06-11-2009, 09:34 PM
#11
Will they come in pink???
06-11-2009, 10:30 PM
#12
Feedback Score: 9 reviews
Quote: Originally Posted by mike@bwoodyperformance
I just mainly need input, do you guys want lower springs or just softer or both?
I don't need the lowering. If I want to lower it, I could get the lowering kit from Venforcer. I would mainly just like to have softer springs. The stockers are very harsh. They may be alright for someone 220+ lbs but I am 180 and they are way too stiff. A softer spring with the same ride height would be the way to go.
'04 KFX730
Fundy 11.1:1 Pistons, FST Stage 2 cams, Ceramic-coated Muzzy Exhaust, +8 Swingarm, 12-Hole Mod, UPP Cross-over Intakes, 3/32" drilled main jets, #42 pilots, 3 shims/needle, Elka Front Shocks, Revalved Rear Shock w/ Road Magnet Spring, CCP Steering Stabilizer, TrailTech X-bars/Clamp, Pro-Armor nerfs--grab bar, #2 Blaster Paddles, Polaris Yellow Clutch Spring w/ 2 shims... BOSS NOSS 30-shot
'04 KFX700
DMC Afterburner Quiet4 Dual Exhaust, 12-hole Airbox Mod, Crossover Intakes, #45 drilled main jets, shimmed needles, 6* Timing Advance Key, Spark Plug Boot Mod, Road Magnet Suspension Springs, 24x11-10 8-paddle Skat-Trak Extremes on 10x10 wheels, EPI Almond Clutch Spring
06-12-2009, 06:28 AM
#13
Feedback Score: 4 reviews
i would think just softer. im 265 and feel like if i try a donut ill roll the bike on top of myself. lowerong would be nice, but then the loss of ground clearance would kinda suck for trail riding
04 kfx700 kawi green, muzzy pro, k&n , polaris white spring, prm desert bumper/grab bar, 12 hole/ms mods, 5/64 mains, 42 pilots, carb mods, dynatek, 6* key, rox anti vibe risers, pro taper contours, Camo's shorty shifter
05 marble orange kfx700, theft recovery project!! aka " voodoo quad ": fps, amr, lte's . . . Under reconstruction
02 prairie 650, camo ,27" mudzillas,25" holeshot atr's, currently not running
06-12-2009, 07:25 AM
#14
I think that softer springs used in conjuction with Venforcer's lowering kit would be a nice setup (if you wanted to go lower).
Would you make only one spring rate or a few different ones based on rider weight. Seems like a softer spring for a 180-lb rider would be too soft for a 260-275 lb rider.
'04 KFX730
'04 KFX700
06-12-2009, 07:38 AM
#15
Feedback Score: 18 reviews
I'd only be interested in a softer OEM replacement springs. I'm 150 and the stock springs beat me to death. Softer springs would be the perfect mod for the V.
2005 FPS 700= FPS BBK, CWR 418 cams, VFJ clutch, Quadboss full skids, TwinAir,12 hole mod, 42 pj, LTE duals, Spark plug mod, ASR Brake Lines, Crossover intake, Razr 2's on Hiper Tech 3, Orange Power Mad Handguards, TrailTech bars, mount , Vector, Carbon Fiber hood, H.E.P Taillight, AC front bumper, AC nerf bars, fan switch
2007 Brute Force 665= VFJ clutch, 82mm pistons, CWR 418 cams, Custom BKuzzy exhaust, K&N filter, UPP intake, Electric fuel pump, Fan switch, 42 pilots
06-12-2009, 09:24 AM
#16
Feedback Score: 6 reviews
I am interested pending a good price. Powdercoated black.
The Speed Force KFX800™
FST800, Stage 3's, Muzzy Pro, VFJ Stage 3, 36's, EPI Maroon, MSA Wheels, Duro Scorchers, Powdercoated Everything. Proud winner of August '09 KOTM and lucky winner of December '09 KOTM.
06-12-2009, 03:19 PM
#17
alright its done then we'll just change the load rate too make them softer, i'll keep you all informed on the progress.
2009 Renegade X (HID Conversion, Stock)
2009 Polaris RZR (muzzy, power commander, BWoody snorkel kit, clutch limiter removed)
2009 KFX 700 V-Force (AMR 730 BBK, Muzzy SUper Pro, Venforcer +4, xx cams, AMR p&p heads, +1.5 int. +1 ext. Valves, crossover intakes, 6 degree key, Trailtech clamp, trailtech vapor, 12 hole mod, velocity stacks, Twin air filter, maroon clutch spring, custom BWoody oil catch can, Plethora of green powdercoating)
2009 Polaris 850 XP LE(HID, Super Swampers ITP rims)
2008 Polaris Sportsman 500 EFI Touring (AAen slip on, HMF tuner, K&N)
2009 Polaris Sportsman 300
2006 Polaris Hawkeye 300
2007 Dodge Charger SRT-8 (392 stroker 530 whp)
2007 Jeep Grand Cherokee SRT-8 (11.27@122)
2005 Viper SRT-10 Truck (Beater...lol)
2004 Dodge Viper (941whp 984Tq)
2004 Dodge neon (10.43 @ 136)
1968 Road Runner 440 6 pack
06-12-2009, 07:26 PM
#18
How long will it take to make the springs?
06-12-2009, 07:38 PM
#19
Should only take a couple of weeks to get some prototype sets out.
06-12-2009, 08:01 PM
#20
I am really looking forward to the outcome of this. When I put the Works triple-rate shocks on the front of my green V it was WAY better because they are softer. The same thing would be nice to do to the rear shock. My orange V is stock all the way around so that one could benefit from a whole set.
If it helps at all, a tech at Works told me the spring rates of the springs on the front shocks that I have. I had bought them used and had no idea of the spring rates. I measured them with a calipers and he knew exactly what spring rates they were. The uppers (blue) are 600-lb, the middle ones (black) are 900-lb, and the lower main spring (red) is 235-lb. I don't know if any of that info would apply or help for the springs you are trying to setup. Here's a picture.
'04 KFX730
'04 KFX700
| Visitors found this page by searching for these keywords: |
kfx 700, kfx 700 6 degree timeing key, 1968 roadrunner 440 6 pak, converting kfx 700 swing arm, 2009 polaris rzr, kfx 440 for sale, power commander for kfx 700, h.i.d conversion kits clam shock atv
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
any interest in
hndlbarmonkey |
Kawasaki KFX700 V-Force |
12 |
09-18-2007 05:57 PM |
Any interest?
V-powered 730 |
For Sale |
4 |
09-13-2007 05:03 PM |
Gauging interest
DaveHenke |
For Sale |
5 |
08-10-2007 08:39 PM |
Interest?
Ranger |
For Sale |
17 |
03-21-2005 05:46 PM |
A arm interest?
Big Al |
9 |
11-16-2004 02:28 PM |
» Site Navigation |
