36mm Carb Jetting
This is a discussion on 36mm Carb Jetting within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; With stage 2's with a full Pro Circuit I'm at 150-152 w/ two shims and 42 pilots....
Old 06-03-2009, 08:22 PM   #31
Wild650's Avatar
View Wild650's Photo Gallery(0)
Default
FST 765 w/ stage 2 cams, AMR trail porting, F4 36mm carbs, ProCircuit full pipe, dyna CDI, GTYR filter set up, stage 3 clutch w/ spider mod, flexx bars, shindy tach,
Wild650 is offline   Reply With Quote
Old 11-15-2009, 07:02 PM   #32
Feedback Score: 18 reviews
05-BF-750's Avatar
View 05-BF-750's Photo Gallery(4) Send a message via AIM to 05-BF-750
Default
I just bought a set of 36mm carbs and I need to know where to start with jetting. I have an LM-2 so I'm just looking for a starting point. My engine is stock internally, I have a Muzzy Super Pro, home made crossover intake, and GYTR filter.
Also what do I do about the choke? I know I have to reach down and choke it by hand by what do I use as the choke? Is there a plunger I can buy or what..? Thanks!
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
05-BF-750 is offline   Reply With Quote
Old 12-20-2009, 11:49 AM   #33
DDQuader's Avatar
View DDQuader's Photo Gallery(0) Send a message via MSN to DDQuader
Default
Did some reading and drilled jets with a 5/64th drill bit. Goes like a MF now!!!
If you have to ask the method of my madness you will never understand!!!
DDQuader is offline   Reply With Quote
Old 02-04-2010, 06:59 PM   #34
Feedback Score: 1 reviews
trainhorns's Avatar
View trainhorns's Photo Gallery(1)
Default 36 carb springs
how much are you cutting your springs on your 36s
EMPTY POCKETS RACING
ALL THROTTLE NO BOTTLE
trainhorns is offline   Reply With Quote
Old 02-04-2010, 07:11 PM   #35
trainhorns's Avatar
Default carb springs for 36s
How much do you need to cut your springs on your 36s.
Old 04-02-2010, 02:43 PM   #36
Feedback Score: 6 reviews
The Speed Force's Avatar
View The Speed Force's Photo Gallery(2)
Default
Trainhorns, I didn't have to cut my springs at all.
The Speed Force KFX800™
FST800, Stage 3's, Muzzy Pro, VFJ Stage 3, 36's, EPI Maroon, MSA Wheels, Duro Scorchers, Powdercoated Everything. Proud winner of August '09 KOTM and lucky winner of December '09 KOTM.
The Speed Force is offline   Reply With Quote
Old 04-02-2010, 04:03 PM   #37
Feedback Score: 4 reviews
HEATHEN 730's Avatar
View HEATHEN 730's Photo Gallery(0) Send a message via AIM to HEATHEN 730
Default
I think 4 coils get cut off.
2004 KFX730
2003 Predator 90
HEATHEN 730 is online now   Reply With Quote
Old 04-30-2010, 07:21 PM   #38
Default
11.5 FPS 730
FST Stage 3 cams
Ported heads
FST UPP intakes
Muzzy Super Pro
Dyna CDI
36's with Yamaha filter
2 shims on each needle
42 pilots
Had a 132 and 135 in it, lean with mid to upper 13's on meter since switching intakes. Would a 135/137.5 or 140 cut it, or should I go 140/145?
2004 KFX730
2003 Predator 90
Old 05-02-2010, 10:43 PM   #39
DDQuader's Avatar
Default
820 Fundy, 36mm Keihn carb, fundy porting on heads, trail/race cam's, HPP intakes,FMF exhaust 2250 ft elevation. 180/182 main jets, 38 slow jets, no shims yet because i havnt had a chance to take it out with the LM1 meter. On idol it is 13.4-14.1 air/fuel. I will post later when i have some results.
Old 07-30-2010, 11:33 PM   #40
ItsAllCreated's Avatar
View ItsAllCreated's Photo Gallery(0)
Default
how come I need big-ass jets in my stock carbs with x-over intake ...and alot of you guys are running smaller jets in you 36mm carbs??? I have 7/64 in them now (its a little rich, but better than a little lean)
I would think since 36mm carbs flow more air, they'd need even bigger jets?
I'm temped to try my 7/64 jets in my 36's
~StephenB
08- BruteForce 750 w/ Muzzy Pro Exhaust System, DASA 38mm TB's, & MSD Fuel/Ignition Controller
03- Prairie w/ 700 motor, FST 11.5:1 Std Bore Pistons, Fundy Race Cams, Rocker Mod, Dyna CDI, FST Intakes, 36mm Carbs, Muzzy Exhaust System, VFJ Stage2 Primary Clutch, VFJ Race Secondary Clutch, DS Customs +7 Swinger
ItsAllCreated is online now   Reply With Quote
kfx700
You may not post new threads
You may not post replies
36mm carb filter # vtprairie03 Kawasaki KFX700 V-Force 8 02-27-2009 11:47 AM
36mm carb needles bb 650 Wanted 2 08-27-2008 11:52 AM
36mm carb pilots fastfatboy Kawasaki KFX700 V-Force 10 05-11-2008 03:07 PM
730's WITH MUZZY - 36mm CARB JETTING????? rpm Kawasaki KFX700 V-Force 25 05-08-2008 02:29 PM
36mm Carb air/fuel bb 650 Kawasaki KFX700 V-Force 3 04-19-2007 01:27 PM
