ATV Oil vs AUTO Oil - Kawasaki ATV Forum
post #1 of 12 Old 03-27-2008, 10:58 PM Thread Starter
I am curious - lets say your using the Castrol (non-synthetic) 10/40w --- could you then drain it out of the ATV (I have a KFX450r) and use 10/40w automotive oil?
jwhopson is offline
post #2 of 12 Old 03-28-2008, 03:47 AM
Feedback Score: 1 reviews
You could if your transmission is seperated from the engine oil like the honda 450's. Automotive oil will not work with the wet clutch. Atv oil is designed for this and to be used in transmission gears.
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #3 of 12 Old 03-28-2008, 07:50 AM
Quad82's Avatar
This is one of those questions that will get you every possible answer. So let me be the first to get fired at. I am over 40 so I do have time as a honest backup. I run nothing but Valvoline 10/40. Same oil in all my machines, quads, trucks, tractors and bikes. I have never had a problem with any of my racing motors having clutch problems. But I change the oil after every few rides or race. It is cheap enough and I can see what is comming out of the motors a lot more often. I have been using it since my dad got me my first Indian dirt bike. I am not saying that synthitic(sp) or other oils are not better. I am just saying that auto type oils will work fine. But there are different types of auto oils. This is where the trouble is.
I take back the comment about running nothineg but Valvoline 10/40. Over the years, I have used Kawasaki, Klotz, Golden Spectro and Arctic oils. That might have something to do with the Quadzilla, T-4, LT, KX, RM, and a slew of other 2 strokers using premix.
95 KLF400
01 KLX440
03 KFX440
04 KFX440
01 TRX500
85 lt185
89 230 Quadsport
03 S-10 Quad-cab
Quad82 is offline
post #4 of 12 Old 03-28-2008, 09:32 AM
Supporting Vendor
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
I run Royal Purple and Amsoil now. they are both Auto oil and have used auto oil in the atv's for many years with wet clutches.
I think some atv dealers install Fear into the customer as they tell them that you HAVE to run the ATV oil they sell there.
to each their own.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #5 of 12 Old 03-28-2008, 09:35 AM
aaronc's Avatar
[/b]
Agreed I have until last year ran nothing but castrol 20w-50 in everything from the trucks to the ATV and even my old Harley ...never had any problems .... Last year do to Sponsorships I change to Amsoil 20w-50 v-twin oil in my prairie .... !
TBC BOG TEAM
Motor built by FCP
SPONSORED BY-WEB CAMS/WISECO/INTERCO TIRES/FLYNTS PERFORMANCE/AMSOIL/SIMPLE GREEN/FULMER HELMETS/PB.BLASTER/GORILLA AXLE/YASKY ATV/KLIM USA/DAYCO BELTS/
POWER MADD/SPIDER GRIPS
http://mudanddirt.com/
http://www.myspace.com/AaronCSporna
aaronc is offline
post #6 of 12 Old 03-28-2008, 01:11 PM
gardner99_brute's Avatar
You can run a auto oil in your quad if you change it often. Quad oil and motorcycle oil have more detergents in them. So as they go through your motor and tranny they take the abuse and don't get as dirty as fast,they also don't break down as fast. I took a class on oil when I worked at my last job( a bike shop) and I believe there are 7 ingreidents in a motorcycle oil and 4 in a auto oil.Change it often and you should be fine.Heck, I had a friend who put 10/30 in a 2 stroke as the mixer just so he could make it home one day.
06' team green p700
dynatek-napa hose mod-k&n filter
almond pri spring-itp wheels and big horns
03'klx400 "my street bike"
carb mods-full muzzy-k&n filter-lowered
19 inch wheeles-acrebis lights-trailtech guages
flush mount blinders-fabbed taillight
07'V ( mike bensons 07 championship quad)
Four Stroke Tech 700cc Motor (headwork, cams, etc.)
Muzzy Full System with O2 bung welded in
Orange Powdercoated Frame
Renthal Bars-honda front hubs
Herrman Steering Stem-AC nerfs,full skid,grab bar
Heavy Duty Tie Rods and Ends
Stainless Brake Lines-12 hole mod
Pro Armor Front Bumper
450r Choke Mod-oury grips
YFZ Catch Can Mod
Honda Thumb Throttle
Adapt Graphics w/ gripper seat cover
FST Side Cover-kill switch
relocated Key and warning lights
gardner99_brute is offline
post #7 of 12 Old 04-02-2008, 04:23 PM
thormax360's Avatar
I use auto oil 100% synthetic, in the kfx 400.
