Attn Tire Experts Seating the bead Question - Kawasaki ATV Forum
post #1 of 7 Old 07-26-2004, 08:15 PM Thread Starter
Feedback Score: 4 reviews
BANDAMAN's Avatar
Ok, so I got my new tire changer from Harbor Freight. it works pretty slick. Breaking the beads is pretty easy, dismounting the tire is even easier. Mounting the tire is a little more tricky, but not too bad with some patience. Now, heres the problem, I can't get the bead to completely seat.
The back side seats fine, the front seats all the way except for about 4 inches that won't seat up all the way over the bead lock area (ridge) on the rim. I am using plenty of lube. the sidewall says not to exceed 25 psi to seat the bead, I am at 25 and am about to go higher, but don't want to blow it up in my face either. I am going to ask a few tire dealers, but thought I would check with you guys.
Thanks
BANDAMAN is offline
post #2 of 7 Old 07-26-2004, 09:01 PM
Feedback Score: 2 reviews
BossMan's Avatar
put 30 lbs in it
05 KFX 700-FST 715-Sold
07 Brute Force 750i Black
2013 Brute Force Candy Green LE
Georgia
BossMan is offline
post #3 of 7 Old 07-26-2004, 09:33 PM
KevinM's Avatar
I had one tire on a new wheel I couldn't get to seat at all. I eventually took a Dremel tool with some sandpaper bits and went all the way around the wheel scuffing it up good and then coated it with dishwashing liquid. Went right on after that.
KevinM is offline
post #4 of 7 Old 07-27-2004, 05:45 AM
Mike Walker's Avatar
If you go to what you believe to be the max pressure & the tire won't fully seat, you can try bouncing the tire... I've had good luck, raising the inflated tire to shoulder height, & dropping it on the tread... this bouncing effect, often seats them right away... usually in 2-3 bounces
2005 Mud Nationals SRA Champion, 3 - 1st place finishes & 1 - 2nd place finish in the stock & modified ATV pulls, 1 - 3rd place finish in the open class Mudda Cross race, 1 - 3rd Place finish in the open class mud bog, at the 2006 Mud Nat&#39;s</span>[/b]
Mike Walker is offline
post #5 of 7 Old 07-27-2004, 02:22 PM
bartlettracing's Avatar
putt it on the quad ,,drive down the drive way and do some turning ,it will pop on ..... if not I have inflated then pretty high in preasure ...... razors are tuff !
10 speed pedal bike
bartlettracing is offline
post #6 of 7 Old 07-27-2004, 03:55 PM
Hey man, I changed quad tires for 4 years and I&#39;ve had to put up to 60 psi in some to get them on bead. Use as much slime or lube as possible and try to stand clear if you can. You can get air chucks that clip on with 3 or 4 feet of hose so you aren&#39;t right in front of it. Also, do you have the core out of the valve stem? It fills up alot faster with it out.
nascarlyle is offline
post #7 of 7 Old 07-27-2004, 08:16 PM Thread Starter
BANDAMAN's Avatar
Thanks Guys, for the advice!
I finally got all four mounted up and on the V. I have my stock Holeshots on ITP T9s fully polished. I am probably going to use the stock rims for sand tires or might sell them.
I am in the Commercial Tire Business, so today I got some bead lube from one of my dealers. It is the nasty black stuff that looks like axle grease and is used to mount semi truck tires. I lubed the bead area up good and they seated up no problem. Yes, I was inflating them without the valve core, that helps get the volume in there quick. I just set my regulator on the compressor to 50 psi and held it on until both beads popped. Probably didn&#39;t take more then 30 psi to seat them. It is not violent, but the anticipation will pysch you out. Being in the business, I have seen many videos of truck tires being blown out. They are quite a bit more dangerous, and run over 100 psi. Many service techs get killed every year inflating tires without a saftey cage.
In my opinion, dismounting and mounting these wasn&#39;t as hard as i thought, but still pretty tricky. It will take some practice to get good. I would rather mount a big truck tire any day then wrestle with these ATV tires and bead lock rims
BANDAMAN is offline
atv bead seat max
best way to seat atv tire bead
can't get atv tire bead to break even with the bead breaker what do i do
getting atv tire to seat
how to get the bead to seat on a four wheeler tire
how to seat a atv tire
how to seat a tire
how to seat an atv tire
how to seat an atv tire on the rim
how to seat atv tire
how to seat bead on atv tire
how to set the bead on a atv tire
what helps seat a atv tire
seating rings TRUEGREEN Kawasaki KFX700 V-Force 19 09-28-2008 06:47 PM
prairie cylinder question for the motor experts 690scarolinaraptor Kawasaki Brute Force/Prairie/Bayou 5 04-20-2008 07:26 PM
question for the experts on kawieriders 690scarolinaraptor Kawasaki Brute Force/Prairie/Bayou 7 04-13-2007 09:17 PM
Broke Bead on Tire! 05BrutePower Kawasaki Brute Force/Prairie/Bayou 8 12-13-2006 03:36 PM
ATTN: Helix.....BF spring question Stakk Kawasaki Brute Force/Prairie/Bayou 6 10-04-2004 02:50 PM
