Carb Question
Ok I'm having a small issue that I can't figure out.. After tuning my bike and getting the a/f right it doesn't want to idle very good.. Somtimes when I give it gas the throttle doesn't come all the way back down. I can pop the throttle and sometimes it will come down but still turning higher rpm's han it's suppose to be, sometimes it will die out.. Sometimes I can pop the throttle and it will go down to idle perfect and then when I'm not even touching the bike it will rev up on it's own about 1000 rpm's, what could cause this ?? I have been over the carbs and everything seems to be working correctly, slides, floats, etc.. It's not the chokes because I have cut the cable on those because they were a pain in the azz getting stuck all the time.. I'm running 45 pilots, Dynojet 138 front, 144 rear, needles on 3rd clip w/ 2 shims.. If I step it down to 42 pilots I get a real bad cackling and popping on decel.. ANY help would be greatly appreciated..
Thanks, John
06' Arctic Cat Tony Stewart Edition - AMR 840 -And A Beer Cooler!!
www.bamaboggers.com
Powered By Argo Powersports
Sponsors:
Argo Power
Rubberdown Customs
Atv Direct
Mad Motorsports
Yasky Atv
