fire out tail pipe - Kawasaki ATV Forum
post #1 of 22 Old 03-01-2011, 07:57 PM Thread Starter
Orangekfx700's Avatar
fire out tail pipe
I am not sure if I am running rich or lean but when I rev or accel then let off throttle it shoots a 1 foot flame out the tail pipe and back fire pretty loud.
I am drilled my jets 3/32 i believe and have cross over and exhuast as well as 12 hole/twin air. Oh and 42 pilots.
thanks
2005 Kfx700
White Bros race exhaust, 12 hole mod, Crossover intake, twin air filter, Spark plug mod, Polished slides. Dynatek FS Ignition, 42 pilot jets and 1 washer under each needle, cut 2 loops off carb springs, EPI Pink spring, 22 inch front I Razr
Orangekfx700 is offline
post #2 of 22 Old 03-01-2011, 08:39 PM
brutemike's Avatar
sounds too lean to me
brutemike is offline
post #3 of 22 Old 03-01-2011, 10:01 PM
Feedback Score: 21 reviews
Camo's Avatar
I had the same thing once, but after I knew I was jetted properly. It was a plugged pilot jet.
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
Torque is quick... Horsepower is fast
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim / VFJ Clutch Weights & Springs
YOU DESERVE A HIGH FIVE... IN THE FACE... WITH A CHAIR
Camo is offline
post #4 of 22 Old 03-01-2011, 10:03 PM
Feedback Score: 17 reviews
AnotherNewb's Avatar
I agree with camo, clean the carbs....
09 V----Mixbreed 800 with stage 3 cams, Muzzy Super Pro, Cross-over intake, VFJ stage 3 w/spidermod clutch. Plus 2 swinger.
AnotherNewb is offline
post #5 of 22 Old 03-02-2011, 06:54 AM
yamihoo's Avatar
Yep LEAN! Which could be dirty jets, leaking exhaust or improperly jetted among other things. Did this happen immediately after mods or just start doing it out of the blue?
If you drill out your jets you run the risk of not having a true hole size, 3/32 could be +/- .005-.010" depending on the quality of your drill bit, how straight you drilled it, the quality of the hole drilled
Personally I don't understand why people drill jets, they are so cheap to buy and much more accurate. If they don't offer the size you want, you probably don't need it...but you can also try different jet brands... if you have experience with precision machining and you pin gauge these jets you'll find they cross over more then you think.
If your bent on drilling your own jets, you should really use a reamer to get a quality and accurate hole. Just my 2cents
2009 KFX 700 (Totalled...Rebuilding)
Yoshi TRS Duals#NoToil#138/142J's#DaltonOD-O/B spring#DG V-Lite#Dillo' 6pk#Tusk Skids/Arms#TT Vapor/Dash/XBars#ODI Rogue#Bar Heaters#PowerMadds#HandShifter#TRX450R Front Shocks
2011 Can Am Renegade 800XXC
yamihoo is offline
post #6 of 22 Old 03-02-2011, 09:27 AM Thread Starter
Lean huh, I was thinking it was rich. It feels like its rich when I ride it. It only back fires as i decel. never while riding and it is not over heating. it runs nice and cool.
I just put new pilots in it 20 hours ago I would not think they are dirty yet.
2005 Kfx700
post #7 of 22 Old 03-02-2011, 10:12 AM
Feedback Score: 1 reviews
I would check for an exhaust leak, With the bike running, plug the exhaust with your hand and listen for leaks. You could be running rich, when the unburnt fuel coming out of you exhaust gets oxygen from a exhaust leak it can re-ignite causing a back fire.
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #8 of 22 Old 03-02-2011, 11:07 AM Thread Starter
Thanks
where do i check for leaks the white bros system i have just slips together. Should I maybe try and use hose clamps or something to make sure they are sealed 100%
2005 Kfx700
post #9 of 22 Old 03-02-2011, 02:50 PM
There is a good chance it is leaking where it slips together. Take the muffler off and put high temp silcone on where it slips togther. Put the can back on and let the silicone fully cure before you start it. I would get an A/f meter to check your jetting, it could be a big part of your problem.
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #10 of 22 Old 03-02-2011, 03:21 PM Thread Starter
Silicone like what you use to make gaskets?
I jetted where i was told I should for my set up when I bought the cross overs. I feel it is rich.
I am leaving for little sahara next friday. What jet would you folks recomend.
I have 12 hole, twinair filer kit, white bros exhaust, crossover, spark plug mod and pink spring in cvt.
Please let me know your thought on what to jet to.
2005 Kfx700
2005 arctic cat 650 with hmc pipe backfires when accel
banshee pipes are shooting fire
fire from tailpipe
fire from tailpipe air filter
fire out of exhaust mean lean
fire out of exhaust pipe motorcycle rich
kawasaki 17 hp engine fire out exhaust pipe
kfx 450 fire out exhaust
madura running lean blue exhaust pipe
my kfx 400 shoots fire out the exhaust
should my big dog shoot flames from the pipes
spark coming from my motorcycle tail pipe
why is fire commin out when my kfx 400 back fires
strong exhaust smell \ sparks out tail pipe dogwood Kawasaki Brute Force/Prairie/Bayou 12 11-29-2010 05:44 AM
brute 2009 back fire bad, red hot pipe bordage Kawasaki Brute Force/Prairie/Bayou 11 02-17-2010 05:19 AM
FIRE! FIRE! FIRE!....GAS TANK!....GAS TANK! Griffee Kawasaki Brute Force/Prairie/Bayou 13 05-14-2007 09:53 AM
Wanted stock tail pipe for '03-'05 kfx/z400 05yoshimuraV700 Wanted 2 07-08-2005 12:10 PM
Big Fire Creek Runner Kawasaki Brute Force/Prairie/Bayou 6 06-03-2004 07:31 PM
