Drill bit size to jet # conversion chart
This is a discussion on Drill bit size to jet # conversion chart within the Kawasaki KFX700 V-Force forums, part of the Kawasaki ATV Performance / Maintenance / Technical category; Is there any way to make a chart that converts drill bit size to Main Jet size. I found THIS chart that gives the measurements ...
Old 05-09-2008, 11:50 AM   #1
Feedback Score: 2 reviews
BossMan's Avatar
View BossMan's Photo Gallery(1)
Thumbs up
Is there any way to make a chart that converts drill bit size to Main Jet size. I found THIS chart that gives the measurements of drill bits. Anyone know how to convert this to Jet size.
I want to ride this weekend & need a 178-180 jet. Installed a Muzzy on my brute & it's way lean. Just wondering so I dont have to sit on it all weekend & go Vrooooooom Vrooooooom
05 KFX 700-FST 715
07 Brute Force 750i Black
Georgia
BossMan is offline   Reply With Quote
Old 05-09-2008, 01:02 PM   #2
Hebert Racing's Avatar
View Hebert Racing's Photo Gallery(0)
Default
Check with Gauge, he may know.
04 Team Green 700 ,Adapt graphics kit, VENFORCER'S swingarm extension,VENFORCER'S tie rods,CRJ lowering kit,Renthal Fatbar,ODI Grips,Maier Racing hood,VFJ stage 3 clutch,Muzzy Pro ceramic coated,15 hole mod,Twin Air airfilter ,stock needles with shims,185F/182R jetting,carb coolant lines removed, mini ms mod, carb slides polished, carb springs cut, White Brothers front bumper, PRM grab bar, Comet black, Elka suspension, ITP rims, VENFORCER'S coolant line, Performance ATV lug nuts, and Hebert Racing detail job
Hebert Racing is offline   Reply With Quote
Old 05-09-2008, 02:31 PM   #3
Eforce13's Avatar
View Eforce13's Photo Gallery(0)
Default
I think I just seen a chart on HL site that somebody posted in the brute and prairie section about a week ago, I knew I should have saved it.
My Marble White V: K&N filters w/Outerwear, AMR CDI, AMR Racing coils, Dalton OR/BL Spring, VFJ stage 2 Clutch , DPK 58g weights, Titanium Clutch cover bolts, Muzzy Exhaust - Jet-Hot Extreme Coated, PRM Desert Grab, Kawie Front Bumper, IMS Foot Pegs & Heel Guards, AC Nerf Bars, Maier CF Scoop Hood, Kawie Gripper Seat Cover, Royal Purple 15-W40 Motor Oil, ESR Temp Gauge, Crankcase Vent Mod, Fluidyne Radiator, Two Aluminum In-Line Coolers, LED Tail Light, Precision steering stabilizer, Maxxis Razr 2's on Black C-Series rims, 24" Extremes 9 Paddle & 21" Buffed Mohawks on Polished C-Series rims, 22" Innova Racers (rims undecided), ASR SS +2" Brake Lines, ASR +2" A-Arms & Tie Rods, All Ball's Racing Tie Rod End's, Durablue 2"+2" Eliminator Axle, G-Force +3.5" Extended Hubs, Houser Black +2" steering stem & Anti-vibe Fat Bar Mounts, Black Pro Taper Couture Fat Bars, Elka's Race Front & Rear, FPS800 BBK, Nikasil cylinders, Fully ported, Trail/Race cams, 36mm F4 carbs , UPP 36mm Intakes, Braided Fuel lines, Black & Silver IMS Powermadd Star Hand Guards, LC1 Digital Air/Fuel Gauge, Polished Shorty Shifter, Moose Billet Throttle, Ven's +4" Swing arm Ext., Everything powdercoated Black & White, Dyno Tuned @ 64.5 RWHP
Eforce13 is offline   Reply With Quote
Old 05-09-2008, 02:36 PM   #4
conig's Avatar
View conig's Photo Gallery(0)
Default
there is a chart on here. drilling jets is i beleive how i found it. you will probable need numbered bits for a size that small.
2004 blaze orange kfx-700. HMF Duals, epi orange, 55gram weights, boondockers, upp intakes, twin air proflow, 15 hole, proarmor bumper, mini ms mod, 6000k HID's , msd plug boots, overdrive clutch, 22-14-8 mini desert traks, venlowering kit, adjustable aluminuim rear strut wheelie bar.
