KFX just dies (FUEL PUMP) - Kawasaki ATV Forum
post #1 of 12 Old 10-14-2007, 02:22 PM Thread Starter
GREEN GOBLIN's Avatar
My KFX decided to just die today.... I noticed the fuel pump isnt making that noise it made when you start it up. I tried the roll over circuit as discussed in a previous thread but no luck.. Has anyone else had this problem?
Stock 450R, Not so stock pilot!
GREEN GOBLIN is offline
post #2 of 12 Old 10-14-2007, 02:50 PM
Feedback Score: 40 reviews
PIPO's Avatar
Do you have a PCIII? I'd check that 1st before anything else.
PINARELLO DOGMA 60.1/CAMPAGNOLO RECORD 11
CANNONDALE SUPERSIX EVO HI-MOD/DURAACE 11
PIPO is offline
post #3 of 12 Old 10-14-2007, 08:11 PM Thread Starter
[/b]
Its stock, Whats the PCIII?
post #4 of 12 Old 10-14-2007, 08:16 PM
PIPO's Avatar
Power Commander III
PIPO is offline
post #5 of 12 Old 10-14-2007, 08:20 PM Thread Starter
Quote:
Power Commander III
[/b]
I'm not being ignorant , but is it stock PCIII or is there a problem with them? gimme the scoop.
post #6 of 12 Old 10-14-2007, 08:36 PM
PIPO's Avatar
The power commander is an aftermarket fuel controller.
PIPO is offline
post #7 of 12 Old 10-15-2007, 09:48 AM
May have popped the fuse for the fuel pump. Hopefully that's all it is. I had looked into the fuse locations before but can't remember which one it was, it is under the front cover though where the rollover switch is.
08 KFX450R SE
ESR Full ceramic Exhaust
FUELATV INTAKE
PCIII with FUEl MAP
Next addition: 3 degree advance flywheel keyway for ignition(try this cheap upgrade in lue of the dynojet ignition controller)
Steering stabilizer
Still need to upgrade the sprocket, going 15T front first
Cams??? Hopefully---trying to stay out of the internals though.
roundyround is offline
post #8 of 12 Old 10-15-2007, 09:03 PM Thread Starter
[/b]
Thanks dirt, The only fuse I can find really is the main fuse on the top right, even the manual states there a radiator fuse and a fuel pump fuse but i cant find them even though they point them out. i will keep searching because even though its covered under warranty once it goes into the black hole of the dealership who knows how long it will sit there on an ordered part that for some reason takes months to come in. LOL
post #9 of 12 Old 10-17-2007, 06:56 PM
Feedback Score: 1 reviews
Jonny450R's Avatar
Location: Colorful Colorado!!! You know you're jealous!
Do you have any other electric turning on? My main fuse went out on the trail and nothing worked no head light not even the green neutral light. I would triple check that along with your battery my wouldn't turn the pump on or turn the starter one day and check underneath the seat there a ground wire there for the fuel pump, if thats dirty that can give you an issue as well. Other wise keep pluging away at the manual to see if you can find the fuse and if worst comes to worst, try to follow the wiring harness back from the fuel pump to to fuse. I know easier said then done and could possibly void your warranty, but that depends on how frustrated you are at that point to bring you quad back to the dealer and have them taking a look at it.
Jonny450R is offline
post #10 of 12 Old 10-17-2007, 10:26 PM Thread Starter
[/b]
Thanks for that suggestion but, the other thread i did points out and has a pic of where to find the fuel pump fuse and the fan fuse. It was the fuel pump fuse as I suspected but could not locate for a while.
08 kawasaki 450r fuel pump fuse
2006 kawasaki kfx 400 fuel pump
2008 kfx 450 nothing comes on
2008 kfx 450r fuel pump
2008 kfx450 fuel pump relay
700 kfx fuel pump fuse location
kawasaki kfx 700 fuel pump relay
kawasaki ksf450b fuel pump diagram
kfx 450 fuel pump
kfx 450r fuel pump diagram
kfx450 fuel pump
kfx450r fuel pump
kfx450r fuel pump relay problem
Anyone need a fuel pump mudman0000 For Sale 4 04-19-2014 07:12 PM
Electric fuel pump mod for Brute 650's with vacuum fuel pump VFORCEJOHN Interstate Motorsports 0 04-14-2009 02:21 PM
need fuel pump junkman Wanted 2 09-05-2007 11:07 AM
fuel tank and fuel pump gomerkfx700 Kawasaki KFX700 V-Force 4 03-04-2007 09:22 PM
fuel pump GnFnRs Kawasaki KFX700 V-Force 13 11-22-2006 11:38 PM
