700 kit with stock carbs?
This is a discussion on 700 kit with stock carbs? within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Hi guys! I haven’t posted in a while, but I am back and looking to tear into the motor a little. I have a question ...
Old 02-15-2008, 06:46 AM   #1
Chris07's Avatar
View Chris07's Photo Gallery(0)
Default
Hi guys! I haven’t posted in a while, but I am back and looking to tear into the motor a little. I have a question regarding jetting the stock carbs on a 700 kit. From what I remember once you get in the 190’s on jets it doesn’t seem to give it much more fuel. With my setup now I am already 185/187. To those with 700 kits, what type of jetting are you running on stock carbs? Are you drilling the jets? I am a little scared to spend $500 on a kit and not be able to tune it right on the stock carbs.
2005 KFX700
Media
*Yoshi TRS Duals *Twin-Air Pro flow w/ 12-1" holes *HotCams
*Keihin Jetting: 195f/192r * Blue Spring *Stage 3 Clutch Machining
*Works Tripple Rate Front Shocks *Stadium Suspension Rear Shock w/rez
*Galfer SS brake lines *PRM Bumper *PRM six-pack rack
*Pro Armor Nerfs *Trail Tech Speedo *Twin 55w Aux lights
2008 Raptor 700R
*PCIII *Pro design intake *White Brothers XRC slip-on
*Trail Tech Vapor *Pro-alum bumper *iRazr
Chris07 is offline   Reply With Quote
KawieRiders.com is the premier Kawasaki ATV Forum on the web. Registered Users DO NOT see these ads. Please Register - It's Free!
Old 02-15-2008, 06:49 AM   #2
Feedback Score: 2 reviews
Dvader's Avatar
View Dvader's Photo Gallery(0)
Default
[/b]
You`ll end up drilling jets.
At sea level>5/64ths to 3/32nds will be very close.
2 04 v`s
Drag/////////trail
FST715///////FST730
10* key///////6*key
AMR porting,,stock porting
66hp----------62hp
fst Stg3cams//fst stg2cams
both cluthes cut [vfjstg3 w/spidermod]
hotseatviolet p360 wieghts//daulton blue 2-56`s
cut secondary/stock secondary
10"extended swinger///stock swinger
Muzzy Superpro`s all around.
elka`s on both plus many add on`s
built and tuned by VFJ at
interstate motorsports
RIDE FOREVER AUTODOC
Dvader is offline   Reply With Quote
Old 02-15-2008, 06:49 AM   #3
Feedback Score: 9 reviews
RAWDAWG700's Avatar
View RAWDAWG700's Photo Gallery(9)
Default
A 700 kit with stage 2 cams and 12 holes in air box lid jets drilled 3/32 should be almost spot on for where you are usually stock pilots and no shims under the needle either
04 AMR 840 JUICED UP (?)
08 FUNDY 700 (CHERRY PIE)
06 HYBRID 730 JUICED UP (BLUE BALLS)
RAWDAWG700 is offline   Reply With Quote
Old 02-15-2008, 07:06 AM   #4
Feedback Score: 19 reviews
g-rider's Avatar
View g-rider's Photo Gallery(0)
Default
/\/\/\/\/\/\/\/\ What he said, should be very close.
2008 Teryx
Muzzy, Dyna, Dalton Clutch kit, Hunterworks kit, Uni filter with billet adapter, TRP Water Pump, Highlifter Temp Gauge, ITP SS312's, 26" GBC Dirt Commanders, Warn winch, Aluminum roof
g-rider is offline   Reply With Quote
Old 02-15-2008, 07:08 AM   #5
Chris07's Avatar
Default
I was hoping I didn’t have to drill jets, but I’ll probably run a stage 1 cams as I do not want to do valve springs. I believe stage1 cams are the only ones you can run w/o springs… The 5/64ths to 3/32nds should be a good range with stage 1 cams?
2005 KFX700
Media
2008 Raptor 700R
Old 02-15-2008, 07:11 AM   #6
View mudman's Photo Gallery(2)
Default
i know on the old fst stage one cams you need valve springs- not so sure about the new stage ones.
05' Prairie FST 730
mudman is offline   Reply With Quote
Old 02-15-2008, 07:12 AM   #7
Chris07's Avatar
Default
[/b]
I think the new kit they have doesn't, but I am not 100% sure on that.
2005 KFX700
Media
2008 Raptor 700R
Old 02-15-2008, 07:13 AM   #8
g-rider's Avatar
Default
New Stage 1's don't need valve springs. I don't know of anyone who has run the new Stage 1's but I would say you would probably still be close with 5/64 or 3/32.
2008 Teryx
Old 02-15-2008, 07:31 AM   #9
Feedback Score: 3 reviews
asnowmobiler's Avatar
Default
The stage ones that I had needed less fuel then the stage threes.
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,Dirty South +5 swingarm,39mm carbs, Looney Tuned Exhaust, programmable Dyna,front Elkas,30 shot of Boon,Brute Force Flywheel,Flexx bars,Rox Risers,ODI grips,ECT.
AMR 330 347 6800
Old 02-15-2008, 07:55 AM   #10
Chris07's Avatar
Default
[/b]
I just realized I'll probably need the catch can also. I assume none of these kits come with one.
2005 KFX700
Media
2008 Raptor 700R
Bookmarks
You may not post new threads
You may not post replies
Stock Carbs Oakley For Sale 2 05-22-2009 04:26 AM
stock carbs paulg Kawasaki KFX700 V-Force 2 12-12-2007 08:05 PM
Stock carbs motomike211 Wanted 3 10-16-2007 04:09 PM
Stock V Carbs V--NASTY Wanted 3 04-22-2007 08:53 PM
Stock carbs krewzlo Kawasaki KFX700 V-Force 3 01-17-2007 06:23 PM
