05 brute 750 - sudden loss of power then oil in air filter box - Kawasaki ATV Forum
post #1 of 8 Old 05-24-2010, 10:56 PM Thread Starter
Unhappy 05 brute 750 - sudden loss of power then oil in air filter box
Hello everyone I just bought a used 2005 brute 750. I did a service on it (changed all fluids, new plugs, cleaned carbs, air filter and box). I took it out for its first ride. Went out for about an hour and everything worked well (lots of power) and seemed fine. The next day I went out again. About a half hour into the ride and was driving on a flat road at about 50 km/h when I suddenly lost power and heard a rattling from the engine. When the quad came to a stop I tried to start it again and fired right back up. When I went to take off again, I had a very noticeable drop in power, to the point I could barely get it over 45 km/h. I stopped and looked inside the air filter box. Still dry and clean.
So knowing that something wasn't right I turned around and headed home. By the time i got home I had oil running down the outside of the airbox and side panels. I opened the airbox and there was a significant amount of oil inside.
It is a stock brute. I have some mechanical background and owned dirt bikes all my life but this is my first quad and I am not too familiar with ATV's.
PGBrute
PGbrute is offline
post #2 of 8 Old 05-25-2010, 06:12 AM
Feedback Score: 1 reviews
PGBrute
Very common for the Brute to push oil into the airbox
Hunterworks is offline
post #3 of 8 Old 05-25-2010, 06:30 AM
monsterbrute750's Avatar
It is common for the brute to push oil in the airbox.But combined with the power loss you are experiencing there could be a problem.That happened to me on my '05.Followed by loss of power and what sounded like an exhaust leak on the header.Turned out the top end blew.
2008 Brute Force 750i EFI
28x11x14 Zillas
RDC 2" Lift
Full Muzzy System
Highlifter Radiator
MIMB Snorkels
Team Monster Energy Kawasaki Graphics
Backrest
Custom Beer Cooler
Custom stephen189 ass kicker Bore
monsterbrute750 is offline
post #4 of 8 Old 05-25-2010, 11:47 AM Thread Starter
Dealer comments
I spoke with the dealer and he felt I could have got something in one of the carb causing it to flood. Which would explain the loss of power ( like it having the choke stuck open). and I seem to have used a large amount of fuel to get home as well. But I don't understand how that would cause the increased crankcase pressure to increase and push oil to the air box?
PGbrute
PGbrute is offline
post #5 of 8 Old 05-25-2010, 11:54 AM
Feedback Score: 3 reviews
rdm531's Avatar
sounds like compression problem to me, how many hrs on this bike, how long did it sit if any before you got it, has it ever been sunk? i would do a compression test, just my thoughts
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #6 of 8 Old 05-27-2010, 03:27 PM Thread Starter
Update
I did a compression test. Got a zero reading on the front cylinder and there was evidence of damage to the spark plug. ..... Not good. I am currently in the process of removing the head. I will let you know what I find.
PG Brute
PGbrute is offline
post #7 of 8 Old 05-30-2010, 10:21 PM Thread Starter
mystery solved
Well after getting the heads off, it turned out to be a broken exhaust valve. Not sure how the heck that can happen. But oh well. I am going to replace the top end while I have it apart.
PG Brute
PGbrute is offline
post #8 of 8 Old 05-30-2010, 10:29 PM
Likely your valves tightened up and broke. Make sure you recheck your vavle clearance all the way around when you're done.
Smokey is offline
Tags
2005, 750, brute, loss of power, oil in airfilter
2005 kawasaki brute force 750 oil on air filter
2005 kawasaki brute force 750 was riding and lost power
750 brute force car lost power while driving
atv loss of power since new air filter
brute force 2005 oil in my air filter
brute force 750 air filter
how did my 08 brute force 650 all the sudden loose compression
how did my 08 brute force 650 lose compression all the sudden
kawasaki brute force losing power while driving
kawasaki oil in air filter
oil in air filter 2008 brute
what would lose power while driving your four wheeler
y is my 09 brute force blown all my oil in to the air box
2008 Brute loss of power Stroker 5440 Kawasaki Brute Force/Prairie/Bayou 6 05-08-2010 11:22 PM
Brute Force 750 power loss Hackdawg13 Kawasaki Brute Force/Prairie/Bayou 2 02-15-2010 11:07 PM
06 Brute Force 750i power loss to 1 wheel Please help! jspring0033 Kawasaki Brute Force/Prairie/Bayou 16 08-30-2009 09:35 PM
brute power loss Hog Kawasaki Brute Force/Prairie/Bayou 2 08-01-2009 09:35 PM
Sudden Loss of Oil Pressure cluelessrookie Kawasaki KFX700 V-Force 7 05-06-2008 04:51 PM
