kfx 700 Spider removal tool - Kawasaki ATV Forum
post #1 of 21 Old 10-25-2016, 04:20 AM Thread Starter
Gr3u's Avatar
Hi there. I have a kawasaki kfx 700 from 2008 and one of the spider bushing has broke. I finaly succesed to remove the primary clutch with a clutch removal tool made from me at the lathe and heat threated the iron in the lab at the University. Now i have to remove the spider, and again... don't have the proper tool for that. I searched the net and wasn't able to find any detailed specs or pictures about this tool. Can somebody help me? Thank you very much.
Gr3u is offline
post #2 of 21 Old 10-25-2016, 04:42 AM Thread Starter
Gr3u's Avatar
It seems that nobody makes this bushings and I have to buy the whole spider, so after i succed to remove the spider i will create my own bushings.
Gr3u is offline
post #3 of 21 Old 10-25-2016, 04:44 AM Thread Starter
Gr3u's Avatar
I will make then at the lathe with the exactly same dimensions as the original.
Gr3u is offline
post #4 of 21 Old 10-25-2016, 04:44 AM Thread Starter
Gr3u's Avatar
After that I will measure the streght of the original material with a special machine and heat threat my material to match the Kawasaki original material strenght.
Gr3u is offline
post #5 of 21 Old 10-25-2016, 04:45 AM Thread Starter
Gr3u's Avatar
All of this will be done at the lab at the University for Material Science in Romania as a experiment. All the help is needed.
Gr3u is offline
post #6 of 21 Old 10-25-2016, 12:51 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
I saw a guy use a piece of plywood to hold the back of the clutch. He cut grooves on the plywood that matched the cooling fins on the back of the clutch. and put a bolt through the center to hold the clutch tight to the plywood.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #7 of 21 Old 10-25-2016, 01:42 PM Thread Starter
Gr3u's Avatar
That's a very good advice, thank you.
Gr3u is offline
post #8 of 21 Old 10-25-2016, 10:34 PM
Feedback Score: 1 reviews
Enigma's Avatar
Doesn't vforcejohn sell bushings as well as a variety of repair parts? He has not been on here for sometime. I believe most of his communication is through his facebook page.
vforcejohn.com
KFX 400
KFX / FST 800
Enigma is offline
post #9 of 21 Old 10-26-2016, 05:14 AM Thread Starter
Gr3u's Avatar
I found him on fb. Thx.
Gr3u is offline
post #10 of 21 Old 10-26-2016, 05:26 AM Thread Starter
Gr3u's Avatar
I finally finished making the Drive Pulley Holder and the Drive Pulley Wrench. Just some fine tunning adjusting left to fit perfect on the spider. I hope nothing brakes.
Gr3u is offline
Brute front pinion removal tool Fearnothing For Sale 0 05-26-2014 02:34 PM
clutch removal tool wjw11teen Kawasaki Brute Force/Prairie/Bayou 10 06-02-2013 06:55 PM
Clutch removal tool question. commando57 Kawasaki Brute Force/Prairie/Bayou 6 06-16-2012 11:39 AM
Vfj roller spider conversion VFORCEJOHN Interstate Motorsports 0 06-10-2009 02:33 PM
Spider removal 2zl Kawasaki Brute Force/Prairie/Bayou 11 09-08-2008 09:11 PM
