we stopped at a lake and were going to wash some of the mud out of the rad but i found a deep spot and the bike got a drink of water. it quit immediatly and we pulled it back. i just took it aprt today to drain the oil, belt case, and blow the water out of the cylinders. i checked the compression and it was about 75 to 80 psi in both cylinders. i was just wondering what the best way continue is. i've never drowned a bike before so i'm new with this. is there any special about the brute forces that i should know before i try to start it back up
thanks
hoyt351w is offline
post #2 of 5 Old 05-23-2010, 06:58 PM
Feedback Score: 1 reviews
Compression is going to be low because of the decompression mechanisms, in a 750 45 to 60 is acceptable
Hunterworks is offline
post #3 of 5 Old 05-24-2010, 01:03 PM
blue brute's Avatar
keep an eye on your oil it might be milky for a while depending on how much it drank, so buy a bunch of cheap oil and keep flushing the motor untill it looks normal again
08 brute 650i HMF slip/jet kit,Moose mod,K&N,Outerwears pre filter,EPI marron primary and almond second,27" ITP mud light XTR, temp gauge, 4000lb Viper Max winch, Loud Vision head light eye brows, Highlifter pen lock,1.5" wheel spacers, Kujo control arm bushings
blue brute is offline
post #4 of 5 Old 05-25-2010, 01:32 PM
Thumbs up
Drain the oil at least 4 times with transmission fluid(oil) and a cheap grade engine oil mixture while starting it for 15 secs between changes. 5th time change oil filter at same time and then use your regular 5-30w synthetic. Take plugs out and squirt transmission fluid down them and crank at same time.( oil Transmission oil acts like a detergent, helps clean). The bike will still smoke for approx a couple of mile then clear up.
Gussy is offline
post #5 of 5 Old 05-25-2010, 02:24 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Do a search; this has been covered many, many times and there are several good methods to remove the water. Also keep in mind that if the water was dirty, then the carbs are full of dirt and will need to be removed, disassembled and cleaned.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is online now
atv water engine never quit
brute engine quit with water
brute force water in motor
engine oil milky flush filter bayou
transmission fluid brute force 650i
Whats it take to make a Vforce motor a Brute/Prairie motor? BANDAMAN Kawasaki Brute Force/Prairie/Bayou 5 01-10-2010 03:55 PM
gas smell and motor died when i went into water Shumate650 Kawasaki Brute Force/Prairie/Bayou 4 11-04-2009 09:21 PM
Testing the water in a fst 840 motor for sale painterx For Sale 7 07-16-2008 10:19 AM
2006 brute with locked up motor..ate lots of water.. sdteb Kawasaki Brute Force/Prairie/Bayou 5 02-26-2007 06:02 AM
water in motor pop Kawasaki KFX700 V-Force 4 05-20-2004 08:03 AM
