On the Kawie Forum website they show the clearance on the valves .10 - .15 and .20 - .25. Is this correct?
I think stock is .004/.006 mm but with bigger cames I set mine at .006/.008mm.
[/b]
700V.com---adjusting valvesOn the Kawie Forum website they show the clearance on the valves .10 - .15 and .20 - .25. Is this correct?
[/b]
What does 700v.com mean by .10-.15<div class='quotemain'>
[/b]
If it is stock just set it at .004 / .006 & stop worrying about it. people in here will not purposley stear you in the wrong way. or try & hert you or your bike this is a kick A$$ site for the V with lots of very smart people in here that love the V & want to help you for free.
Oh no worries here. You guys have helped me many times. I was just a little confused with the numbers thats all. Are the intake and exhaust the same settings?
[/b]
No..
The intake is the lower # and the exhaust is the larger #
Thanks alot. I appreciate the help.......
The numbers are correct, but that should be in inches, not millimeters. (.004" .006")I think stock is .004/.006 mm but with bigger cames I set mine at .006/.008mm.
[/b]
The numbers are correct, but that should be in inches, not millimeters. (.004" .006") [/b][/quote]<div class='quotemain'>
[/b]
