30 amp fuse under seat keeps blowing - Kawasaki ATV Forum
post #1 of 19 Old 12-17-2006, 03:13 PM Thread Starter
ive had an 04 V for about 8 months now....not a single issue.....today the bike just stoped...no power or lights....i remember reading about the fuse under the seat blowing and would leave you stranded.....well it did....i put a new fuse in it and after about 1 min it will just blow.....i put in a third fuse and the bike was just sitting (with out running) and the fuse just blew after about a min.......i just could not find any wire that was broken or rubbing...........any help would be most helpful.......thanks..........dennis
tcat1000 is offline
post #2 of 19 Old 12-17-2006, 03:35 PM
Feedback Score: 3 reviews
Dvader's Avatar
check your cdi--look at the wireing---look for a short to ground.
Notoriuos to wear the insulation on the wire on the frame right at the cdi.
If not there --it is somewhere in that wire loom.
Check the whole thing.
Good luck
dvader
Trail//FST730,
,stock porting/6*key/fststg2cams/62hp/stock swinger/ daulton blue 2-56`s/stock secondary
clutch cut [vfj stg3w/spidermod]
Muzzy Superpro.
elka`s ,, plus many add on`s
built and tuned by VFJ at interstate motorsports
Dvader is offline
post #3 of 19 Old 12-17-2006, 03:42 PM
Feedback Score: 12 reviews
VENFORCER's Avatar
[/b]
Trace the wires from the fuse as far as you can and look for worn insulation on the wires possibly grounding to the frame, or onto another wire. Some of the other wires are also ground wires. Hot-ground will blow a fuse everytime. The problem can also be intermintant if the grounding is soft (just touching).
VEN
2004 Green KFX 700, Boss Nos(30 shot), FST 803, stage 3 cams, AMR ported heads, 36mm carbs, My +7" cut and weld swinger, My 6 pack rack grab bar, My Manta dash, Stadium shocks front and rear, LTE exhaust, Razer 2 tires, IMS front bumper. My radiator guard. My 14mm stainless steel tie rods. ODI grips, Honda throttle, My stainless steel pegs, My billit stator cover.
www.atvtrickstuff.com
VENFORCER is offline
post #4 of 19 Old 12-17-2006, 03:47 PM Thread Starter
Good luck
dvader
[/b]
my first thought was the CDI (FST)....i had heard this CDI having some issues........thanks i will look closer or just put the stocker back in.....the CDI is only 4 months old....got it straight from Mickey........
Quote:
<div class='quotemain'>
[/b]
VEN
[/b][/quote]
ive traced all the wires and they all look very good..but i can only see the "jacket" that they r in.......i was hoping some simple "fix" was in order....nothing rubbing anywhere.....i just didnt want to split the jackets to expose the wires........
tcat1000 is offline
post #5 of 19 Old 12-17-2006, 06:25 PM
lpwall's Avatar
Good luck
dvader
[/b]
[/b]
VEN
[/b][/quote]
[/b][/quote]
i thought the fst cdi was pretty reliable? wires on the frame check again.
05 White Maier Plastic, Maier Black Hood with Air Scoop, AC Racing Nerf Bars, AC Racing A-Frames, Skid and Swing Arm Plates. Diamond G Tie Rod Ends, Penland Black Tie Rods,Custom Black Bumper and Grab Bar, Custom Seat Cover, Dalton Clutch Cover and Weights, with EPI Maroon Spring (3 shims), Commet Black, or Dalton O/B. EHS Air Box Cover, 10 1 Inch Holes, K&N Air Filter with Outter Ware, Jetted 175F, 180R, Trail Tec Speedo endurance, Trail Tec 1 and 1/8 Bar Clamps with Dashboard Protector, Pep steering stablizer, Black Fasst Flex Handle Bars, ODI Grips, Honda Thumb Mod with Custom Billet Cover, 20 Inch Inline Coolers, HMF Dual Exaust Custom Black Cans, Elkas Sport Front and Rear Shocks. LM-1 Bung Installed. 12 Volt Power Supply Installed. 23x7x10 Kenda Bear Claws Fronts on Black C Series ITP Rims, 25x11x10 Interco Swamp Lites Rears on Black Baja T-9 Pro Series Rims.
Wish list: 730 BBK, FST CDI, Persision Steering Stablizer.
lpwall is offline
post #6 of 19 Old 12-17-2006, 06:38 PM
Pkspawn's Avatar
I don&#39;&#39;t think Vader meant the actual CDI itself.. Just the wires around the CDI..
