05-31-2009, 05:29 PM
#1
No more gears
I'm a new member in need! I got rid of my old 400ex and picked up a v-force and i'm not sure why. I thaught that 700cc would be absolutely nuts but i got to say that i was sorely mistaken.
The machine is an '04' with about 10 hours on it. I just threw in a Dalton clutch kit and kept my fingers crossed but was let down again. Can someone tell me the best mods for your dollar because if it takes another 2 grand to make it fast than it's gotta go. Let me clarify that when i say fast i don't need to go 100 but it better tear my arms off. Thanks to everyone that gives me some feedback.
05-31-2009, 05:36 PM
#2
Feedback Score: 10 reviews
BBK and cams. $1100.00
Green KFX 700, FST 800, stage 3 cams, AMR ported heads, 36mm carbs, My +6" billit swing arm extension, My 6 pack rack grab bar. Trail Tech dash clamp and bars, Trail Tech lights, My Manta dash, Stadium shocks front and rear, LTE exhaust, Razer 2 tires. Boondockers NOS, IMS front bumper. My radiator guard. My 14mm stainless steel tie rods. ODI grips, Honda throttle, My stainless steel pegs, FST billit clutch cover, My billit stator cover.
www.atvtrickstuff.com
www.diamondgracing.com
05-31-2009, 06:22 PM
#3
Feedback Score: 3 reviews
vens right... for about 1k you can just about double your horsepower on the bike... it is like night and day..... you will not be dissappointed...
FST 730
BILLET GAS CAP
BILLET SHIFTER
FLEXX BARS
ROX RISERS
ACEWELL TACH
DYNA CDI
ELKA SUSPENSION
INTERCOOLER SYSTEM
05-31-2009, 06:29 PM
#4
Feedback Score: 6 reviews
Did I miss something here if you think the kxf is slow then that 400ex should have felt like a complete turd. I would have to agree with what was said already do a big bore you won't be disappointed.
05-31-2009, 06:46 PM
#5
Feedback Score: 1 reviews
search on here for the 12 hole airbox mod.drill the jets.put on a pipe. it'll run with or faster than most 450 with bolt ons and he price is fairly cheap.
If Obama is the answer,the question was stupid.
05-31-2009, 06:56 PM
#6
Feedback Score: 17 reviews
Yea my Bro-inlaw has a built up 400ex and my bolt-on 700 will absolutely destroy his Honda. My 700 was fast even when it was bone stock.
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
05-31-2009, 06:58 PM
#7
you might not be used to the steady pull of the automatic.. ive had 2 440EX and they were not a little bit fast, but the little snap they give when you shift might give the allusion..
DS1000 VULCAN 1600 CLASSIC ZX12R KD80
05-31-2009, 07:06 PM
#8
What did you throw in for the Dalton clutch kit the DPK 56's, 57's or 58's?
With any of them you should of felt a lot more on bottom although they could feel a little sluggish with the blue spring.
The 12 hole mod, and a minimal of an overdrive cut clutch will certainly help, and the 12 hole is pretty much of no cost but can't say the same for the clutch mod.
05-31-2009, 07:09 PM
#9
Thanks for the advise and by the way, the trx may not be faster than the kfx but when you come out of a burm or anywhere with a rolling start ant you can pin the throttle and want more it is discouraging from a 700, when you can do the same thing on a trx and snap the clutch and stand it up.
05-31-2009, 07:40 PM
#10
12 hole mod, trim the springs, polish the slides, spark plug mod, VFJ Stage 3 clutch, a good filter, exhaust & jet it correctly. Should not cost much more than $500 or so. It will be a good bit snappier..
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
» Site Navigation |
