water pump oil seal - Kawasaki ATV Forum
post #1 of 12 Old 06-14-2010, 08:10 PM Thread Starter
BRICKLAYER's Avatar
water pump oil seal
we were putting a new gasket on my friends 650 brute water pump and we noticed the oil seal behind the impeller was cracked. we pulled it out and cant seem to get the new one to set in there like the old one did it just slides in but wont stay. its got two little notches in it is it supposed to compress the spring and then turn to lock it or do you just drop it in and put the impeller back on?
thanks
2005 Brute Force 820 SUNBEAM RED
JE 820 PISTONS
WEBB CAMS
MUZZY PRO
AMBER PRIMARY
RED SECONDARY
K&N FILTER
GORILLA RAD RELOCATE
MIMB SNORKELS
HL 2" LIFT
28" MUDZILLAS
COPPERHEAD CDI
MAXXIS MAXLITE RIMS
2.5" CUSTOM WHEEL SPACERS
BRICKLAYER is offline
post #2 of 12 Old 06-14-2010, 08:24 PM
Feedback Score: 9 reviews
hndlbarmonkey's Avatar
just pretty much slides on, it should just kinda stick after you pass the 2 notches, you don't turn it though.
Home of the proven fastest and quickest all motor Kawies in the world
Quote:
Originally Posted by Dynoray View Post
Quote:
Originally Posted by hndlbarmonkey View Post
It says race because it was 12.6:1, instead of 11:1
lol, so going from 11:1 to 12.6:1 is building a race motor to you
LOL, back in 04-05, pretty much, LOL
AMR 840 trail bike
Fundy 800 race motored trail bike<wifes
Fundy 800 drag bike
It's nice when you get to a point, where you don't give a shit anymore
hndlbarmonkey is offline
post #3 of 12 Old 06-14-2010, 08:50 PM Thread Starter
BRICKLAYER's Avatar
can i just put a socket over it and press it down?.
JE 820 PISTONS
WEBB CAMS
MUZZY PRO
AMBER PRIMARY
RED SECONDARY
K&N FILTER
MIMB SNORKELS
HL 2" LIFT
28" MUDZILLAS
COPPERHEAD CDI
MAXXIS MAXLITE RIMS
post #4 of 12 Old 06-14-2010, 09:03 PM
just line up the notches on the seal with the two on the piece sticking up and it should just pretty much slip right on. The notches just hold it on for assembly purposes, once you put the impeller on it pushes down on the seal
AMR 840 trail bike
Fundy 800 drag bike
post #5 of 12 Old 06-14-2010, 09:08 PM Thread Starter
BRICKLAYER's Avatar
ok cause it was real hard to pull out. and its kind of a spring in behind it. so i just put it in place loose and screw the impeller back on and it will seat the seal. cause right now i can just turn the cover upside down and the seal falls right out. is this right?
JE 820 PISTONS
WEBB CAMS
MUZZY PRO
AMBER PRIMARY
RED SECONDARY
K&N FILTER
MIMB SNORKELS
HL 2" LIFT
28" MUDZILLAS
COPPERHEAD CDI
MAXXIS MAXLITE RIMS
post #6 of 12 Old 06-14-2010, 09:52 PM
Feedback Score: 1 reviews
The spring thing is part of the seal, if you have them separated, not good
Hunterworks is offline
post #7 of 12 Old 06-15-2010, 02:23 PM Thread Starter
BRICKLAYER's Avatar
cool. i didnt seperate the spring from the seal its still together. how will i know if i installed it right, will oil or coolent leak somewhere? and quick question does anybody know the part number for the little breather that is connected to it?
JE 820 PISTONS
WEBB CAMS
MUZZY PRO
AMBER PRIMARY
RED SECONDARY
K&N FILTER
MIMB SNORKELS
HL 2" LIFT
28" MUDZILLAS
COPPERHEAD CDI
MAXXIS MAXLITE RIMS
post #8 of 12 Old 06-15-2010, 05:06 PM
Feedback Score: 8 reviews
asnowmobiler's Avatar
I'm not sure which one you talking about.
There are three seals.
Starting from the inside.
Oil seal
Mechanical seal.
And the one on the backside of the impeller.
The Mechanical one has the spring that pushes against the impeller seal. It has a pressed fit,and needs to be pressed in or knocked into place with a large socket.
To replace the inner oil seal,the side cover should be removed.
The impeller seal,just needs to be pushed in with your fingers.
None of them should fall out,unless there is another problem.
Officiallywas one of the fastest Prairies in the world
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,AMR ported intakes,programmable Dyna,30 shot of Boon,Brute Force Flywheel,stock carbs,stock exhaust,Flexx bars,Rox Risers,ODI grips,Tusk Dozer plow,ECT.
AMR 330 347 6800
2013 BMW K1600GT
2015 BMW R1200 GS Adventure.
asnowmobiler is offline
post #9 of 12 Old 06-15-2010, 08:46 PM Thread Starter
BRICKLAYER's Avatar
its only the mechanical seal i have to put in the little black plastic ring on the outside of it was cracked and fell of when i took the impeller off. so i pulled the whole mech seal out with visegrips. i got a new one so to get it in i gotta bang it in with a socket or press it in im getting a little confused here
JE 820 PISTONS
WEBB CAMS
MUZZY PRO
AMBER PRIMARY
RED SECONDARY
K&N FILTER
MIMB SNORKELS
HL 2" LIFT
28" MUDZILLAS
COPPERHEAD CDI
MAXXIS MAXLITE RIMS
post #10 of 12 Old 06-15-2010, 08:52 PM
Quote:
yes just press it in, you are talking about the spring loaded seal, if it's new it has a little blue sealer around where it goes into the cover....use a socket or whatever that fits over the guts and just pushes on the metal body
AMR 840 trail bike
Fundy 800 drag bike
2005 brute force 750i water pump seal
2005 bruteforce 750 waterpumps
bmw gs 650 water pump replacement
brute force 650 water pump
brute force 750 water pump seal
brute force water pump seal assembly
brute force water pump seal removal
how to install waterpump seal on a kawasaki 750 brute force
kawasaki prairie 650 water pump seal
kawieriders oil water pump
oil seal leaking on water pump shaft brute force 75
prairie 650 water pump impeller
water pump for 2005 brute force
replacing the mechanical seal on the water pump GreenSubmarine Kawasaki Brute Force/Prairie/Bayou 54 07-19-2014 09:34 PM
oil pump/water pump shaft seal kyblev Kawasaki Brute Force/Prairie/Bayou 1 03-31-2010 09:13 AM
water pump seal question bentone Kawasaki KFX700 V-Force 0 02-06-2010 05:29 PM
Water pump bearing and seal rsnyder1976 Kawasaki Brute Force/Prairie/Bayou 4 12-19-2009 01:16 PM
looking for a mechanical water pump seal for a v badasskfx Wanted 10 09-01-2009 02:00 PM
