36mm Carb Jetting
This is a discussion on 36mm Carb Jetting within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; <div class='quotemain'> Adding the 2" rise to the intake will want more fuel like he is saying and it worked pretty good when I tested ...
Old 12-13-2008, 03:43 AM   #21
Feedback Score: 7 reviews
Psi-700's Avatar
View Psi-700's Photo Gallery(6)
Default
Adding the 2" rise to the intake will want more fuel like he is saying and it worked pretty good when I tested but never really finished testing,hope it works out for you.
[/b]
hmm my intakes are atleast a two inch rise maybe more on 36's Glenn had to port my air box cover so the carbs would fit Im at 135/138 with ported heads though. 850 above sea level.
Quote:
bought the carbs of vtprarie03 they had 155f 160r couldnt go over half throttle backfiring and the more i crept up in size the better it gets i rekon it will pan out close to 192f 195r but i dont know how much dif it makes if at all but im only 100 feet above sea level
[/b]
If you have bits a #48 drill bit is a 195 main jet.......
[/b][/quote]
yes will try the 48 bit in the morning my neighbours hate me at the moment tooooo many test runs up and down the street exspecially wen they started at 4 in the morning 2 days ago
rodeo 383 chev skid
http://www.facebook.com/v/34065074572
just need me carbys and its finished
Psi-700 is offline   Reply With Quote
Old 12-25-2008, 04:44 PM   #22
Psi-700's Avatar
Default
[/b]
[/b]
[/b][/quote]
[/b][/quote]
went to 192f 195r cant really tell diference without dyno,mite even try to find a 2nd hand lm1
rodeo 383 chev skid
Old 12-25-2008, 05:01 PM   #23
Feedback Score: 5 reviews
View OHVFORCE's Photo Gallery(0)
Default
What size jets do you have that you can try? smallest to the largest?
OHVFORCE is offline   Reply With Quote
Old 12-25-2008, 07:45 PM   #24
Psi-700's Avatar
Default
[/b]
ive tryed all the way from 128 to were it is now wich feels real good so im happy
rodeo 383 chev skid
Old 01-04-2009, 03:16 PM   #25
Psi-700's Avatar
Default
can anyone give me an idea were to start with the jetting on 36s on a 700?
bike has twin monster pipes, cdi, 6 degree key,almond spring,
rodeo 383 chev skid
Old 01-11-2009, 01:11 AM   #26
Feedback Score: 15 reviews
Camo's Avatar
View Camo's Photo Gallery(0)
Default
155/158
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim
Camo is offline   Reply With Quote
Old 02-26-2009, 04:49 PM   #27
greenguyshrek's Avatar
View greenguyshrek's Photo Gallery(0)
Default
I just got the pro circuit t4 dual exhaust. The only other mods i have is the k&n filter and the clutch spring. What jetting should i run, cause i just called pro circuit and they didn't know. I also want to do the air box mod, dose anyone have the link or tell me how its done?
thanks
greenguyshrek is offline   Reply With Quote
Old 03-27-2009, 12:59 PM   #28
Eforce13's Avatar
View Eforce13's Photo Gallery(0)
Default
This section of the forum is not for stock carbs.^^^^^
My Marble White V: K&N filters w/Outerwear, AMR CDI, AMR Racing coils, Dalton OR/BL Spring, VFJ stage 2 Clutch , DPK 58g weights, Titanium Clutch cover bolts, Muzzy Exhaust - Jet-Hot Extreme Coated, PRM Desert Grab, Kawie Front Bumper, IMS Foot Pegs & Heel Guards, AC Nerf Bars, Maier CF Scoop Hood, Kawie Gripper Seat Cover, Royal Purple 15-W40 Motor Oil, ESR Temp Gauge, Crankcase Vent Mod, Fluidyne Radiator, Two Aluminum In-Line Coolers, LED Tail Light, Precision steering stabilizer, Maxxis Razr 2's on Black C-Series rims, 24" Extremes 9 Paddle & 21" Buffed Mohawks on Polished C-Series rims, 22" Innova Racers (rims undecided), ASR SS +2" Brake Lines, ASR +2" A-Arms & Tie Rods, All Ball's Racing Tie Rod End's, Durablue 2"+2" Eliminator Axle, G-Force +3.5" Extended Hubs, Houser Black +2" steering stem & Anti-vibe Fat Bar Mounts, Black Pro Taper Couture Fat Bars, Elka's Race Front & Rear, FPS800 BBK, Nikasil cylinders, Fully ported, Trail/Race cams, 36mm F4 carbs , UPP 36mm Intakes, Braided Fuel lines, Black & Silver IMS Powermadd Star Hand Guards, LC1 Digital Air/Fuel Gauge, Polished Shorty Shifter, Moose Billet Throttle, Ven's +4" Swing arm Ext., Everything powdercoated Black & White, Dyno Tuned @ 64.5 RWHP
Eforce13 is offline   Reply With Quote
Old 06-03-2009, 08:00 PM   #29
Feedback Score: 6 reviews
Moby's Avatar
View Moby's Photo Gallery(0)
Default
Looking for jetting opinions on a 765 with stage 3's, stock intakes, and LTE's. I'm at 1200'
Moby is offline   Reply With Quote
Old 06-03-2009, 08:05 PM   #30
Default
start 140ish main jets 40-42 pilots
kfx700
You may not post new threads
You may not post replies
36mm carb filter # vtprairie03 Kawasaki KFX700 V-Force 8 02-27-2009 11:47 AM
36mm carb needles bb 650 Wanted 2 08-27-2008 11:52 AM
36mm carb pilots fastfatboy Kawasaki KFX700 V-Force 10 05-11-2008 03:07 PM
730's WITH MUZZY - 36mm CARB JETTING????? rpm Kawasaki KFX700 V-Force 25 05-08-2008 02:29 PM
36mm Carb air/fuel bb 650 Kawasaki KFX700 V-Force 3 04-19-2007 01:27 PM
