kfx400 timing marks?no compression - Kawasaki ATV Forum
post #1 of 3 Old 04-02-2011, 05:59 PM Thread Starter
just got it from a friend,had a bent valve,replaced it,was told to set timing at ex cam 1 mark facing gasket surface and 2 mark up.intake cam mark 3 on the 15th pin from ex cam mark 2 so it would be ex-2 up,in-3 up.motor has no compression.do i have the timing right?
my95f150 is offline
post #2 of 3 Old 04-02-2011, 11:38 PM
yes as long as you have it on top dead center you are correct!!
check to make sure the valves are sealing properly!
Rcfan is offline
post #3 of 3 Old 04-04-2011, 08:03 AM
the cams sound like they are right, as long as the T mark on the flywheel was up, you should be OK on timing. My bet is the replaced valve is might be too tight, and a thinner shim is needed. Check the valve clearance next.
sandman74 is offline
220 bayou timing marks? tazmaniac_37752 Kawasaki Brute Force/Prairie/Bayou 2 10-20-2010 07:40 PM
Compression & timing advance Enigma Kawasaki KFX700 V-Force 1 06-01-2010 10:02 AM
timing marks? coolinthewoods123 Kawasaki KFX700 V-Force 2 01-19-2008 11:50 AM
Removing Ink marks xchamp Club Kawie 10 12-28-2007 06:51 AM
Compression check KFX400 Chezehead Kawasaki KFX450/KFX400 0 06-13-2007 08:28 PM