2002 scrambler 400 2x4 freedom plastics and graphics, hpd race pipe, boxermutt/Bubba porting, lectron, e85 duner/dragger and who knows what else.
1999 cr 125r. skids, gaurds, fmf shorty and crisp jetting. woods rider/play bike.
conig is offline   Reply With Quote
Old 05-09-2008, 03:36 PM   #5
Feedback Score: 3 reviews
GAUGE's Avatar
View GAUGE's Photo Gallery(0)
Default
I'll get one for you....I have to skan it then post it....
AMRacing
"FILL YOUR HANDS YOU SON OF A BITCH!"
GAUGE is offline   Reply With Quote
Old 05-09-2008, 03:49 PM   #6
BossMan's Avatar
Default
[/b]
Thanks, there is some stuff I'm reading in search, I typed jets & its under drilling jets. I do have a LM-1 to check A/F.
05 KFX 700-FST 715
Georgia
Old 05-09-2008, 04:41 PM   #7
View stinkybutt's Photo Gallery(0)
Default
You could also just try shimming the needles to get it close so you can ride.
Aleck
stinkybutt is offline   Reply With Quote
Old 05-10-2008, 01:06 AM   #8
Kfxnando's Avatar
View Kfxnando's Photo Gallery(4) Send a message via Yahoo to Kfxnando
Default
hi!
just my 2c!!
dont drill jets, one never knows what happens, jets are cheap enough, rather have a variety of them at home!!
just my 2c!! thanx!!
good luck!!
KFX700(fast green) wheel spacers, nerf bars, full hydedevelopments bash plates, Trail Teck Vapour, motor internal stock, PENTA 2 into 1 pipe(equal length headers), twin air filter element, blue Dalton spring and O/D cover, stock weights
BF750 - 2inch spacers all round
TRX250TM
FZR1000 EX-UP yoshi, BMC filter 155bhp
http://community.webshots.com/user/kfxnando
http://www.youtube.com/kfxnando
www.kfxnando.com
Kfxnando is offline   Reply With Quote
Old 05-10-2008, 11:39 AM   #9
View jake_evans420's Photo Gallery(0) Send a message via MSN to jake_evans420
Default
Drilling Jets Chart
I think this is what you are looking for.
Also Drill Bit Sizes
5TH GEAR PINNED CAUSE GOLF COURSES SHOULD BE MX TRACKS!!!!!
Sold the V.
Black 94 Mustang GT, conv., crome cobra R rims, drag radials, dual flowmasters, high flow cats, and H-pipe.
06 ZX-6R 636
GPR Stabilizer
PICS------> http://s165.photobucket.com/albums/u59/jake_evans420/
jake_evans420 is offline   Reply With Quote
Old 05-10-2008, 12:02 PM   #10
Eforce13's Avatar
Default
The thing about that jet chart is keihin jets don't come in half sizes.
carb jet size chart
carburetor jet size chart
jet size drill chart
keihin jet size chart
drill bit conversion table
carburetor jet drill bits
jet chart drill
keihin jet drill
carb jet sizes
keihin carb jets drill
KEIHIN JET DRILL BIT SIZE
WHAT SIZE DRILL BIT KEIHIN JET
carburator jet size chart
CLUTCH DRILL BIT YAMAHA
small drill bit sizes chart
"drill bit chart"
fuel jet drill bits
drill bit for carburetor jets
micro drill bits for jetting
You may not post new threads
You may not post replies
DJ conversion chart, how accurate? ManicHaze Kawasaki KFX700 V-Force 13 05-24-2007 04:41 PM
Anyone know what size drill bit is a 200 jet? krewzlo Kawasaki KFX700 V-Force 6 02-13-2007 03:57 PM
Gonna Drill Some Jets 700Bullet Kawasaki KFX700 V-Force 2 09-30-2006 05:48 AM
Is there a conversion chart for Dyno/Keihin Jets? KeithsKFX Kawasaki KFX700 V-Force 3 05-21-2005 11:11 AM
(no drill) mud flaps for sale northend For Sale 10 05-03-2005 07:44 AM
