Has anyone made a choke cable work on 36's. I don't know if all the exhausts are bent like Bigguns but mine are real hard to get around without burning yourself.
[/b]
I was planning to put a choke cable on my 36s...in fact, I bought a cheap cable from a lawnmower shop for this purpose. But then I decided not to install the cable after I mounted the carbs and found out that I can easily reach the choke lever on the carbs by hand. I have a supertrapp pipe and it is low enuf that I don't worry too much about burning my hands when the motor is cold.
I put 42 pilots in my 36mm carbs, so I don't need the choke once the motor is warm.
If you do mount a cable on the carbs, it appears you will have to route the cable forward and then turn 90 degrees to the right side of the motor. Good luck with that.
[/b]
dave i can tell your not goin to get much done at work the next few months are ya. its a good thing we dont live close to each other we would have some ungodly creations
[/b]
I was running the Big Guns too and took those off and went back to my modified stock... No problem now reaching down there.
Related Threads
Kawasaki ATV Forum
971.2K posts
52.3K members
Since 2002
