fuel switch - Kawasaki ATV Forum
post #1 of 10 Old 08-21-2010, 05:11 PM Thread Starter
fuel switch
hi, i have a 2003 kawasaki kfx 400 and on the side where the fuel shutoff switch is there r three words, on, reserve, and primary, does anyone know what primary means?????
2003 kawasaki kfx 400 with pro armor skid plates, nerf bars and kill switch, itp gncc holeshot tires, renthal sprokets and chain, ac raceing front bumper, tusk d-flex handguards, and alot of room to build it up
2003 kfx 400 is offline
post #2 of 10 Old 08-22-2010, 11:46 AM
Prime is just constant fuel flow.
kfx400travis is offline
post #3 of 10 Old 08-23-2010, 01:23 PM Thread Starter
then whats on mean?
post #4 of 10 Old 08-23-2010, 02:08 PM
jonboy's Avatar
You carberator pulls fuel by vacuum through the motor. The prime index on the petcock is to prime the carb if the bowl is dry form draining it to clean the carb or what not. The on index is for normal running conditions.
04 KFX400,Crasko 450bbk, Crasko P&P,DRZ flywheel,Web cams,custom Yosh header w/FMF PC4,FCR39,ESR intake,Leager A arms,ESW modded 450r shocks,GTT rear link,Tag stem and bars,JBcustoms frame gussets,LSR axel,YFZ450 front calipers.
99 Lakota, DG excellerator,400ex carb,CWR 335 kit,CWR .390 cam,JB custom intake,Crasko P&P head,400ex rear hubs, Modified KFX400 front suspension.
88 Tecate 4 mostly stock Bills pipe and works shocks.
Sponsors, JBcustoms,6thPinned Motorsports,Crasko Performance.
jonboy is offline
post #5 of 10 Old 08-24-2010, 05:42 AM Thread Starter
so you use prime when the carb is dry, but for how long untill you seitch it over to on???
post #6 of 10 Old 03-30-2011, 06:40 PM
How long to prime
Any reply to this question of how long for the prime switch? Thanks
Kawikiller is offline
post #7 of 10 Old 03-30-2011, 08:22 PM
I've never used prime.....well not until I changed to an FCR carb.
You don't need it. The 'choke' will also get gas into your carb quicker, not worth reaching down to switch the petcock.
You can use it just as described though......as well as if you run out of gas you could switch it to prime and then to reserve.
spize909 is offline
post #8 of 10 Old 03-31-2011, 07:23 PM
Thanks man, the quad just runs out of fuel and I've cleaned carb every jet and hole I could find, rebuild carb kit, checked for clogged lines, checked for vacuum leak, its all stock, everything is real clean petcock etc. I think I'm ready to take it in for service.
post #9 of 10 Old 04-01-2011, 07:11 AM
Are you sure the diaphragm doesn't have a tear in it?....although I would think on prime it should be flowing fuel. How about the needle valve is the float working right and letting the valve open and close.
I would switch to a Raptor 660 petcock for 20 bucks or so and try that before taking it to the shop.
spize909 is offline
post #10 of 10 Old 04-06-2011, 09:57 AM
Sorry i took so long gettin back thanks for the info. I left the prime switch on for 5min then turned it to on and it seems to be working! I have started it and riden it just using the switch in the on position and its workin I don't get it but I just saved an a$$ load of money thanks for the replies.
Unleaded fuel (87) or premium fuel for my brute?!?! cdcbarr Kawasaki Brute Force/Prairie/Bayou 48 07-07-2011 12:20 PM
Kawie Fan Switch or Rad Temp switch monkeybruteforce650 Kawasaki Brute Force/Prairie/Bayou 1 07-27-2008 06:55 PM
LIGHT SWITCH/ ON-OFF SWITCH/CHOKE SWITCH ASSY. VFORCEJOHN For Sale 1 10-09-2006 03:03 PM
any suggestions??? fuel control switch... dirk_411 Kawasaki Tecate 6 06-06-2005 11:50 AM
Fuel Pump Shut Off Switch???? OrangeForce Kawasaki KFX700 V-Force 7 03-27-2005 07:18 PM
