I noticed the second time around on taking mine off, it was hard to screw in all the way. I had to use a socket to get past a rough spot that must be on the threads in the clutch because the actual bolt looks fine. I only hand turn mine in until its tight enough by hand i can use an impact. I wouldnt be suprised if mine broke or i accidently force it on and screw up the threads either in the clutch or on the bolt.
I luv pissin you off, It gets me off
Like my lawyers
when the F*ckin judge lets me off
