This is a discussion on 36mm Carb Jetting within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; 730cc proted heads stock valves cwr 450 lift cams big gun rev box drag pipe stock unported intake boots 42 piolets 130-135 jets i believe ...
| Kawasaki KFX700 V-Force Kawasaki's big-bore, V-twin sport machine! |
LinkBack | Thread Tools | Display Modes |
#11 |
Quote:
730cc
proted heads stock valves cwr 450 lift cams big gun rev box drag pipe stock unported intake boots 42 piolets 130-135 jets i believe the reason for so many diffrant jettings are the carbs not all have the same type of 36mm carbs and not all have the same needles so it kinda makes it a guessing game [/b]
My Marble White V: K&N filters w/Outerwear, AMR CDI, AMR Racing coils, Dalton OR/BL Spring, VFJ stage 2 Clutch , DPK 58g weights, Titanium Clutch cover bolts, Muzzy Exhaust - Jet-Hot Extreme Coated, PRM Desert Grab, Kawie Front Bumper, IMS Foot Pegs & Heel Guards, AC Nerf Bars, Maier CF Scoop Hood, Kawie Gripper Seat Cover, Royal Purple 15-W40 Motor Oil, ESR Temp Gauge, Crankcase Vent Mod, Fluidyne Radiator, Two Aluminum In-Line Coolers, LED Tail Light, Precision steering stabilizer, Maxxis Razr 2's on Black C-Series rims, 24" Extremes 9 Paddle & 21" Buffed Mohawks on Polished C-Series rims, 22" Innova Racers (rims undecided), ASR SS +2" Brake Lines, ASR +2" A-Arms & Tie Rods, All Ball's Racing Tie Rod End's, Durablue 2"+2" Eliminator Axle, G-Force +3.5" Extended Hubs, Houser Black +2" steering stem & Anti-vibe Fat Bar Mounts, Black Pro Taper Couture Fat Bars, Elka's Race Front & Rear, FPS800 BBK, Nikasil cylinders, Fully ported, Trail/Race cams, 36mm F4 carbs , UPP 36mm Intakes, Braided Fuel lines, Black & Silver IMS Powermadd Star Hand Guards, LC1 Digital Air/Fuel Gauge, Polished Shorty Shifter, Moose Billet Throttle, Ven's +4" Swing arm Ext., Everything powdercoated Black & White, Dyno Tuned @ 64.5 RWHP |
| Sponsored Links | ||
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free! |
#12 |
Feedback Score: 1 reviews
mine are the real small ones on the tip id say the last 3/8" or the needle is less the half the diamiter then the rest of the needle
2008 brute force black and red high lifter springs for about 1.5" of lift 27" mud light xl's should have gone bigger 2005 kfx700 Project "GRAVE DIGGER" In memory of Jimmy Cox gone 04/06/06 But never Forgotten |
#13 |
Quote:
<div class='quotemain'>
730cc proted heads stock valves cwr 450 lift cams big gun rev box drag pipe stock unported intake boots 42 piolets 130-135 jets i believe the reason for so many diffrant jettings are the carbs not all have the same type of 36mm carbs and not all have the same needles so it kinda makes it a guessing game [/b] ![]() [/b][/quote] Hey did you ever get that midrange lean problem figured out? I never did on mine but want to try 36's again this summer. Just curious if you found out anything.
#14 |
It wasnt the carbs at all, it was my porting that was messed up. Someone, (I'm not calling names) put my heads on a flow bench and then filled in the intake ports to make them flow better (higher #'s on that damn machine) and more even. So after that stuff was ground out of my intake ports it was fixed. I kinda new it wasnt the carbs or any tunning problems for that matter because I had been using the 36's before the problem and they worked perfect.
#15 |
FST 800
No Porting Stage 3 cams Supertrapp IDSX full exhaust Dyna CDI Stock Intake boots Stock Airbox (modified to fit on 36mm carbs) with 23 hole lid 36's w/ #42 pilots 1 Shim Per Needle 128ft /130rr @200 ft Tuned on a Supertrapp Dyno (supposedly made 72.7 RWHP)
'04 FST Twin Peaks 800 AMR ported heads/FST Stage 3 cams/36mm carbs/LTE dual exhaust/VFJ Stage 4 primary & lightened secondary/Dyna Programmable CDI/FST intakes/lightened flywheel/Mike Walker oil cooler/Elka rear shock & strut springs/AC front bumper/PRM rear grab bar Happy trails...
#16 |
Feedback Score: 6 reviews
800 bbk stg3 cams porting twin hmf 36mm carbs with 2 inch adapter between boots and carbs gtyr filter 188f 192r and still nosing over a bit up top waiting on more jets
#17 |
Feedback Score: 5 reviews
[/b] That seems a bit much for main jetting.
"The Untouchable" |
#18 |
Adding the 2" rise to the intake will want more fuel like he is saying and it worked pretty good when I tested but never really finished testing,hope it works out for you.
06 Brute 650 665 FST Stage 3 Cams |
#19 |
bought the carbs of vtprarie03 they had 155f 160r couldnt go over half throttle backfiring and the more i crept up in size the better it gets i rekon it will pan out close to 192f 195r but i dont know how much dif it makes if at all but im only 100 feet above sea level
#20 |
[/b] hmm my intakes are atleast a two inch rise maybe more on 36's Glenn had to port my air box cover so the carbs would fit Im at 135/138 with ported heads though. 850 above sea level.Quote:
[/b]
"The Untouchable" |
Back to Top
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 36mm carb filter # | vtprairie03 | Kawasaki KFX700 V-Force | 8 | 02-27-2009 12:47 PM |
| 36mm carb needles | bb 650 | Wanted | 2 | 08-27-2008 12:52 PM |
| 36mm carb pilots | fastfatboy | Kawasaki KFX700 V-Force | 10 | 05-11-2008 04:07 PM |
| 730's WITH MUZZY - 36mm CARB JETTING????? | rpm | Kawasaki KFX700 V-Force | 25 | 05-08-2008 03:29 PM |
| 36mm Carb air/fuel | bb 650 | Kawasaki KFX700 V-Force | 3 | 04-19-2007 02:27 PM |
Looking for information on other ATV Manufacturers? Head on over to visit our friends on these other forums specializing in the following: Kawasaki ATV - Can-Am ATV - Polaris ATV - Suzuki ATV - Yamaha ATV - Honda ATV - KTM ATV - Yamaha Raptor - Can-am DS450 - Kawasaki KFX 450 - Suzuki LTR 450 |
