2004 kfx700 fuel pressure at pump - Page 2 - Kawasaki ATV Forum
post #11 of 14 Old 01-12-2011, 09:25 AM
and btw, do i need a low pressure regulator with the low pressure mr gasket fuel pump? I was possibly thinking that when I put that new pump on I could be pumping too much fuel and that y it is only running at a high rpm
CoopDawg is offline
post #12 of 14 Old 01-12-2011, 09:37 AM
Supporting Vendor
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
This is an easy and cheap fix.
here's how to do it.
remove the stock pump. take a pliers and snap off the regulator on top of the fuel pump. it sits directly on top of it and feeds the rubber line.
next get a longer rubber line and attatch it to the pump.
now. see if the pump works. usually the regulator goes bad.
if it doesn't. add a longer line that hangs down to the bottom of the tank and remove the stock pump.
bolt back up the pump housing.
next get a MR gasket 42S fuel pump. they are about 50.00
install it in line. be sure to use the 1 way check valve that is included in the pump to prevent drain back when you shut it off.
you can tap right into the fuel pump +12v power wires that are right there. leave the ground and the signal wire there, to supply the low fuel warning light
there is no need for a pressure regulator.
I've used this setup on many NOS bikes I have set up and it supplys fuel to handle 100 rwhp easily. and it's cheap.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #13 of 14 Old 01-12-2011, 10:56 AM
Feedback Score: 1 reviews
Sweet info, thanks john!
2004 V-Force Orange
Shorty Shifter,Red EPI Spring,PowerMadd Black Handguards, DG 6 Pack Rack , Gunnar Kill Switch, Cobra Nerf Bars
Rocks Front Bumper,HEP LED TailLight
22x11-10 Sur Traks, Custom Head Lights
Vented Hood, Pro-Action Reworked 450R Front Shocks, Elka Rear Shock, Rocks Belly & A-Arm Skid Plates, Dalton Clutch Cover,Twin Air Power Flow Intake,Dual Yoshimura Exhaust,Jetted,23x8-10 Front Mudlites, Fluidyne Radiator, ITP Front & Rear Beadlocks, IMS Oversize Tank
WFO Racing.
04hemigtx1990 is offline
post #14 of 14 Old 08-27-2011, 01:17 PM
Feedback Score: 40 reviews
PIPO's Avatar
I know, old topic...but I have a question. Does anyone know if the fuel psi changes when you remove the regulator John is talking about? One more question...is the fuel tank vent hose fuel resistant?
PINARELLO DOGMA 60.1/CAMPAGNOLO RECORD 11
CANNONDALE SUPERSIX EVO HI-MOD/DURAACE 11
PIPO is offline
2004 kawasaki kfx 700 fuel pump test
2004 kawasaki prairie 700 fuel pump
2004 kfx 700 fuel pump
2004 kfx 700 fuel pump pressure
fuel pressure on a kfx 700
fuel pressure regulator kvf
kawasaki kfx 700 fuel pump pressure
kfx 700 fuel pump
kfx 700 fuel pump problems
kfx 700pressure in the tank
kfx700 fuel pump
Fuel pump pressure LAVRx Kawasaki Brute Force/Prairie/Bayou 6 11-02-2009 05:33 AM
V fuel pump pressure? Psi-820 Kawasaki KFX700 V-Force 3 09-07-2009 05:54 AM
Electric fuel pump mod for Brute 650's with vacuum fuel pump VFORCEJOHN Interstate Motorsports 0 04-14-2009 02:21 PM
KFX700 fuel pump for sale mudman0000 For Sale 2 01-19-2008 09:27 AM
Fuel Pressure? AfterMidnight Kawasaki KFX700 V-Force 6 04-08-2007 02:51 PM