Unplug the CDI,, turn the Quad on.. See if the fuse blows.. If it does, keep looking.
But I can&#39;t remember ever hearing of a CDI blowing fuses..
Wiggle all the wires.. See if the fuse still blows..
Home of the World&#39;s Slowest and now Ugliest V-Force - Unofficial DragstripTime 4.2 - I was in front of 700mud filming him when he ran 4.4
PK, Inc - Stealing others Ideas since 1999!!</span>
Building the Ultimate Trail Machine: FST 715 BBK, Stage 2.5 cams, Twinair power Flo with 15 holes in airbox. Herrmann Racing A-arms and Anti-Vibe Steering Stem, Fluidyne Radiator, Hiper Wheels with Maxxis Razr2 tires. Fasst Flex Bars, Cycra Pro-Bend Handguards, Hardkor Front Hubs. Honda rear Hubs. AC Racing Wide Grab Bar, IMS Pegs, Heel Guard and Nerfs, Gas Tank. FST CDI, Elka Elite Front & Rear Shocks, 3/4 PRM Skids, THANK YOU FST - Maier Black Plastics , Muzy out - Muzzy Pro in.
On the way: Ultimate Trail and Race Carb Setup
Wishlist: Precision Stabilizer
<span style="color:#000000">Keeping it stupid:
25HP shot of NOS
&#39;08 KFX 700 - The one above looks like a pretzel.
Pkspawn is offline
post #7 of 19 Old 12-17-2006, 06:43 PM
Dvader's Avatar
[/b]
yup--pk`s got the idea---the wires rub from vibration and short out.
Usually right at the turn where it plugs in at the cdi.
Trail//FST730,
Muzzy Superpro.
Dvader is offline
post #8 of 19 Old 12-18-2006, 06:39 PM Thread Starter
[/b]
[/b][/quote]
went out tonight and re-checked all the wires......took off the CDI and noticed that all the wires r free and clear of the frame....and the best part(or worst) is i cant get the fuse to blow .....i tried to wiggle every wire i could get my hands on and the fuse would not blow........this is with the bike not running.....now im wondering if i have a water "gremlin"......blew 3 fuses when it was wet now the bike had a full day to dry out.....any suggestions...and also.....does the V have a "brake" light.....the tail light works but no brake light..........thanks.......
tcat1000 is offline
post #9 of 19 Old 12-19-2006, 06:52 AM
flht3's Avatar
yes.. it has a brake light.. electricial problems are a bitch !!!!
ims rad,roll design pegs,heal guards,carbon pro pipe,barts box,ktm tie rods,elkas w/res,itp,razr2,vampires,,k&n,decal driven graphics,pro taper,acerbis,custom seat,pro aluminium,vens guards,prm,ac,tech spec.......
flht3 is offline
post #10 of 19 Old 12-19-2006, 07:23 AM
Feedback Score: 4 reviews
z-mann's Avatar
Mine did the same thing and it was the foot brake wiring that was shorting out on the frame. Check that asap as I had to replace a section of my wring harness as it burnt up.
04 kfx730- Fundy/amr powered
04 kfx764- " "
04 kfx? BK powered chain drive
08 kfx ? chain drive
04 z400
04 Prairie -BK 840
06 Sportmans 90
04 250ex
99 traxter
08 Teryx
z-mann is offline
2002 kawasaki mule 3000 main fuse blows
2006 3010 mule 30 amp main fuse
2006 3010 mule blowing 30 amp main fuse
4010 kawasaki mule blowing main fuse
700 kawasaki prairie main fuse
700 quad king 30 amp fuse blows
kawasaki mule 2010 battery short fuse
kawasaki mule 610 blows fuse
kawasakimule blowing main fuse when you turn the key
kawasakimuleblowingmainfusewhenyouturnthekey
mule 610 main fuse blows
prarie 300 keeps blowing fuses
where is fusebox for 3010 mule
30amp fuse 250 Kawasaki KFX700 V-Force 1 07-02-2008 08:22 PM
blowing fuse vtprairie03 Kawasaki Brute Force/Prairie/Bayou 38 09-11-2007 05:47 PM
Ignition key switch blowing 30 amp fuse instantly tom97zr2 Kawasaki KFX700 V-Force 2 03-12-2007 10:06 PM
30 amp blown fuse BAM Kawasaki KFX700 V-Force 6 10-12-2006 09:15 AM
Keep blowing fan fuse... Licken2 Kawasaki Brute Force/Prairie/Bayou 3 08-15-2004 10:44 PM
