700v.com valve adjustment - Kawasaki ATV Forum
post #1 of 9 Old 04-08-2011, 01:42 AM Thread Starter
Feedback Score: 1 reviews
Ok, I got lucky and could easily read "r" and "f" on the flywheel. As long as it is on the appropriate cylinder marking, I can adjust the valves? On the rear, the exhaust was in tolerance, and intake was just a tad tight on one valve. Rotate it to the front, and both intake valves and both exhaust valves were pretty tight. Took a few turns to be able to slide feeler gauge in there. Sound like I did it right? If so, no wonder the bike was running bad, popping, and hard starting; much less running at all.
Thanks for the help, joe
Dirty joe is offline
post #2 of 9 Old 04-08-2011, 02:10 AM
Feedback Score: 2 reviews
RANDALLPINK7's Avatar
actually sounds like youre running low on muffler bearing oil.
2005 KFX 700
AMR 840, PORT AND POLISH, +4 VALVES, XXX cams BOONDOCKER NOS, 38mm Carbs with Custom Intakes, VENFORCER +4 EXTENSION, drag pipe, VFJ STAGE 3 WITH SECONDARY, K&N, MARVIN SHAW HILL SHOOTER'S FRONT AND REAR, FRONT LOWERING, O/B SPRING WITH WEIGHTS, DYNATECH CDI, 25 x 11 x 10 SKAT TRACK RIPPERS
04 KFX 400
440 BIG BORE KIT,13.5-1 wiseco, DYNATECH CDI, K&N, LRD EXHAUST, K&N AIR BOX LID, Fasst Flexx bars, ODI grips, 450R front shocks
06 BRUTE FORCE 750i
2 INCH LIFT snorkeled, 28 in. Mudzilla TIRES
ITP SS112 12X7 rims, dynatek cdi, K&N AIR FILTER
KFX 80
WHO KNOWS
2008 TERYX
27 in. Mud Lites, 2 inch lift, Team Green plastics, ITP SS212's
RANDALLPINK7 is offline
post #3 of 9 Old 04-08-2011, 07:31 AM
mattysticks's Avatar
I pretty much had the same exact issue with my v last week, mines an 04 and the guy I bought it from didn't do a whole lot of riding but he never had the valves done at all. The bike was takin 10 min if not longer to start and when it finally wouldn't start I did the valves and cleaned the carbs real well. Now she starts and runs just like it was from the factory again.
04 V-spark plug mod from venforcer,rocker mod, k&n intake, dual yoshis, 450r thumb throttle, powermad guards, hd tie rod kit from venforcer,epi pink spring,stage1 cams, and much more to come.
ride it like you stole it
mattysticks is offline
post #4 of 9 Old 04-08-2011, 01:57 PM
Feedback Score: 21 reviews
Camo's Avatar
As long as the rockers are on the base circle of the cam, you can adjust that same valve. You don't need to worry about r and f.
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
Torque is quick... Horsepower is fast
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim / VFJ Clutch Weights & Springs
YOU DESERVE A HIGH FIVE... IN THE FACE... WITH A CHAIR
Camo is offline
post #5 of 9 Old 04-08-2011, 02:15 PM Thread Starter
Quote:
Thats what I was wondering. The 700v website wasnt real clear. Said f is for front valves and r is for rear valves. So do I need to redo my valve lash again, disregarding f and r and the 700v instructions?
post #6 of 9 Old 04-08-2011, 02:44 PM
Camo's Avatar
No, not if you followed them properly. I just don't do it that way cause you don't have to. But they are very good instructions for doing them.
OrangeCrush RR
1) Bench Racers
4) The Big Dog
Camo is offline
post #7 of 9 Old 04-09-2011, 08:49 AM
Agreed.... alot easier and quicker doing it this way. Basically, just turn crank till exh valves are going down then adj the int valves on same bank. same for exh valves wait till int goes down then adj. Do same for oposite bank. Just remember to do one bank at a time. Easy... I dont even use a feeler guage, because I get ticking when valves are adjusted that way. Its more of how the gap feels to me moving rocker arms back and fourth... 10 times simpler and quicker. Literally takes 10 min this way...
HMF duals, EPI pink spring, 12 hole mod, UNI filter. Horsepower recipie: cheap, fast, reliable. You can pick any two you want!!!
JRENIGAR is offline
post #8 of 9 Old 04-09-2011, 03:13 PM Thread Starter
I must not have them done correctly because my front valves were loose as hell. I adjusted them like race cars and like what you all said to do. Good to go now.
P.s. Dont ever buy amr racing ignition coils. The spark plug wires cannot be replaced. The front spark plug wire was broken. Ordered new coils from dealership. Will be here thurs
post #9 of 9 Old 04-09-2011, 07:07 PM
I had on heluva ordeal trying to use the flywheel marks to adjust rockers. It never worked out for me either.
JRENIGAR is offline
2005 kfx 700 valve adjustment
700v.com
how much is a valve for a kfx 700 atv
how to adjust valves on kfx 700
kfx 700 valve adjusment
kfx 700 valve clearance
kfx 700 valve specs
valve adjustment for a kfx v-force kawaski 700
what is the suggested valve lash on a 2004 kawasaki 700 v twin
what is the vavle adjustment on a kfx700
www 700v com
www.700v.com
valve adjustment help dunny Kawasaki Brute Force/Prairie/Bayou 8 09-23-2010 06:50 PM
360 valve adjustment? swampvol Kawasaki Brute Force/Prairie/Bayou 1 01-13-2010 07:05 PM
valve adjustment. lonerezzie Kawasaki KFX700 V-Force 7 07-18-2005 10:29 AM
Valve adjustment on a 785 bb razzergreen Kawasaki Brute Force/Prairie/Bayou 2 06-28-2005 06:33 AM
Valve Adjustment KevinM Kawasaki KFX700 V-Force 0 12-31-1969 07:00 PM
