Valve adjustment - Kawasaki ATV Forum
post #1 of 19 Old 01-26-2013, 12:23 PM Thread Starter
vman1973's Avatar
Valve adjustment
Hi all. I have a 09 kfx 700 which needs valve adjustment every 3 or 4 tanks. It now seams to have a problem which I think might mean it time to take the front head off. Problem is!!! Intake valves. Even with the lash adjusters removed there is no valve to rocker clearance. Have done the check of possibly being out 180 degrees. Timing all seams well. If I rotate the engine by hand the valves still go up and down but don't come all the way up, when rotated so that the rocker arm is on the rear of the cam lobe I can get a small screwdriver and lever the rocker arm up and it will "click and lift up higher but still have no valve clearance. Any ideas before I strip it down.
Am hoping someone out there will tell me it's a easy 10 min fix but I doubt it...
Sent from my iPad using Tapatalk HD
vman1973 is offline
post #2 of 19 Old 01-26-2013, 12:41 PM Thread Starter
vman1973's Avatar
Sorry. Not sure what year it is but was told by previous owner that it's a 09
vman1973 is offline
post #3 of 19 Old 01-26-2013, 03:55 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Has this not already been asked and answered elsewhere?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #4 of 19 Old 01-26-2013, 04:01 PM
NovaKaw650's Avatar
The only thing I can add is if the 700 was still running, and you don't have any valve clearance even with the adjusters removed, then the quad absolutely would not start. Make sure that the rocker arms aren't seized up.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #5 of 19 Old 01-26-2013, 06:18 PM Thread Starter
vman1973's Avatar
Yep. Won't start. Rocker arms are not broken, sorry if this has been covered in another post. Please forward me the link so that I don't annoy anyone
vman1973 is offline
post #6 of 19 Old 01-26-2013, 09:28 PM
NovaKaw650's Avatar
I copied and pasted from the other thread:
Quote:
Originally Posted by vman1973 View Post
Hi all. I have a 09 kfx 700 which needs valve adjustment every 3 or 4 tanks. It now seams to have a problem which I think might mean it time to take the front head off. Problem is!!! Intake valves. Even with the lash adjusters removed there is no valve to rocker clearance. Have done the check of possibly being out 180 degrees. Timing all seams well. If I rotate the engine by hand the valves still go up and down but don't come all the way up, when rotated so that the rocker arm is on the rear of the cam lobe I can get a small screwdriver and lever the rocker arm up and it will "click and lift up higher but still have no valve clearance. Any ideas before I strip it down. <br />
Am hoping someone out there will tell me it's a easy 10 min fix but I doubt it...<br />
Nope, no ten minute fix here.
As you suspected, the valves are now completely worn out, and probably ruined the seats in the head. Minimum will be to buy new intake valves and find a trustworthy machine shop to recut the seats, unless they have worn too deep. If the seats are in decent shape, you may be able to lap the new valves to the old seats, but considering the wear in your case, I doubt that will be an option. I wouldn't run the engine any more, the edges of the valves are now so thin that they could break off and trash a cylinder.
Keep an eye on the classified ads on this site; there are often good heads for sale. Watch Ebay as well.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #7 of 19 Old 01-27-2013, 01:28 AM Thread Starter
vman1973's Avatar
Thanks for the reply. You are spot on the money . 1 inlet valve is paper thin. I have. Uncle that owns a bike shop so I will be asking for some family assistance, hopefully the head is not totally stuffed. Thanks
vman1973 is offline
post #8 of 19 Old 01-27-2013, 05:01 AM
NovaKaw650's Avatar
Are you from Australia? The are some active members on this site from Down Under.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #9 of 19 Old 01-27-2013, 01:00 PM Thread Starter
vman1973's Avatar
Yeh. I'm in Australia. There don't seam to be to many bikes like mine around here. Rather hard to get parts
vman1973 is offline
post #10 of 19 Old 01-30-2013, 05:33 PM
ballpeen's Avatar
I have the same problem. Took the head off and luckily I caught it in time valves were wore really thin and seats were wore a little but were not beyond repair. Took the heads to the shop and he said he could recut the seats for 20 bucks a head.
hot cams stage 1,wiesco 11:1,port & polished heads,k&n filter ,muzzy , 12 1" holes in lid,flex bars,orange powder coated frame ,scalloped omf bead locks,ac nerfs,22"razar2 f,20"razr2 r ,58g dalton weights,o/b spring
ballpeen is offline
kfx 700 time jump or valve adjustment
kfx 700 valve adjustment
kfx 700 valve adjustment clearance
kfx 700 valve adjustment tools
kfx 700 valve clearance
kfx 700 valve problems
kfx 700 valves
kfx450valveadjusting
kfx700 valve adjustment
valve adjustment kfx 700
valve adjustment kfx450r
valve adjustment on kfx 700
valve adjustment procedure fo kx 700
valve adjustment or what?? brutee750 Kawasaki Brute Force/Prairie/Bayou 4 11-15-2011 05:43 AM
valve adjustment-help T-DOG Kawasaki Brute Force/Prairie/Bayou 6 12-13-2010 01:18 PM
valve adjustment help dunny Kawasaki Brute Force/Prairie/Bayou 8 09-23-2010 06:50 PM
Valve Adjustment Pibster Kawasaki Brute Force/Prairie/Bayou 2 01-23-2009 01:45 PM
valve adjustment ReignMan22 Kawasaki KFX700 V-Force 5 06-05-2005 06:21 PM
