03-05-2008, 10:35 AM
#1
Feedback Score: 9 reviews
Doe s anyone know the part number for the filter and outerware?
FOUR STROKE TECH 730
Special thanks to the following:
Four Stroke Tech
ATV Trick Stuff
Big Kevs Performance
Interstate Motorsports
Dasa Racing
Dick's ATV
Monkey Motorsports
03-05-2008, 10:54 AM
#2
V-Force Green 04 FST 700 SS,R&D Valve Springs w/Ti Retainers(347-K),FST Stage 3 Race Cams,05 Rocker Mod,Mild Porting,Muzzy Pro w/02 Bung & LC1 A/F Gauge,FST CDI,AMR Monster Coils,JT temp gauge,WIX 51365 Oil Filter,Lucas 20w-50,Cooling Muzzy Fan Blade PN# HT-H17,Razr-2's 23"f 22"r,Tag T2 bars,IMS Front Bumper,IMS brake pedal,Stage III Clutch Work,Dalton Clutch Cover,Dalton O/B Spring, 2- shim- Weights 54.9g,450R LED Tail light,Bitchin Seat Cover,37's,GYTR Blue K&N w/GYTR Blue Outwear,Pilots #20,Needles 1/2 Shimmed,Mains F 162.5/R165,Plug Boot Mod,ODI Rogue Grips w/Green clamps&Thug Plugs,SRP Steering Damper,Stadium Front Shocks,Maier Carbon Hood,FST Stator Cover,Duncan Racing SS Green Brakelines
03-05-2008, 10:57 AM
#3
Feedback Score: 15 reviews
The GYTR outerwear part number is GYT-5LP95-11-BL...the BL is the color. The filter is GYT-5LP95-01-10.
OrangeCrush RR Boosted / Nitrous Injected Duner Fundy Performance Sports 1-902-893-(DYNO) 3966 1) Bench Racers 2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST JH MACHINE CUSTOM ROLLER CLUTCH
03-05-2008, 11:06 AM
#4
Supporting Vendor
Feedback Score: 7 reviews
which one fits the better?? the foam or the K&N style
03-05-2008, 11:22 AM
#5
K&N--- The foam filter has two metal things inside of it that makes it hard to get over the velocity stacks.
03-05-2008, 12:46 PM
#6
Feedback Score: 2 reviews
The Foam UNI filter that I bought has too big of openings to even clamp it on to a set of 36's.
KFX/Fundy730 - Big Valves/36mm Carbs/BOSS NOSS NOS/Oval MUZZY Pro/FST CDI/Dalton OB/JH Machine Custom Clutch/5" Extended Swingarm/25" 10 paddle Edge's/Elkas/Race Cut Maier BLACK Plastic
King Quad 700
08 Raptor 700 (Wife's)
Motorsports Artwork & Photography By RPM Art
"I DIDN'T HIT THE BUTTON....... I PROMISE."
03-05-2008, 12:47 PM
#7
The real K&N is probably cheaper than they GYTR and the are made the exactly the same. JUst woundering why most buy the GYTR instead of the K&N? K&N # is RU-4720
My Marble White V: K&N filters w/Outerwear, AMR CDI, AMR Racing coils, Dalton OR/BL Spring, VFJ stage 2 Clutch , DPK 58g weights, Titanium Clutch cover bolts, Muzzy Exhaust - Jet-Hot Extreme Coated, PRM Desert Grab, Kawie Front Bumper, IMS Foot Pegs & Heel Guards, AC Nerf Bars, Maier CF Scoop Hood, Kawie Gripper Seat Cover, Royal Purple 15-W40 Motor Oil, ESR Temp Gauge, Crankcase Vent Mod, Fluidyne Radiator, Two Aluminum In-Line Coolers, LED Tail Light, Precision steering stabilizer, Maxxis Razr 2's on Black C-Series rims, 24" Extremes 9 Paddle & 21" Buffed Mohawks on Polished C-Series rims, 22" Innova Racers (rims undecided), ASR SS +2" Brake Lines, ASR +2" A-Arms & Tie Rods, All Ball's Racing Tie Rod End's, Durablue 2"+2" Eliminator Axle, G-Force +3.5" Extended Hubs, Houser Black +2" steering stem & Anti-vibe Fat Bar Mounts, Black Pro Taper Couture Fat Bars, Elka's Race Front & Rear, FPS800 BBK, Nikasil cylinders, Fully ported, Trail/Race cams, 36mm F4 carbs , UPP 36mm Intakes, Braided Fuel lines, Black & Silver IMS Powermadd Star Hand Guards, LC1 Digital Air/Fuel Gauge, Polished Shorty Shifter, Moose Billet Throttle, Ven's +4" Swing arm Ext., Everything powdercoated Black & White, Dyno Tuned @ 64.5 RWHP
03-06-2008, 03:37 AM
#8
Thanks E just what I was looking for
Four Stroke Tech
ATV Trick Stuff
Dasa Racing
Dick's ATV
Monkey Motorsports
03-06-2008, 05:13 AM
#9
your welcome!
03-06-2008, 05:24 AM
#10
The k&N filter is about the same as the gytr but the k&n outerwear was more than double the gytr prefilter. I learned the hard way and ordered both from k&N. <_< Atleast it matches though.
up next...????
03 prairie 650...stage 2's, high comps, muzzy
08 RED TERYX sold
06 team green prairie sold
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
» Site Navigation |
