Coolant Flush - Kawasaki ATV Forum
post #1 of 10 Old 08-17-2004, 06:11 PM Thread Starter
I bought some Engine Ice to help cool things down a bit (I know...you all probably think I should have bought Evans, but that's life). Anyway...I want to make sure I properly flush out the cooling system. What is the basic/best way to do this? Should I empty it at the water pump, and empty the overflow bottle, pour water thru the radiator a to rinse the coolant out, then pour some engine ice in and let it flush out things as well before filling things back up.
How do we make sure that everything comes out of the motor (not just the radiator). Should I "blow" air thru the water jacket to empty the coolant, and then just run the motor with water, then repeat things over again? I've never had a water cooled quad before, so some pointers would be cool. I just don't want to gunk things up mixing the stock coolant with the Engine Ice.
Thanks!!!
Chad
Clackamas, OR
'06 Raptor 700R (His)
'04 V-Force (Hers)
NW Quadriders ATV Club
nwquadriders is offline
post #2 of 10 Old 08-17-2004, 07:25 PM
T3ch_N9ne's Avatar
I would just take the lowest coolant hose that connects to the pump off and let the coolant drain there. Most of it will come out. (Although there is a drain plug/bolt on the bottom of the pump. Doesnt work to well though.) Then drain the overflow bottle by disconnecting the hose or taking the bottle off completely. Hook them all back up and fill with water to the top. Run it at idle for a bit, then drain it yet again ..and repeat until you get pretty clean water. Then fill it with engine ice or whatever.
www.sandtraxx.com - Dune Tees!
"Not all who wander are lost."
T3ch_N9ne is offline
post #3 of 10 Old 08-17-2004, 07:29 PM Thread Starter
Thanks, that makes sense... I'll mess around with that in a couple of evenings. I want to see if Engine Ice really does make a difference. If the heat coming from the headpipe tames down a bit, it will be well worth the money. I'm also switching to synthetic oil. I read that it makes a small difference in temperature too.
Chad
Clackamas, OR
'04 V-Force (Hers)
post #4 of 10 Old 08-17-2004, 07:41 PM
T3ch_N9ne's Avatar
No problem. Do you not have to mix Engine ice with anything? Just pour it in and go? Just curious.
Also, i was looking at an American Ironhorse motorcycle (like a harley) and noticed the pipes were chromed. Or so i thought until i looked closer. It was just a chromed piece of metal or something that wrapped around the visible part of the exhaust..acting as a nice looking heat shield. It has about half an inch gap in between. I was thinking, if someone could do all the bending and rolling to make it fit almost all the way around the visible part of an aftermarket exhaust, that would look/act as a bada$$ heat shield. If you do it right, it would look like your pipes are chromed. Sure you could jet hot coat it but, that wouldnt be a heat shield.
post #5 of 10 Old 08-17-2004, 07:44 PM
It comes premixed.
jtlee75 is offline
post #6 of 10 Old 08-17-2004, 08:24 PM
Killer__Shee's Avatar
I am using Engine Ice and it made a big difference in how often my fan kicks on. Never tried Evans, but Engine Ice is a good product. I flushed water through my system until I got all of my glycol coolant out, and then I put the Engine Ice in. Unfortunately, it isn't going to make any noticable difference in your pipe temperature--it's good but it's not that good
Keep The Rubber Side Down !!!
2008 Honda 700XX
2007 Honda Rancher 420ES
Killer__Shee is offline
post #7 of 10 Old 08-18-2004, 06:15 AM Thread Starter
So do you think that richening up the jetting just a little bit might take down the temp a bit? I'm worried that the heat may be due to being jetted lean from the factory.
Chad
Clackamas, OR
'04 V-Force (Hers)
post #8 of 10 Old 08-18-2004, 06:47 AM
My bike is stock. But when I removed my stock snorkle I noticed my engine running hotter. The fan ran alot more and it got very hot on my leg. I think this is a good way to tell if your jetting is not quite right.
04 Green KFX 700, Fully Adjustable Custom AXIS Suspension, Muzzy Exhaust, 12 1" Holes in Airbox, 182/185, ProArmor Bumper, Nerfs and A-Arm Guards, PRM Desert Grab Bar, Diamond G Green TieRods, ODI Grips w/ Thug Plugs, 20" Mud Sharks, Throttle Limiter Screw almost 1/2 way out.
~The GREEN is SMOKEIN~
ckill is offline
post #9 of 10 Old 08-18-2004, 06:49 AM
I don't think you are probably too lean if you are still stock with stock jetting. No matter what you do those pipes are going to put a tremendous amount of heat off. If you upgrade to an aftermarket exhaust that doesn't have a heat shield it will get even worse. This is the first four stroke I have ever owned, and I don't even notice the heat off of the pipes.
2008 Honda 700XX
post #10 of 10 Old 08-18-2004, 08:24 PM Thread Starter
I don't notice it much either...it's my wife that's complaining....it's her bike. I think she just needs to ride faster :P
Chad
Clackamas, OR
'04 V-Force (Hers)
antifreeze change in a kawasaki mule 2003
change coolant kawasaki mule
flushing cooling system on kawasaki mule
how change radiator kfx 700
how to back flush the radeator on my kawasaki mule
how to change coolant on 2007 kawasaki mule
how to drain antifreeze on kawasaki 3010mule
how to flusbmy kfx
how to flush out atv radiator
kawasaki coolant flush 400
kawasaki mule coolant drain
kawasaki mule how to change cooling liquid
kfx radiator flush
coolant shooting out of breather hose on coolant resivor tank thormax360 Kawasaki KFX450/KFX400 3 02-24-2009 07:44 PM
coolant in oil... bowman Kawasaki Mojave/Lakota 3 01-09-2009 06:55 PM
Coolant RuninWideOpen Kawasaki KFX700 V-Force 5 08-23-2008 08:27 PM
Front Diff Flush Minjin Kawasaki Brute Force/Prairie/Bayou 5 04-27-2008 10:34 AM
coolant in oil? vtprairie03 Kawasaki KFX700 V-Force 6 01-11-2008 04:58 PM
