In the middle of replacing my rear axle seals, right hand side you need to remove the bearing from the gear case cover to get the seals in or out, any tricks to doing this without damaging the bearing. Not much of a lip there to get ahold of it with a puller. The manual i have just says to replace the whole cover if the bearings or seals are bad. any help would be great
Thanks
Shane
like wise, I put mine (bearings) in the freezer before putting them in, makes them easier getting in
Related Threads
Kawasaki ATV Forum
971.2K posts
52.3K members
Since 2002
