Primary Clutch Bolt Broke
This is a discussion on Primary Clutch Bolt Broke within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; I need some big help I was taking my primary clutch bolt out to install a clutch kit in doing this i noticed that the ...
Old 02-13-2007, 07:10 PM   #1
Feedback Score: 1 reviews
hensons700v's Avatar
View hensons700v's Photo Gallery(0)
Default
I was taking my primary clutch bolt out to install a clutch kit in doing this i noticed that the bolt was way harder then last time to take out 2 seconds later it snapped off with about half of the threads left in it
How can i get the rest of this bolt out
06 Kfx 800
stage 2 cams
big kev drag pipe
87 Tecate 4
hensons700v is offline   Reply With Quote
Old 02-13-2007, 07:14 PM   #2
Feedback Score: 2 reviews
BossMan's Avatar
View BossMan's Photo Gallery(1)
Default
Where exactly did it break ? Threads in the crank. Drill pilot hole & use an easy out.
05 KFX 700-FST 715
07 Brute Force 750i Black
Georgia
BossMan is offline   Reply With Quote
Old 02-13-2007, 07:24 PM   #3
Default
Well i would guess that it has half inch of threads still left on the bolt
But it broke off up in there deep with only like other half inch of threads still left in the bike
Cant find an easy out long enough tried calling a few places for them
never used one
so dont know how to extend an easyout to that long if it is possible
06 Kfx 800
stage 2 cams
big kev drag pipe
87 Tecate 4
Old 02-13-2007, 07:38 PM   #4
Banned
View MetalAlien's Photo Gallery(0)
Default
sell the bike, it will be less frustrating than fixing that!
MetalAlien is offline   Reply With Quote
Old 02-13-2007, 07:43 PM   #5
Jim
Jim's Avatar
View Jim's Photo Gallery(0)
Default
Take a bolt the same thread center drill it in a lathe so you hit center hold it strait with a drill the bolt you screw in is the fixture center point ....easy out it ...if its acts like its two much and can break the easy out jack the bike up on the left side ...take small propane torch heat the bolte bolt up at 200% dont damage the seal and melt some bees wax in it...let it cool and then easy out it...it will come right out....now let me explain why this happpens ...kawie puts that bolt in dry and it stretches...like .040 ..needs .010 ....it can bottom out ...you need to use a drop of oil on that bolt and and torque it at 66 ft # and lube the washer...dry bolts dont torque right with dry washers...Take turtle wax and wax that taper on the crank and let it dry...wipe it off ...clutch will never stick to the taper but wont slip...this works one 100hp units ...much more hp we will be keying them with a woodruff key...meanwhile thats protocol and it works...JH
Custom or stock Kawie CVT clutches all applications.
In stock complete bushing kits to your door for the do it yourself guys.
Custom Tailored weight reduction For your stock weights to out perform other profiles.
TRUE SFI Material Kevlar 2 pounds of protection of saftey blanket for the high horsepower engines That exceed O.E.M. Rpms and HP.
Custom diameters on needle rollers available From stock dia .630 up to .750 for (last chance units.)
I AM THE FIRST SUCCESSFUL ORIGINAL INNOVATER OF THE NEEDLE MOD SPIDER AND NEEDLE WEIGHT AND TRUE SFI RATED BALLISTIC PROTECTION FOR THIS PARTICULAR TYPE CVT.
We are In the classifieds in Dirt Wheels Magazine.
All major credit cards accepted.. vast inventory, and reasonal turnaround time. On shelf units with core exchange for super speedy service if needed.
C.A.Z. hardened stands micropolished for anti bind with impregnated buttons for less streaking and wear.
Trail or full race, Specific build for your HP output and wants.
We DO make you faster.
Jim is offline   Reply With Quote
Old 02-13-2007, 09:29 PM   #6
bonestockklx's Avatar
View bonestockklx's Photo Gallery(0)
Default
If you can get the clutch off, there might be enough bolt sticking out of the crank to grab witha GOOD pair of channel locks ( like Knipex). Don't forget that the bolt is a left hand thread also. Don't even bother with an easy out. it is just going to break off and you will have even more of a mess on your hands. Ezy outs are for right handed threads so don't even try, even if you could find one of the ellusive left hand ezy-outs. Try using a three jaw puller to get the clutch off.
Jim, woodruff keys are for timing and locating purposes only. They offer very little or no resistance to slipping. If a clutch or flywheel wants to slip, it will shear a woodruff key smooth of without hesitation. That is why there isn't one on there already. The clutch is not timed with any other componant. No need for a key. The only reason your old chevy or ford v-8 is keyed at the end of the crank is because of the timing mark on the harmonic ballancer.
It's completely stock. Really, its just ran like that since day one.
This forum really needs a spell checker
bonestockklx is offline   Reply With Quote
Old 02-13-2007, 09:50 PM   #7
BossMan's Avatar
Default
When I take my clutch off I insert the puller bolt & totque down on it, them smack the bolt it with a dead blow hammer & it pops right off.First time I pulled it I thought oh Chit I broke it, sounded terrible.
05 KFX 700-FST 715
Georgia
Old 02-13-2007, 10:07 PM   #8
Banned
Default
Oh the horror show! Talk about a scarey thing to happen... I know I would have freaked out! good luck, I hope someone on here can help you.
Old 02-13-2007, 10:18 PM   #9
Enigma's Avatar
View Enigma's Photo Gallery(0)
Default
I have never had this happen on my ATV but I have had bolts break off deep inside the hole where you cant get at them.
I ended up taking them to a small welding/fabrication shop I do biz with. They got it out. Might be worth talking to them if you know of a reputable outfit.
Enigma is offline   Reply With Quote
Old 02-13-2007, 10:38 PM   #10
Jim
Jim's Avatar
Default
Make your own easy out you have a center to go off of clutch or not ..reverse grind it 4 corners 5*angle...or cut it off we sell clutches,,Why do we run two crank keys to run a blower at 30 psi..,yes you will see keyed clutches here before long they are galling with 100hp and up ask any engine builder ...sorry for your problem and a viable reply ...I understand your plight sir...sorry..it will come out take your time and think....JH
You may not post new threads
You may not post replies
Primary Clutch bolt PIPO Wanted 7 10-21-2008 02:26 PM
broke a clutch bolt atvstevo1337 Kawasaki KFX700 V-Force 10 05-20-2007 10:57 AM
Primary Clutch Center Bolt 700Bullet Kawasaki KFX700 V-Force 2 03-10-2007 10:45 AM
Broke bolt stuck clutch Jim Kawasaki KFX700 V-Force 6 02-16-2007 01:56 PM
Primary Clutch Bolt Broke!!! PrairieFrisbee Kawasaki KFX700 V-Force 10 05-07-2004 04:20 PM
