Air/Fuel screw help. - Kawasaki ATV Forum
post #1 of 6 Old 02-25-2012, 08:50 PM Thread Starter
Where do i adjust my air/fuel screw to.. All the way in and back it off 3 full turns?
2003 Kawasaki KFX 400. With full CT racing exhaust and a jetted carb with155 main. Uni foam filter with air box lid on. Nothing special.
brianrolin is offline
post #2 of 6 Old 02-25-2012, 11:36 PM
Careful not to tighten it down too tight, you can break the tip off. You will probably be at 2.5 to 3 turns but I'm sure things like elevation could make a difference on that.
spize909 is offline
post #3 of 6 Old 02-26-2012, 09:45 PM Thread Starter
I live in Atmore, Alabama. Its on the Alabama/Florida line.
post #4 of 6 Old 02-27-2012, 12:48 AM
Eustismudder's Avatar
2.5 will be just fine
Eustismudder is offline
post #5 of 6 Old 02-27-2012, 05:27 AM
KawieFreak's Avatar
Quote:
Do you have any mods done to the machine, If you have aftermarket exhaust and air filter with the lid off it could be 3 - 3 1/2 turns out for some machines all depending on what you have done to the bike.
KawieFreak is offline
post #6 of 6 Old 02-27-2012, 05:26 PM
Quad82's Avatar
If you turn it out past 3 turns, you probably should move up a jet size. The tension on the spring is too week at 3+ turns out and the screw can vibrate loose. Stock is 22.5. Going to a 25 is the next step.
95 KLF400
01 KLX440
03 KFX440
04 KFX440
01 TRX500
85 lt185
89 230 Quadsport
03 S-10 Quad-cab
Quad82 is offline
2003 kawasaki klx 400 carburator screw pilot air
adjust air fuel mixture kfx 400
how to adjust air/fuel mixture on a 2007 kfx 50
how to adjust kawasaki kfx 50 carb
how to adjust kawasaki kfx 50 carburetor
kawasaki kfx 50 carburetor adjustment
kawasaki kfx 50 carburetor adjustment screw locations
kawasaki kfx@50 mix ratio
kfx 400 carb adjustment
kfx 400 carb adjustments
kfx 400 pilot screw adjustment
kfx400mixture adjustment
air fuel mix screw wapiti1 Interstate Motorsports 2 04-28-2009 09:41 AM
fuel/ air mix screw firedoger Kawasaki KFX700 V-Force 7 12-29-2008 04:23 PM
Where is the air/fuel screw located at? ZKriegel Kawasaki KFX700 V-Force 6 04-05-2007 01:41 PM
Air/Fuel screw OKKFX700 Kawasaki KFX700 V-Force 2 07-21-2005 02:51 PM
Fuel air screw mjohnson97045 Kawasaki KFX700 V-Force 3 03-11-2005 01:48 PM
