clutch belt light!!!! - Kawasaki ATV Forum
post #1 of 8 Old 08-12-2008, 01:49 AM Thread Starter
stuntman700's Avatar
Post
hey guys well i was riding my kfx700 and all of a sudden my CHECK BELT LIGHT goes on..i checked the belt and it was fine no cracks or signs of belt slippage!!!!!so i heard that the light goes on every 100 hours...but how in the world do i RESET or TURN OFF the light on my bike????any ? please help me out kawie experts it would mean alot!!!!!!!!!!!!!!!!!!!!!!!
stuntman700 is offline
post #2 of 8 Old 08-12-2008, 03:58 AM
1stQuad's Avatar
The KFX700 belt check indicator light turns on after 100 hours to cause you to take it to the dealer and get the belt checked.
Turn ignition off.
Remove Seat.
Locate the two 4 pin connectors under seat. One is black and the other is grey.
Disconnect both connectors and reconnect them to their opposite color (black to grey, grey to black).
Turn on the ignition switch.
The belt indicator light should flash.
Turn off ignition switch (note that the hour meter is reset when the key is turned on).
Disconnect the two connectors and reconnect them to their same color (black to black, grey to grey).
Turn ignition back on and confirm that the belt light is not on.
Dicksatv.com.Toll Free 1-877-764-8313.Great Prices And Even Better Service!
Photos http://community.webshots.com/user/mark7117
1stQuad is offline
post #3 of 8 Old 08-12-2008, 04:16 AM
Feedback Score: 1 reviews
700ccMARSHMELLOW's Avatar
Mine has been on for over a year now I like the red aviation glow at night.
700ccMARSHMELLOW is offline
post #4 of 8 Old 08-12-2008, 05:41 AM
Kfxnando's Avatar
1st welcome stuntman700
1stQuad's description is spot on, thats the way to go!!
for every time the light flashes it resets 10hrs off the counter!!
good luck!!
KFX700(fast green) wheel spacers, nerf bars, full hydedevelopments bash plates, Trail Teck Vapour, motor internal stock, PENTA 2 into 1 pipe(equal length headers), twin air filter element, blue Dalton spring and O/D cover, stock weights
BF750 - 2inch spacers all round
TRX250TM
FZR1000 EX-UP yoshi, BMC filter 155bhp
http://community.webshots.com/user/kfxnando
http://www.youtube.com/kfxnando
www.kfxnando.com
Kfxnando is offline
post #5 of 8 Old 08-12-2008, 07:52 AM
go here under V-force
http://www.nyrocatv.com/techtip.cgi
jeemann99 is offline
post #6 of 8 Old 08-14-2008, 01:14 AM Thread Starter
hey thanks for the warm welcome KFX NANDO! so are these black and gray two 4 pin switches.. near the battery????
post #7 of 8 Old 10-05-2008, 11:16 PM
Turn ignition off.
Remove Seat.
[/b]
----------------I HATE TO BUT IN GUYS BUT capz sorry............but i've been searching and found nothing of course that is my situtation!!!! I even had a guy that owns a cycle shop on speakphone while i was doing this to reset the light and it still didn't not work!!! i went black to gray and vice versa and unpluged the two wire black connector if your looking at the belt housing that's on the back of it=btw there's also anoher white/clear 3 or 4 wire plug i've been trying to figure out from blow ups what that is. The light flashed quickly and all so i know i was doing it right just done understannd want i didn't even ride it.just put it in N and gave it gas and it was stilll sounding like it was in "limp mode" which basically you all know i'm sure but it sounds like your in reverse not using the override button.! Now what dound bbe going on? any suggestions? I do know this box not my cdi. but the other box that has one plug closest to the front under then seat i thik is bad and maybe that's finally went bad for good then and the light came on b/c of that@ I can't even find a website that has this box listed to tell me what it does or how much they aare. I'd love to find someone parting out there praairie orr twinpeak so i could buy both of thos boxes the cdi and the I've heard it called an ignitior box which sounds like one big relay box. All I know is it was puring gas out my overlow unttiill I while it was running unhooked it and turned key off which btw it did nthing the bike kept running fine! lol and plugged itbag in and the overflow fuel stopped! so it must controll like a fuel regulator along with no telling what else ii jusst does and don't know it. Anyone have one for sale or a junk let me know-i can sendppicccs of what i need
mcnearc is offline
post #8 of 8 Old 10-06-2008, 12:16 AM
Kfxnando's Avatar
~TwinPeak~
are you working on a KFX700 or another kawie, just asking, couz if its not a V, most probably different
the description above applies only to the V!!
hope this helps!!
TRX250TM
www.kfxnando.com
Kfxnando is offline
2005 kawaski priae 4 wheeler belt light
belt tension light on kawasaki 4 wheeler
do all kawasaki four wheelers need the belt reset every 100 hours
how to reset belt light on 650 kawasaki four wheeler
how to reset belt light on kawasaki 4 wheeler
how to turn the belt light off on a kawasaki 4 wheeler
kawasaki 4 wheeler belt light
kawasaki 4 wheelers official website belt light on
kawasaki 700 four wheeler belt light
kawasaki four wheeler belt light
reset check belt light on kawasaki 4 wheeler
what does it mean when the belt light comes on a 2005 brute force four wheeler
what is belt means of a kawasaki 4 wheeler
belt light bosshog Kawasaki KFX700 V-Force 4 05-16-2011 09:03 PM
Belt Light will not go off wvprairie Kawasaki KFX700 V-Force 13 09-27-2009 07:00 AM
Belt Light VTBF750EFI Kawasaki Brute Force/Prairie/Bayou 13 05-29-2009 12:32 PM
785 v belt light tim Kawasaki KFX700 V-Force 3 07-10-2007 04:57 PM
Belt light scooterdale Kawasaki Brute Force/Prairie/Bayou 1 04-21-2005 04:54 PM
