Fan issues - Kawasaki ATV Forum
post #1 of 8 Old 05-27-2017, 02:35 PM Thread Starter
Feedback Score: 3 reviews
kfxmatt's Avatar
Fan issues
Went riding for first time this season.and my fan wouldn't come on..actually boiled it over once..not good I know...any way,the wiring to the sensor on the radiator is fine.it's a spal fan I bought about 4 or 5 years ago plus I cleAned it really good when the bike was apart and it was spinning perfect...do those brass sensors on the radiator just go bad? Unless the fan went bad from sitting,which I can't imagine..my only other guess is the brass sensor? Any help would be appreciated..
kfxmatt is offline
post #2 of 8 Old 05-28-2017, 08:10 AM
NovaKaw650's Avatar
Garage
Sensors have gone bad. There should be a test for them in the manual.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #3 of 8 Old 05-28-2017, 10:02 AM Thread Starter
kfxmatt's Avatar
Nova,are you referring to the brass plug on the radiator? Is there more than one sensor? I see the 30a block under the seat..everything is fine in there..I'll check manual now
kfxmatt is offline
post #4 of 8 Old 05-28-2017, 12:31 PM
NMKAWIERIDER's Avatar
What's on the radiator is just a fan switch. Pull the connector and jumper it, then turn the key on. If the fan runs, replace the sensor/switch. If not, look to the fan breaker next. That's probably under the seat as well.
06 BF 750
EZ-Steer EPS | Elka Stage-3s | 26" Grim Reapers | Dynatek | UNIFilter | YFZ Catch Can Mod | Perma-Cool Oil Cooler | Diamond "G" Tie Rods | EPI Pink/Almond Springs | Ricochet Skids | HL Bumper | Direction2 Overfenders | Moose Dual Gasser Throttle | ROX risers & guards
15 ZF 800
27" Grim Reapers | Cold Air Intake w/ Dual Filters | High Flow Exhaust Mod | Seizmik Mirrors | Custom Fenders | Performance Clutch Mods | SATV 4Point harnesses
NMKAWIERIDER is offline
post #5 of 8 Old 05-29-2017, 08:53 AM
I had the same problem this weekend and it was the fuse under the seat corroded up (its the glass fuse in the link attached to the little crossbar between the battery and fuel tank). Trail fix was to simply take the fuse holder out and run it. I have also had the sensor in the radiator go bad.
LAmenace87 is offline
post #6 of 8 Old 05-29-2017, 10:25 AM Thread Starter
kfxmatt's Avatar
thanks guys! hoping to get a chance today to take a look
2005 green v force,g4 graphics fst 730.stage xxx cams,12 hole mod,crossover intake,fast flexx bars,rox risers,odi rogue's, powermadds,o/b spring,carbon man hood,itp t-9s black, muzzy super pro,steering stabilizer,k&n filter,full armor,works triple rate shocks,
kfxmatt is offline
post #7 of 8 Old 06-17-2017, 03:24 PM Thread Starter
kfxmatt's Avatar
I bought a new radiator fan switch and fan was still not coming on.i had to hardwire it with a inline fuse.going on a ride up mount Washington in new hampshire this coming weekend and had to have it working..I mounted the toggle on my rox dash pad next to ignition.
kfxmatt is offline
post #8 of 8 Old 06-17-2017, 03:33 PM Thread Starter
kfxmatt's Avatar
Not a fan of the toggle switch but at least it's working
File Type: jpg 51942969404__F75AFCF5-F637-4D03-8ABA-8368FEEDA970_1497738770296.JPG (675.7 KB, 7 views)
kfxmatt is offline
1998 bayou 300 4x4 issues firefighter398 Kawasaki Brute Force/Prairie/Bayou 22 10-28-2016 08:38 PM
help, having alot of issues with brute 750 SteveCZ28 Kawasaki Brute Force/Prairie/Bayou 32 10-22-2016 04:56 PM
650sra Electrical Issues jg650 Kawasaki Brute Force/Prairie/Bayou 4 08-12-2013 05:46 AM
2012 Brute Radiator Issues gtsum2 Kawasaki Brute Force/Prairie/Bayou 9 12-10-2012 01:41 PM
