Engine Noise Help! - Kawasaki ATV Forum
post #1 of 8 Old 06-23-2010, 10:31 PM Thread Starter
Engine Noise Help!
Got a strange ticking noise... here's what happens...
When the quad is cold it starts up clean and sounds great...runs great and the engine sounds good. After about 10mins when it start to warm up all of a sudden I hear a ticking noise (it's actually a little louder than a tick but not as loud as a knock). It does not go away when revving up the motor and just stays ticking during idle. The ATV is a 1993 Bayou 300, it runs great otherwise, no loss of power... just trying to figure out what this is so that I can remedy. Could it be some kind of timing issue or maybe an oil-pump failure of some sort. Any help is much appreciate!
mguned is offline
post #2 of 8 Old 06-24-2010, 05:27 AM
Shumate650's Avatar
Have you checked your valve clearance? That could be causing the ticking noise you are describing.
2008 Brute Force SRA
VFJ Stage 3 clutch, EPI pink primary and VFJ #4 secondary springs, Dynatek, spark plug boot mod, Crossover intakes, polished slides, shimmed needles, #42 pilots, #140 mains, TRP water pump, Faria temp gauge, Napa hose mod, Twin Air power flow kit, Elka front spring kit, Elka Stage 3 rear, Fasst Flex handlebars, Rox risers and dash, ODI grips, Streamline steering stabilizer, PRM grab bar, aluminum skids, Renegade footpegs, Black Rock wheels, Kenda Bear Claw HTR's
Shumate650 is offline
post #3 of 8 Old 06-24-2010, 09:39 AM Thread Starter
Thanks for the reply. Is this something that might occur only after it warms up? I am going to work on it over the weekend, if anyone else has any other suggestions on what I might look for please let me know. Thanks in advance for the advice...
mguned is offline
post #4 of 8 Old 06-24-2010, 11:07 PM
i have the same issues... but i have a 750 brute...
bustamove is offline
post #5 of 8 Old 06-25-2010, 11:19 AM Thread Starter
I spoke with an local ATV mechanic yesterday and he said the same thing that Shumate650 mentioned...that it probably needs a valve adjustment. He said that it is common and is fairly easy to do. Hopefully this is the case... if anyone has any other suggestions let me know... I will post more when I start the work... thanks!
mguned is offline
post #6 of 8 Old 06-25-2010, 11:43 PM Thread Starter
Does anyone have the valve clearance specs for a 1993 Bayou 300 2WD?
Thanks!
mguned is offline
post #7 of 8 Old 06-26-2010, 02:53 PM
Feedback Score: 2 reviews
canada's t4's Avatar
intake is .004-.006 and exhaust is .006-.008 right out of the book best bet is to remove front fenders for this makes it soo much easier
`2005 bruteforce 750i
26 inch mudlites
moose power module
passenger seat
warn winch
fairing
muzzy pro
`1996 ski doo formula 3 600 triple(AKA the purple screamer)
`2006 brutefore 650i( getting complete rebuild from frame up)
canada's t4 is offline
post #8 of 8 Old 06-26-2010, 10:01 PM Thread Starter
Thanks for the info... We checked the valve clearance and found the intake a little tight, but overall they were good. A buddy of mine assisted and checked out the noise... he attributed it to "a little piston slap" and said not to worry too much about it... So off I go riding...
Thanks to everyone for the info...
mguned is offline
01 bayou 220 engine noise
1993 kawasaki bayou timing noise
1993 kawasaki klf 300 bayou engine knock
300 bayou kawasaki ticking sound when running
300kawasaki bayou vavle niose
bayou 300 ticking
how to adjust the clutch on a 1993 kawasaki bayou 300 4x4
how to adjust valves on kawasaki bayou 300
i have a kawasaki 300 with a clatter in the engine when warmed up,what is it
kawasaki bayou 300 ticking
kawasaki bayou 400 engine noise
kawie 300 bayou ticking noise
what would cause a 2005 750 brute force to loose power and have a knock in engine
05 bf 750 engine noise wjw11teen Kawasaki Brute Force/Prairie/Bayou 2 10-21-2009 06:00 PM
Ticking noise from the engine asnowmobiler Kawasaki KFX700 V-Force 42 05-29-2008 01:22 PM
KFX 400 engine noise k-fairatv Kawasaki KFX450/KFX400 1 01-09-2008 08:29 AM
Engine noise when hot 650twin Kawasaki Brute Force/Prairie/Bayou 10 12-03-2007 02:57 AM
Engine noise? desdak4 Kawasaki KFX700 V-Force 2 12-23-2003 02:28 PM
