07-27-2010, 09:50 PM
#1
4x4 problems will not go into 4wd
Hi i have an 05 brute force 750.
It willnt go into 4wd. when i turn the switch to 4wd the indicator just stays at 2wd and the actuator doesnt move or make noise? i tryed a buddies controler and that didnt work. i put mine is his bike and mines good. manuel say dead controler but its not that. i have not done the BUSS fix yet could this be my problem? side note, i was just have tones of issues with the bike backfireing and missing could these be linked?
what should i be checking???
thanks for all your help!
07-27-2010, 10:51 PM
#2
Fix the BUSS first it will cause all kinds of problems.
05 BRUTE FORCE 750
04 V Force
87 230 quadsport kids
Alcohol Tobacco and Firearms
Who is bringing the chips?
Sounds like a party to me.
07-28-2010, 12:37 AM
#3
The buss connector is a must for 05 and 06, but one more spot to check is the fuse, and fuse box itself they are known to corrode underneath. There is a connector on the bottom of the box that gos bad.
07 BRUTE 750i, 3" MANDRAL BENT SNORKEL, BIG GUN FULL EXH, JETED 160 F 165 R, DG5 & 6* key, VFJ stage 3 spider mod, FULL SKID"S by me, REAR BUMPER by me, 3000 LPS WINCH SYNTHETIC ROPE.
07-28-2010, 05:05 PM
#4
i have the same exact problem with the exact bike. besides ive already done my buss fix and my fuse is fine?!?!? i really need to get this fixed but i dont want to pay alot of money to take it to the dealer to get it worked on
2005 Kawasaki Brute Force 750Loud & Proud!
- 27" ITP 589's
- K&N Air
- HMF Slip-On/Jetted
- CDI Dynatek
- 2" Lift
- 1" Wheel Spacers
- Custom Temp. Gauge
- Red LED 1 Watt Parking Lights
- Elka Suspension
- Full Pro-Armour Skid Plates
"The Difference Between Men & Boys is the Price of Their Toys!"
07-28-2010, 05:06 PM
#5
peterline if you know your buss is working then that has nothing to do with 4x4 but if your buss is broke and need fixing thats your problem
- 27" ITP 589's
- K&N Air
- CDI Dynatek
- 2" Lift
- 1" Wheel Spacers
- Elka Suspension
07-28-2010, 06:25 PM
#6
FINALLY fixed my 4x4 probelm a while back i took the 10w fuse out for the engine brakng put it back in worked right off the bat!
- 27" ITP 589's
- K&N Air
- CDI Dynatek
- 2" Lift
- 1" Wheel Spacers
- Elka Suspension
07-28-2010, 10:59 PM
#7
Yah the fuse itself usually fine, its the connection the fuse plugs into and the connector under that too, on the bottom of the fuse box. So pull the one 10mm bolt off and lift the box up to check that too. Oh and dielectric grease is your friend use it on all of the electrical plugs on the bike. I do this on all of my wheelers including new the ones.
07-29-2010, 07:54 AM
#8
I got mine to work. My buss was already fixed when I checked it. What I did was jacked it up and put it into 4wd started to run the bike at about 4 km hr. Then I taped the front actuator with the end of the screw driver abot the tenth time it clicked in and started to work. Now it is going in and out just fine. Hope this helps someone out.
Thanks for all your ideas
07-31-2010, 09:17 PM
#9
Mine wasnt switching, it was the speed sensor.
07-31-2010, 11:58 PM
#10
Yah the speed sen will do it too. Speaking of the wheeler needs do be rolling around 1mph or so but less then 12mph or so, to switch back in forth. its some safety thing they have.
| Search tags for this page |
02 prairie wont go into 4wd, 2005 kawasaki 700 will not go into four wheel drive, brute force 750 wont go into 4x4, brute force not changing into 4x4, brute force wont go into 4 wheel drive, brute force wont go into 4x4, brute wont lock in four wheel drive, bruteforce won't switch into 4 wheel drive, buteforce dont go into 4 wheel drive, kawasaki teryx 4x4 not working fuse, my brute force wont go in 4 wheel drive, prairie 650 4wd probs, where is the 4wd fuse brute force
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
» Site Navigation |
» » Other Sites