Stroked, Turbo'd, and on ALKY
thormax360 is offline
post #8 of 12 Old 04-08-2008, 08:47 PM
2000Mojave's Avatar
Well IMO there are two major things to consider. 1) Wet Clutch 2) Transmission. First the Wet Clutch would arguably be fine with a 10w-40 auto oil as long as it doesn't say "energy conserving" and doesn't contain friction modifiers. How would you know if it is "energy conserving" ? It would say on the bottle and I am pretty sure there are no 10w-40 that are. How would you know if it contained friciton modifiers ? Good luck, but the two go hand in hand and it probably doesn't. Second, the transmission will cause oil to "shear" from the gears and most auto oils are not equiped with shear stabalizers like motorcycle oils are. I have read so-called independent test that suggest auto oils shear and loose viscosity ( 40w would test out to a 20w ) in street bikes in as little as 1,000 miles. Where motorcycle oils would test ( 40w would test out to 30w ) in over 3,000 miles. The bottom line to me is this: Is a $5,000-$8,000 investment worth playing the "oil game" over ? To me anything that doesn't have a seperate transmission is going to get motorcycle oil just for the "shear" factor. Anything else like the Kawasaki automatic machines could get either oil.
07 Brute 650 SRA Black
07 Suzuki DR650SE Blue
2000Mojave is offline
post #9 of 12 Old 04-17-2008, 09:32 AM
Kfxnando's Avatar
to each their own.
[/b]
agree with this 100%
have a FZR 1000, and use normal car oil, and no prob so far!!
a friend had a GSXR1100 WP, ran normal car oil for many years and no prob!!
on the older bikes the fully synthetic oil was a prob on the clutches, believe the newer bikes are fine with fully synthetic oil!!
believe the KFX450 should be fine with car oils!!
have heard of some cars running engine oil in their gearboxes!!!
look at it this way, if it was so bad, surely by now we would of heard of major mechanical break downs or motors grenading due to incorrect oils!!!
just my 5c!! hope this helps
good luck!!
KFX700(fast green) wheel spacers, nerf bars, full hydedevelopments bash plates, Trail Teck Vapour, motor internal stock, PENTA 2 into 1 pipe(equal length headers), twin air filter element, blue Dalton spring and O/D cover, stock weights
BF750 - 2inch spacers all round
TRX250TM
FZR1000 EX-UP yoshi, BMC filter 155bhp
http://community.webshots.com/user/kfxnando
http://www.youtube.com/kfxnando
www.kfxnando.com
Kfxnando is offline
post #10 of 12 Old 04-17-2008, 03:02 PM
Car oil will run great in both the engine and tranny. The only issue is with wet clutch disengagement. Your clutch will feel fine and not slip, but without wet clutch additive sometimes they will not disengage cleanly.
For example have you ever experienced the following:
A bike that is very hard to find neutral on, but if you shut it off, it will go right in?
One that if you start it in gear while holding the clutch in it wants to pull forward a little anyway at startup?
In both cases it is because the clutch pack is not separating cleanly. The wet clutch additive prevents these issues. If you can live with these minor problems car oil is just fine.
For some it's beer. Others cigarettes. Still others drugs. For me it's quads, but admitting you have a problem is the first step...
cluelessrookie is offline
atv oil vs car oil
atv oil vs motor oil
atv oil vs regular oil
atv transmission fluid same as car
atv vs car motor oil
can you put atv oil in car
can you switch from synthetic oil to regular oil in an atv
car oil in atv
car oil vs atv oil
difference between atv oil and car oil
is atv oil the same as car oil
is there a difference between atv oil and car oil
what is the difference between atv oil and car oil
auto polish/wax OHVFORCE Club Kawie 9 05-10-2009 07:11 AM
Grand Theft Auto IV GeneralV For Sale 0 04-13-2009 10:51 PM
2 barrel auto carbs hndlbarmonkey Kawasaki KFX700 V-Force 19 08-22-2008 03:40 PM
Hat's off to Auto Mechanics! someone Club Kawie 23 08-10-2008 09:50 AM
auto clutch kawiram Kawasaki KFX700 V-Force 4 04-23-2005 08:24 AM
