From Cat @ Nyroc Site
Take a look at this procedure.
1. Turn the ignition switch to the OFF position; then
disconnect the 4-pin connector.
2. Connect the Reset Connector (p/n 0486-161) into
the forward 4-pin connector; then turn the ignition
switch to the ON position. The belt indicator light
should flash rapidly.
3. Disconnect the belt indicator light switch
connector. The light should flash slowly. Allow
the light to flash for 10 seconds before turning the
ignition switch off.
4. Turn the ignition switch to the OFF position; then
remove the reset connector.
5. Connect the 4-pin connector and the belt indicator
light switch connector; then turn the ignition
should go off.
or this procedure:
disconnect the 4-pin connector and the belt indicator
light switch connector.
2. Install the Reset Connector (p/n 0486-161) into the
switch to ON. Allow the belt indicator light to
flash for 10 seconds or more; then turn the ignition
switch to OFF.
NOTE: The light will flash rapidly for 5 seconds;
then it will flash slowly. Allow the light to flash
slowly for at least 5 seconds before turning the
3. Remove the reset connector and connect the 4-pin
connectors and the belt indicator light switch
connector.
4. Turn the ignition switch to the ON position and confirm
if its revving really high and not moving its not the 100hr reset.. it should be moving like normal but not able to rev up if that was the problem.. take your clutch cover off and take a look
other kawie models like some of the BF models had it!!
would also say, problem else where!!
again from what I recall of the models with limp mode they would not rev!!
sounds like something slipping,
could even be one of the clutches not shifting!!
good luck
Related Threads
Kawasaki ATV Forum
971.2K posts
52.4K members
Since 2002
