09 Brute Force 750i Problems, NEED HELP! - Kawasaki ATV Forum
post #1 of 8 Old 07-16-2010, 04:43 PM Thread Starter
Alright, lets start out with hi my name is AL and im new to this ATV thing..... I just bought a used 09 brute force 750i from a dealer that was a trade in, it has 250 mile and 41hrs. I took this machine out twice to the same trail and it seem like it was good, But the second time i took this machine out it stalled on me going up and down a steep hill... I read the post about adjusting the idle(will try when I have the correct tool).
2. The smell coming from my exhaust smells like fuel, my buddy that was riding behind me said it smells rich?
3. I took the cover for the air filter off, just to look at it and i notice it had oil mixed with water on my filter why is that?(I cleaned my filter out)
4. I also saw that i have oil on my engine so i checked my dipstick and the oil was fine, is that normal?
P.S. My friend told me to throw in some fuel injection cleaner in with some dry gas for the stalling, he said that might work. and he couldn't answer about the exhaust smelling rich.
Any help will be perfect thank you... sorry for the long post.
hateonhaters is offline
post #2 of 8 Old 07-16-2010, 07:16 PM
Feedback Score: 1 reviews
monsterbrute750's Avatar
I've never had a stalling problem.
You might be having a FI problem with the stalling and smell of gas.
The oil and water on your filter could be from the dealer cleaning it and not letting it dry b4 reinstalling it.
You say you have oil on your engine,where?
I only run super unleaded in mine.
2008 Brute Force 750i EFI
28x11x14 Zillas
RDC 2" Lift
Full Muzzy System
Highlifter Radiator
MIMB Snorkels
Team Monster Energy Kawasaki Graphics
Backrest
Custom Beer Cooler
Custom stephen189 ass kicker Bore
monsterbrute750 is offline
post #3 of 8 Old 07-21-2010, 03:42 PM Thread Starter
Sorry im not a machanic but the oil on the engine, u can see it from the side where the rear brake foot pedal is.
post #4 of 8 Old 07-21-2010, 04:16 PM
Feedback Score: 2 reviews
bfb650b2's Avatar
A tach hooked up will tell you if it is at the correct idle adjustment.
The engine oil level is suppose to be between the high and low mark on the dip stick. If the engine is overfilled you will get blow-out of oil.
Water on the air filter could be coming from the air-intake, poor location on this Brute, others install snorkels if riding in water.
If you bought it from the Dealer, then the Dealer needs to be sure it is set-up correctly, the dealer should correct it if it wasn't set up correctly the frist time.
You stated everything seemed fine the 1st ride, did you do anything to the Brute on the 2nd ride, like add engine oil, ride thru deep water.
If the air-filter is dirty or has water in it, the Brute will stall.
2012 BF750eps
ELKA Stage 3 Shocks~Grim Reapers:26/9, 26x11x14/ITP SS216's
~Ramsey 2500 Lb Winch~RICOCHET Belly/Floorboard Skid Plates~Teryx LED HeadLights~D2 OverFenders~Kimpex Rear Trunk~Shorai Battery~TrailTech Voyager GPS~Powermadd handguards~
Kawasaki Fender Bags~ContourHD Roam2 HelmetCam.
bfb650b2 is offline
post #5 of 8 Old 07-21-2010, 04:19 PM
Feedback Score: 24 reviews
twyztid's Avatar
I wonder if the fuel is old. I have had experience with two quads that ran like crap until I drained the fuel tank and put new fuel in it. That could possibly give you the gas smell out of the exhaust also if it isn't burning properly.
'04 KFX800
DSC 12:1 Pistons, DSC Stage 2 cams, Ported Heads, 36mm carbs, Muzzy Super Pro, Dual MTX-L A/F Gauges, VFJ Stage 3 Spidermod Clutch & Adj. Weights, +8 Swing Arm, Elka Shocks, Acewell 3200 Tach, CCP Steering Stabilizer, Trail Tech X-bars/Clamp, IMS Kick-up Pegs, IMS Heel Guards, 24" 14-paddle Staggered SLS Extreme paddles, BOSS NOSS 40-shot...
'04 KFX700
FST700 w/ Stage 2 cams, Muzzy Super Pro, 12-hole Airbox Mod, UPP Crossover Intakes, 6* Timing Advance Key, Acewell 3200 Tach, CCP Steering Stabilizer, Trail Tech X-bars/Clamp, DG Heel Guards, IMS Kick-up Pegs, Honda 450R / Elka Rear Shocks, +4 Swing Arm Extension, 24" 9-paddle Skat-Trak Extremes
'04 KFX730
'05 BF730 SRA
twyztid is offline
post #6 of 8 Old 07-21-2010, 09:59 PM
03maxpower's Avatar
also the oil on the engine could be coming out of the airbox it drains out on the motor i almost panic'd when i seen oil on my motor til i seen where it was coming from
1978 atc 70
Teryx 4 LE aztec red
Catvos 3" lift
29.5" terminators
09' brute forcesold!!!
Fst 840 stg II cams
03maxpower is offline
post #7 of 8 Old 07-21-2010, 10:18 PM
painterx's Avatar
Quote:
very true
painterx is offline
post #8 of 8 Old 07-22-2010, 03:11 PM Thread Starter
The only thing I did different was ran thru deep water. as to the oil fiter yes it was dirty with oil mix with water i since cleaned that out.... I just put fresh fuel so we will see what happens next........... I also pressure washed my quad including the engine and i drained my over flow tubes which were pluged. is that the same 4 u guys also, the overflow has a plug in it?
09 brute 750 common issues
09 brute force 750 problems
2008 kawasaki brute force blow raw fuel out of the exhaust
2009 brute force 750 problems
2009 kawasaki brute force 750 problems
2010 brute force 750 problems
adjusting idle on a fuel injected brute force
brute force 750i problems
kawasaki 750i problems forums
kawasaki brute force 750 engine problems
kawasaki brute force problems
Brute force 750i oil change Naglinn Kawasaki Brute Force/Prairie/Bayou 9 10-04-2012 07:23 AM
Looking at 2007 Brute Force 750I Incindium Kawasaki Brute Force/Prairie/Bayou 0 09-03-2009 07:12 PM
Brute Force 750i for sale.... Mac54 For Sale 13 06-24-2009 01:00 PM
dynatek off of 06 brute force 750I ronnyp For Sale 2 03-23-2008 03:00 PM
my '06 brute force 750i zukitough Member Pictures & Movies 1 02-19-2007 09:56 PM
